Reload this Page >
Flyeaglejet F35 A 1:7
Old 06-02-2013, 09:44 AM
  #51
pjlt
Default RE: Flyeaglejet F35 A 1:7
Peter, isn't that part a sandwich of honeycomb and wood?
Old 06-02-2013, 10:03 AM
  #52
pjlt
Just checked it: the front clamp of both vertical stabs are build from a sandwich of honeycomb and plywood, the aft clamb is on a large hobeycomb former with al sorts of small plywood formers on the aft side of it. To me this seems very strong. And if not, Peter would have noticed this...
Old 06-02-2013, 10:29 AM
  #53
FalconWings
My Feedback: (57)
FalconWings's Avatar
ORIGINAL: jolmer
I concur, this is no challenge for Peter!
[8D]
Old 06-02-2013, 11:10 AM
  #54
pjlt
You're right, it isn't. That's why i asked him to build my F-35...
Old 06-02-2013, 12:13 PM
  #55
AndyAndrews
AndyAndrews's Avatar
The whole thickness needs to be plywood or ply on both sides with honeycomb sandwiched in the center if one were to use it. That thin strip of ply on one side isn't enough for support. The crushed honeycomb on one side does not offer any type of structural support of any kind. Note how the hardware is dimpled in the honeycomb. Once it's crushed there is no support in that area other than the thin layer of ply on one side.
Old 06-02-2013, 12:45 PM
  #56
FalconWings
My Feedback: (57)
Andy I see a layer of ply on each side, but if its only on one side you are absolutely correct.
Old 06-20-2013, 06:53 AM
  #57
pjlt
Hello everybody,
I've posted some updates on my project website and will continue to do so for the remainder of the build. Here's the URL of my website:
     www.f35model.nl
It is in Dutch, there is no correct translation to English yet. But you can give Google Translate a try, with its automated translation?
     www.f35model.nl automated translated into English
Kind regards from The Netherlands,
Jolmer
Old 06-20-2013, 07:07 AM
  #58
gunradd
My Feedback: (9)
gunradd's Avatar
Love the paint work on it so far. Its about time some one did it right! All the panel edges have the lighter paint. Very well done.
Old 06-20-2013, 07:23 AM
  #59
pjlt
Thanks! The lighter items is car wrap foil, with cover of mattique foil. No paintjob there, which is reversable if neccessary...
Old 06-20-2013, 07:27 AM
  #60
pjlt
Here some pics:
Here with test pilot Billie Flynn from Lockheed Martin:
The rest is on my website: www.f35model.nl
Regards!
Old 09-10-2013, 12:48 AM
  #61
pjlt
Hi folks!
Back with an update: I posted some new pic's and video's on my website:
http://www.f35model.nl/bouw/nggallery/page/8
http://www.f35model.nl/evenementen
http://www.f35model.nl/video
Here are two for your appetite:
For the rest of the pic's and video's, please visit my website:
Cheers!
ID:	1918692   Click image for larger version
Old 09-10-2013, 12:34 PM
  #62
General Jake
General Jake's Avatar
How can I order this plane, are there any US reps?
Old 09-11-2013, 01:39 AM
  #63
pjlt
I don't know. Is there someone from the US that can answer that?
You cannot buy this plane the way mine is looking right now. It took a lot of work, extra money and skill to pull it off.
Old 09-11-2013, 04:33 AM
  #64
General Jake
There are no Fly eagle dealers in the US?
Old 09-11-2013, 05:08 AM
  #65
FenderBean
FenderBean's Avatar
There are three I know of in the US but they do not monitor RCU much any more. I suggest you do some research on rcu on the company. If your still interested send me a pm I can get you in contact with one.
Old 09-11-2013, 08:08 AM
  #66
David Jackson
My Feedback: (15)
Hi General Jake,
Try [email protected]. The rep is James Chen. Lowell Wexler is another US rep, but I don't have his contact info.
Old 09-11-2013, 11:55 AM
  #67
Peter Coers
Peter Coers's Avatar
I have this one from Lowell,
[email protected]
Old 09-23-2013, 01:00 PM
  #68
pjlt
Last week, my model ended up on national television, in a debate on the purchase of our F-35's:
http://debatop2.incontxt.nl/seizoene...gen/18-09-2013
For more info, please visit:
Regards,
Jolmer
Old 06-07-2015, 07:33 PM
  #69
FalconWings
My Feedback: (57)
Well, I'm ready for engine installation now. I have to say this thing has come together a lot better than I had expected. Hardware was decent, fit of parts was good, left the gear pressurized overnight with no leaks, lots of room for equipment. Mine does not have any HC, it has hardwood formers all over. Everything "I can see" is hard mounted. I could easily fit 80oz of smoke fluid inside just forward of the CG.
I was ready to get busy with carbon reinforcements, but they don't seem to be needed. I'll just have to keep an eye on everything inside until I grow comfortable with it. I still want to get xrays of wings, stabs, and rudders (my dentist owes me a favor :-)
Yes, you will need a nice sequencer and 4 air valves (I have a mix of electronic and servo driven). The gear has a set of doors that only open during gear cycling, and remain closed the rest of the time(at least the real one does).
I'll keep you posted.
David
Old 09-09-2016, 07:18 PM
  #70
sysiek
My Feedback: (176)
sysiek's Avatar
Hi to all the f-35 flyers will you be able to give me the most correct cg info ,I'm planning to maiden my jet but I'm not sure with the cg location thanks.
Old 09-10-2016, 08:03 AM
  #71
FalconWings
My Feedback: (57)
All FEJ F-35 flyers? I think its just one LOL!
Im flying on factory recommended CG, its pretty good. Would not go any further aft. I'll check my docs and get back to you.
Old 09-10-2016, 03:10 PM
  #72
sysiek
My Feedback: (176)
sysiek's Avatar
Thanks for the info. But I don't have the instructions with the jet so I'm looking for the info will you be able to post the cg and from I should measure thanks.
Old 09-10-2016, 07:59 PM
  #73
sysiek
My Feedback: (176)
sysiek's Avatar
I don't have the location of the CG. Could you help me. I want to try to fly the airplane tomorrow. You would be a big help if you could get me the measurement
Old 09-11-2016, 02:38 AM
  #74
Peter Coers
Old 09-11-2016, 07:38 AM
  #75
FalconWings
My Feedback: (57)
Thats exactly what I used! Bought the Xicoy CG meter just to locate it spot on.
You will notice it feels very nose heavy when sitting on its mains,its normal because the mains are too far aft. It will take a lot of forward speed to rotate, flaps help a lot.
In the air it feels good with the recommended CG, very solid.
David
