 Wing Tubes >
Wing Tubes
Wing Tubes
Old 06-06-2013 | 07:12 AM
DominicM's Avatar
Default RE: Wing Tubes
Many thanks Anton - Dom
Old 06-06-2013 | 10:23 AM
rc4flying's Avatar
My Feedback: (21)
ORIGINAL: pilot tw
ORIGINAL: rc4flying
ORIGINAL: jetpilot
Joe,
Email Anton for a replacement. I think there were two different sizes on the Hawk. possibly you got the wrong one somehow.
Scott
Hello Scott,
Thanks. Do you know how to get in touch with Anton?
Also thanks for the help with my lights question.
Joe
Hi, Joe
please email to John. we will send the new wing tube to you as soon,
[email protected] or [email protected]
Best regards
Anton
Thanks Anton. I will send an email now.
Old 06-06-2013 | 11:02 PM
lxfly's Avatar
Some interesting solutions and links for an important issue.
Nevertheless, the manufacturer of your plane should always be the first to contact, he should be aware of the problem and you avoid some unnecessary discussions.
By the way, CARF and Tomahawk Design use an inner dowel or second tube in their wing tubes.
<br type="_moz" />
Old 06-14-2013 | 12:02 PM
rc4flying's Avatar
My Feedback: (21)
Just wanted to give Anton and John from Skymaster a public Thank You.
As this thread title refers to, well I received a replacement tube from John today. I am very happy to also see that wall thickness is heavier than the one that kit with my SM Hawk.
Again, thanks guys.
Old 06-14-2013 | 01:21 PM
DominicM's Avatar
+1. Got my replacement tube from Skymaster today as well. Thanks Anton, will be pulling some higher G turns with my MB339 now.
Old 06-14-2013 | 02:04 PM
  #31
ianober's Avatar
My Feedback: (12)
ORIGINAL: prr6100
Find a friend with a lathe, buy a wooden dowel larger than the inside diameter of the aluminum tube, then ask him to turn it down so that is a tight fit in the tube. Slide or pound the wooden dowel into the tube, this will help staighten and fix the problem
Why would you do this? Yes it would be stronger, but it would also be 4x heavier for very little strength gain. Not needed. If you want to strengthen an aluminum tube then take some 3mm ply wood and rip a piece to fit in the tube, then orient the tub so that the plywood is vertical, bam, way less weight and way more strength along the proper axis. No need to make a carbon tube stronger.
