Reload this Page >
Xtreme F-16 1/6.75
Xtreme F-16 1/6.75
Old 08-24-2018, 06:42 AM
  #226
smiller
Originally Posted by Dieselman1220
Looking forward to your build progress.
How did you set up your rudder linkage? The stock internal set up shown in the manual or external?
I did the internal with double rods. seems to be very tight.
Scott
Old 08-24-2018, 07:15 AM
  #227
afterburner
My Feedback: (18)
afterburner's Avatar
The wife was hovering above me last night so I could not elaborate much.
I am leaning towards a cheetah 140 I have. The ideal engine seems to be a k120 the cheetah is only a few grams heavier
slightly shorter in length and a 1/4" larger in diameter. I also have a a Rabbit SP I could use.
From my research the people flying them with 100s do not seem to be disappointed with the performance.
My only concern is fuel consumption. Im thinking a cheetah throttled back would maybe be more fuel efficient than a rabbit getting worked a little harder....
Makes sense. What scheme did you order?
Old 08-24-2018, 07:28 AM
  #228
Dieselman1220
My Feedback: (25)
Dieselman1220's Avatar
Alaskan camo, you should roll the dice with me and order one.
I don't like gambling alone.
Old 08-24-2018, 06:42 PM
  #229
afterburner
My Feedback: (18)
My favorite scheme. I have to wait till my HSD Arctic camo starts falling apart before getting something bigger. May not be too long :-)
Old 08-25-2018, 08:54 AM
  #230
Dieselman1220
My Feedback: (25)
I hear ya, I just can’t get myself to get into foam.
What would power it with? Cheetah or rabbit?
Old 08-25-2018, 05:25 PM
  #231
afterburner
My Feedback: (18)
Sorry for the delayed response. I'm the only RCU user who get's no email notifications from RCU since they changed the website.
Yeah, the foam thing was not a great decision. The Cheetah is the 31 lb version?
Old 08-25-2018, 05:52 PM
  #232
Dieselman1220
My Feedback: (25)
No worries, yea original cheetah 140.
or a rabbit 100SP
Old 08-30-2018, 04:56 AM
  #233
DAN 73
Hi.
I received this month this F 16 1 / 6.75.
It's the G2 version of the airex.
I have weighed all components and weighs 8.5 Kg.
I'll use a Jets Munt M 100 XBL turbine
Old 08-30-2018, 12:26 PM
  #234
Dieselman1220
My Feedback: (25)
Thank you for the info Dan73.
im surprised how light weight it is considering the size of the airframe.
Like the scheme too, I’ve never seen that one.
Old 08-31-2018, 05:39 AM
  #235
FalconWings
My Feedback: (57)
FalconWings's Avatar
no kidding my 1/8th is almost that!
Old 08-31-2018, 06:52 AM
  #236
Dieselman1220
My Feedback: (25)
Yea I’m still on the fence to power mine with a rabbit 100 or cheetah 140. If mine is that light I may go with the rabbit.
Old 08-31-2018, 01:48 PM
  #237
tp777fo
My Feedback: (28)
tp777fo's Avatar
New Jet Central motor released today. Lynx.....130 size. Slightly smaller than the Cheeta and has low fuel consumption. I saw it on their Facebook page.
Old 08-31-2018, 03:49 PM
  #238
Dieselman1220
My Feedback: (25)
Wow that would be perfect!
I saw the Hornet 85, but not the lynx.
Old 09-02-2018, 01:30 AM
  #239
DAN 73
https://www.facebook.com/A.FadzrolAn...2915017676585/
Old 10-29-2018, 12:24 PM
  #240
smiller
To those that have some flight time. What is the neutral point of the stabs. ?{ not mentioned in manual} I am setting up control throws on mine. Any control throw changes from manual ? CG ? I am setting up flaperons , Is this a good idea or not needed ?
Scott
Old 10-29-2018, 04:13 PM
  #241
pilot tw
Manual: http://www.skymasterjet.com/f16xtreme.pdf
Old 10-30-2018, 03:10 AM
  #242
FalconWings
My Feedback: (57)
Been wanting to get one of these, but the price of the 1/6 on the black market has been so good lately.
Old 10-30-2018, 05:42 AM
  #243
smiller
Originally Posted by pilot tw
I have the manual but It does not give you neutral stab setting. Does it line up with the trailing edge of the speed brake ?
Scott
Old 10-30-2018, 05:56 AM
  #244
Dieselman1220
My Feedback: (25)
Scott
Hi Scott, the only F16 I’ve ever had is a Tams 1/8.
your stab neutral will be dependent on CG.
I would start with a very slight amount of up eleveator.
maybe 1/8 to 1/4” above the speedbrake.
From my limited research the recommended CG and throws seem to be Ok.
Are you getting close to Maiden? What are your thoughts on the build so far?
Old 10-30-2018, 07:15 AM
  #245
smiller
Thanks for the info Dieselman ! It is turning winter up here in Rochester NY so it won't be flown till spring. I will get the engine this winter. The build is going well, landing gear and brakes are rigged, all servos are installed and functioning, wires are run, Tanks installed. Overall it has gone together well, the only concern is that I have some play in the stab bearings causing a little slop in stabs. I need to see if the washers they give you are pushing on the inner bearing race which would tighten the bearing play. This is my first jet with stabilators, so not sure what is acceptable. The only complaint on the finish {Thunderbird sceme} is that the markings are too big. Looks like maybe they used the 1/6 decals. Not a competition plane so not a big deal.
Scott
Old 10-30-2018, 07:16 AM
  #246
smiller
When I get some time I should put out some pictures.
Scott
Old 10-30-2018, 11:20 AM
  #247
afterburner
My Feedback: (18)
Old 10-31-2018, 03:09 AM
  #248
FalconWings
My Feedback: (57)
Originally Posted by afterburner
RCU Classifieds
Old 10-31-2018, 07:04 AM
  #249
afterburner
My Feedback: (18)
RCU Classifieds
Gotcha. Thought there might be something more I wasn't aware of.
Old 10-31-2018, 12:25 PM
  #250
FalconWings
My Feedback: (57)
LOL I'm afraid not!
