Euro sport speed brake question
![](/forum/images/badges/premium_member.png)
AL
Thanks Gary
I test fly all my jets at an open field, great for jet’s.
However my favorite field has a barbwire fence at each end.
Slowing down a jet is on top of my list.
Johnny
Johnny
Johnny,
im building one right now, and putting one in. Tood W. has me putting mine in he is the resident Euro expert. Im sure he will chime in. I just left his house and he is watching a movie, so look for him tommorrow. From what I understand, it really helps in high alpha manuevers. Good Luck.
Pete
Pete
Got me Im sure he will answer you tommorrow. Now you all are going to get me yelled at. Im supposed to be working on the Euro and he's gonna yell at me because Im online. He always catches me!
![](/forum/images/badges/trading_plus_member.png)
My Feedback: (24)
Doh....Actaully, I was not online last night. Just left the PC logged on.... Watched "Identity" with the wife....Good but very weird....
Johnny,
The speedbrake is not necessary, even for short field ops. This plane has a huge amount of drag and will drop speed off almost instantly. There is some big advantages to having a SB though. First, it allows you to have all you access items (air, propane, fuel fill, manual fuel shutoff and engine data bus) available without having to open the plane up. In addition, it gives you a great location for the UAT without having to run fuel lines up into the nose of the plane, then back to the engine. It also gives easier access to the center section of the plane. The big bonus, it really helps in High Alpha! The extra drag allows you to get the nose even higher and ride the pipe. With the speed brake deployed, I can ride a 45deg high alpha at 20 mph 5 feet off the deck and fly a full pattern this way...... Only drawback to having the speedbrake is it is extra work to install and, you will need a jettronics 2 port electronic valve to operate it. The reason for the Jettronic valve is you will need to be able to open and close the SB manually when the system is powered down. With the jettronic valve, when you turn off the power it bleads the air to the cylinder allowing manual operation of the door.
If you havent already, check out the ES mod page on my site for more info at www.lov2flyrc.com
Todd
Johnny,
Todd
My Feedback: (24)
Mark,
Certainly could be done with a servo! There is room under the brake to do so as well. It would take a beefy servo though and by the time you buy the servo to operate it I think your in it for the same amount of money as air?
Todd
Todd
My Feedback: (24)
I have notorious bad luck with air systems
![Big Grin](https://www.rcuniverse.com/forum/images/smilies/biggrin.gif)
Todd
AL
Todd
Thanks for the info that’s what I was looking for.
Mark
Have you gotten yourself a Euro sport?
If so what color
I went with red
Johnny
Mark
If so what color
I went with red
Johnny
No, I have not, but I want to. I have not yet done so cause I am far too busy at work right now. Hopefully, as the Shuttle gets closer to flight, I will have a life again, but I do not know when that will be. I'd consider buying one for the future, except I don't even have enough time to clear out a spot in the garage.
AL
“I have not yet done so cause I am far too busy at work right now “
Mark
I know where you’re coming from.
This 911-war thing has had me working what feels like 24-7 over the last year or so.
Having Saturdays off now is new for me.
After the wife and kids are all happy at the end of the day I have about an hour left in the day.
Some time I just pick sleep.
Johnny
Mark
Johnny
