 Two quick questions.... >
Old 02-23-2013 | 09:58 PM
Default Two quick questions....
Question 1. I have an older jet that I am trying to get back into the air a hotspot. When it was built by the original owner he put the fuel tank in so it could not be removed. Well when I put the plane away I emptied the tank the best I could. How do I and what do I use to flush the tank out with to ensure there is no mold in the tank. I was thinking of using some acetone but not sure if that would hurt the kevlar tank or not. After flushing it with the acetone I was also going to fill and flush with Jet A fuel to get the acetone out. What do you guys think?
Question 2. Same jet. When it was originally built with screws through the top of wing as a mounting method instead of the wood tongue method. I don't have the complete measurement for that piece of wood. I know it is 5 ply hardwood which is 1/4" thick, and 1/2" wide I just don't know how long that piece is. Does someone have a measurement of that length?
Patrick
Old 02-23-2013 | 10:01 PM
dubd's Avatar
Default RE: Two quick questions....
I personally would not fly the plane unless I was able to replace the clunk line. There is a good chance that the line has hardened give how long the plane has been sitting around.
Old 02-24-2013 | 05:16 AM
My Feedback: (49)
Flush out the tank with gasoline, that will kill any algae. Then flush with kero or Jet A to get the gasoline out. Replace ALL fuel lines and filters. If you have a UAT then that needs to be flushed just like the tank and the filter sock replaced.
Joe
Old 02-24-2013 | 04:08 PM
See the "Consensus of Hot Spots" thread on this forum-several pages back. There's some good info posted from many Hot Spot pilots.
Art ARRO
Old 02-24-2013 | 06:37 PM
DAN AVILLA's Avatar
My Feedback: (12)
About every 2 years I  pull the tanks on my planes and go through them.The tubing on the clunks and stopper is loose even with safety wire. I would try to get the tank out and do it right. Not worth loosing a jet over it. Dan
Old 02-25-2013 | 06:43 AM
ORIGINAL: Art ARRO
See the ''Consensus of Hot Spots'' thread on this forum-several pages back. There's some good info posted from many Hot Spot pilots.
Art ARRO
Art,
I tried to find that thread to ask the question in but could not find it. Even did a search on the word hotspot and it seems to have been deleted or something.
Patrick
Old 02-25-2013 | 08:27 AM
iiievolution's Avatar
http://www.rcuniverse.com/forum/m_11333192/tm.htm
Paul
