National 747 crash
RE: National 747 crash
Wow DiscoWings. What a jackass is right. ( used in correct context as a donkey) why don't you go strap about 7 lbs of lead to the tail of your F-18 and see if you can fly it. Take a video too so I can call it pilot error when it rotates and goes straight up and then into the ground in a fireball.
There have been several reports indicating seven or eight crewmembers aboard.Five of the crewmembers are from Michigan.One member was just married earlier this month and not only leaves behind his new bride, but his one year old daughter as well.There were four pilots, two mechanics and one loadmaster aboard.
Please be kind to each other while posting as we are with heavy hearts.
-Clear skies to all
#31
Just tragic to watch, heart goes out to the families.
Whatever the cause it's plain to see airspeed pretty much drops to zero with the inevitable stall.
Rob.
Rob.
#32
Wow, so sad. And condolences to the families.
I wouldn't even consider pilot error. Any pilot with enough time to be flying big iron would have been shoving that nose down, muscle memory and instinct , IF it was possible.
My younger brother is a Mechanical Engineer at Northrop Grumman. Before that he was at Boeing working on cargo systems , floor rails and restraints. It was always priority 1 to prevent a load shift. It was common knowledge that a big load shift could easily lead to the tragic loss of the aircraft. The critical phases were in heavy turbulence and especially take-off. So sad for these guys and their families.
#33
ORIGINAL: Hustler58
I don't think the nose would come back down if it were tail heavy. It would have done a tail slide.
what you saw is a classic nose high "upset" or "departure" and spin entry.
Tail slide? ....... How long have you been flying full scale jet or transport category airplanes?
#34
ORIGINAL: speed is life
......WRONG, WRONG, WRONG
what you saw is a classic nose high ''upset'' or ''departure'' and spin entry.
ORIGINAL: Hustler58
#35
??????? That is still my point, even grossly tail heavy, a plane like that is not going to "tail slide". It will just depart and spin. Besides, he was not going 90 degrees vertical in any case.
#36
1 Post
That is hard to watch. The pilots must have known it was all going horribly wrong for quite some time.
If the fire does not damage the black boxes the investigators will have data to work with
#37
AR
That is tragic. My heart goes out the the families. It appeared the gear was still down, dont care to watch it again to verify that, I suspect they were fighting with the aircraft trying to gain control of the pitch from the time of rotation.
#39
My Feedback: (60)
Absolutely horrifying video. Very sad indeed. That must have been a massive cargo shift for the plane to become that tail heavy if that is in fact what transpired.
Rest in peace gentleman.
S
S
#41
ORIGINAL: Grodus
#42
My Feedback: (34)
ORIGINAL: DiscoWings
Would like to see more video, why was the jet pointing striaght up, was the pilot knocked out? What was he trying to do? Hover the jet?
Sad but seriously PILOT Error!
Rumor is the crew was heard on radio stating the cargo had shifted aft. I can't verify if that was true or not, but it WOULD explain what's seen in the video.
#45
Very sad and agonizing to watch.
For you full scale guys on heavy iron, is there any way to tell the load is off while on the ground besides doing the math? AND how far aft can the CG go before the jet is either light on its nose wheel or just tips on its tail?
Its amazing to me that will the sensors and technology employed in aerospace that there isnt a scale built into the landing gear, maybe through the hydraulics in the struts, to get some accurate read on the CG of the aircraft prior to flight.
Who knows what happened here but I hope the cause is determined soon for closure.
#46
My Feedback: (34)
#47
My Feedback: (7)
If it was indeed a "shift", scales wouldn't have done squat on the LG. the word shift means that upon acceleration and rotation, the equipment used to tied down the equipment loosened, broke or shifted allowing the cargo to move aft causing the accident.
PS. As I was typing, Doug beat me to the punch... So ditto.
#49
The cargo floors in the 747's (or at least the ones I've seen) have steel ball rollers in them. This makes it easy to push around heavy pallets. But you can also imagine that if something failed in the cargo restraints all those pallets could be sliding rapidly to the back of the plane. Even if the pilot knew what happened he may not have had enough elevator throw to do anything about it. So sad, a tragic accident.
#50
Having flown 747 freighters for Northwest and being familiar with the hazard of load shift, I suspect that the truck shifted during the take off roll. A heavy take off takes about 45 seconds of roll from start to rotation. The full shift was probably complete right at or near rotation speed causing the unrecoverable pitch up with full power. All numbers in the FMC were probably correct for take off. There is a warning message during taxi if there is a CG problem. The nosewheel strut is part of the system. The accident aircraft appears to be a B-747-800 or 747-400.
My heart goes out to the crew and families. A nightmare scenario that could not be controlled once deep into the take off roll. There is not enough time/elevator or trim to recover controlled flight once that much weight shifts to the rear.
Joe Grice
Joe Grice
