Reload this Page >
Ripmax Xcalibur Sports jet
Old 03-30-2014, 09:29 PM
  #551
jetster81
As you are suggesting Dave it's a perfect club model, packs into most cars,easy to assemble,both in the workshop and at the field, flies great on smaller turbines, and handles very well. What more could you want?
Old 03-30-2014, 10:47 PM
  #552
ons_pk
ons_pk's Avatar
Hi Dave,
does it take Jet1A under carriage,
would P80se fit in ?
Omer
Old 03-31-2014, 01:13 AM
  #553
Dave Wilshere
Omar
Units would fit, but legs won't. Its not worth looking away from the Ripmax set, its excellent. The P-80 won't fit. No turbine bigger than 100mm dia will
Dave
Old 03-31-2014, 02:19 PM
  #554
ons_pk
ons_pk's Avatar
I was thinking of Élan's Replacement
omer
Old 04-03-2014, 02:50 AM
  #555
ausfester
Ken hooked me up with the sports version of this model, looks like a pretty quick build. Got it all hinged up in just a few hours.
Is anyone actually using the horns supplied with the kit?
Old 04-03-2014, 05:06 AM
  #556
kmrcjets
hi all. paul I glued in horns on every thing should have told you yesterday. I did it as I fitted a K100 in it
I was looking to make the model stronger on the control surfaces. told you the hinging was easy ha ha
Old 04-03-2014, 05:49 AM
  #557
Dave Wilshere
Have looked at horns a few times, but decided to go with stock horns and screws throughout, even with a P-100RX. Monitoring elevator horn for heat hardening, but so far after just 15 flights it looks and feels the same as when installed and I'm happy. Original model had lots of flying over 8 months and horns all still good, summer and winter flying!
Dave
Old 04-03-2014, 12:22 PM
  #558
ausfester
might see if I have something stronger for the elevator lying around and leave the rest stock. Thanks Dave and Ken
Old 04-04-2014, 03:08 AM
  #559
tp777fo
My Feedback: (28)
tp777fo's Avatar
Dave, You were right. I cut the wing tube too short and now it wont lock the wings in place. I need to remember the old adage....measure twice cut once... Do you have one in stock?
Old 04-04-2014, 05:51 AM
  #560
mikedenilin
My Feedback: (67)
Hi Tom. We can help you get the tube. We are ordering some parts from factory. Did you talk to Jose about it? Mike.
Old 04-04-2014, 06:51 AM
  #561
tp777fo
My Feedback: (28)
tp777fo's Avatar
Yes I did, waiting on quote. Looking to get one quick.
Old 04-04-2014, 07:29 AM
  #562
Dave Wilshere
Tom. Mike is your man. But I knew it was too much. Dave
Old 04-04-2014, 08:33 AM
  #563
tp777fo
My Feedback: (28)
tp777fo's Avatar
Really couldnt get wing to fit at all before I cut it. Think the secret to success is to bevel the tube when I get a new one. Oh well.....live and learn. Thanks anyway!
Old 04-04-2014, 12:02 PM
  #564
ausfester
Did you guys make sure the wing clamps were loose?
I assembled mine no problems not even much force, just a spray of silicone lubricant on the carbon tube and bam! This was from the Aussie batch tho
Old 04-04-2014, 12:47 PM
  #565
tp777fo
My Feedback: (28)
tp777fo's Avatar
I'm bummed....was really looking forward to flying it this weekend.
Old 04-04-2014, 12:54 PM
  #566
Dave Wilshere
Still have the bit you cut off? Hysol it back on, You could add a balsa wood + inside to support, the clamp only retains the wing, flight load is inboard
Dave
Old 04-05-2014, 12:39 AM
  #567
Dave Wilshere
One thing worth checking, the steering arm on the nose pin only has an M3 set screw holding it in position, I've seen two now where steering was becoming vague and it was this screw loosening. I loctited mine when I checked through the gear before installing-don't presume this is tight! .Its also worth checking the retract frame screws to ensure they are snug.
Dw
Old 04-05-2014, 01:25 AM
  #568
Danneman
I have 4 flights on mine now, from our grass field. Flight time about 9-10 minutes whit 1/3 tank left on my P-70 turbine. I have moved the CG to 168mm.
Regards Daniel
ID:	1984193   Click image for larger version
ID:	1984194   Click image for larger version
ID:	1984195   Click image for larger version
ID:	1984196   Click image for larger version
ID:	1984197   Click image for larger version
ID:	1984198   Click image for larger version
ID:	1984199   Click image for larger version
Old 04-05-2014, 04:01 AM
  #569
ausfester
Some interesting findings today with my build. The manual says mini servos for the rudders. One boom the mini servo kinda just fitted, there was almost not enough wood to screw them in straight down but on an angle it "just" worked.. The other boom the opening was way too big, so much so that a full sized servo fitted perfectly. I ripped the mini out of the first boom and made a full size fit.
I'm sure these small issues will get sorted in the next batches but regardless a full sized servo fits just fine.
Old 04-05-2014, 08:44 AM
  #570
Dave Wilshere
Daniel.Great, I took mine out hoping for another 5 flight session, but I ended up club trouble shooter and only managed one on my model.
Yes, Ripmax and the factory are aware, we discussed it after the first batch came through with FS servo openings. This allowed midi servos to be mounted deeper with plywood inserts glued behind the installed plates. Light weight servos are better for balance.I used JR 3401 servos which are now much lower price in England.
Dave
Old 04-05-2014, 02:16 PM
  #571
Worzey
The stock brakes are superb on this kit. I had another flight with the one I assembled for a clubmate and found I could hold the power of a Wren 100 up to 2/3 power. This caused the model to squat on the T/Link legs and give a cattapult type launch when released.
Significantly quicker than my P80se powered Elan with much better "get up and go". My Navy scheme Elan showed up better in today's overcast sky (Xcalibur is white/blue) and models have similar slow speed capabilities.
Both models very well suited to our 100m grass strip
Old 04-05-2014, 11:13 PM
  #572
Dave Wilshere
Ian I play with the "launch" take off too, we have a ridge on our patch from an extension and I can get a 4m take off roll with the P-100 wound up to brake creep, a reasonable head wind and TO flap and the kick the ridge gives! My Xcalibur lands slower than any Elan I have flown...its a lot lighter and similar size.
D
Old 04-05-2014, 11:40 PM
  #573
Worzey
Maybe i didn't try hard enough in slow flight with the Xcalibur.....mind you, its not mine to find the stall!
I'm sure there will be a few Xcalibur's at CJ's on Friday!
See you there
Old 04-06-2014, 05:22 AM
  #574
tp777fo
My Feedback: (28)
tp777fo's Avatar
Dave, found the cut off part....did as you said. Back in business! Thanks!!!
Old 04-06-2014, 09:40 AM
  #575
Dave Wilshere
Stall when you get there is sudden,its why is flicks, snaps and flat spins so well, but landings hover in!
Tom. great.
