Reload this Page >
Ripmax Xcalibur Sports jet
Old 07-19-2014, 10:57 AM
  #801
jetster81
Anyone fitted smoke? if you have can you publish some details please?
Old 07-20-2014, 02:43 PM
  #802
Andy Pratt
Just a quick "Hi" from another Xcalibur owner. Got mine from Dave at Motors and rotors. My first turbine model. Great advice has lead to me being completely smitten by jets. Booted all my glow stuff out. Got a couple of petrol warbirds and 3d machines but I need more jets! From my point of view the Xcalibur is such an easy aircraft to fly. Ok, on the maiden I was shaking like a leaf!!. Now I've got 10 flights under the belt I love it. Trouble is I only have a small patch to fly from but want more jets! Looking at scale stuff from the early jet age. Things like the Vampire, Sea Hawk and the Supermarine Attacker.
Andy
Old 07-20-2014, 11:23 PM
  #803
Beachy1968
Beachy1968's Avatar
For some reason I haven't been able to log on to here for a few days, but here's a quick update of how my build is going.
I managed to get another half day in over the weekend and so I started by putting in the fuel system. I used all the extra bits supplied by Motors and Rotors in their package; genuine Tygon tube, high flow clunk and of course with soldered on barbs and safety wired for peace of mind. A leak check showed everything was air tight so the tank then went in, taking great care to ensure the tubing could not move anywhere near the steering cables (they use wire to cut cheese so I'm sure it would do just as good a job on fuel tubing!)
Next I made up some mounts for the fuel tap and filter. No fancy alloy mounts here! The fuel tap is tucked down beside the tank and is on the suction side of the pump.
After making up battery and ECU data cables for the turbine, I was able to put the equipment trays in and finally finish everything up front. The first pic shows the 'quick release' tray containing the turbine equipment taken out.
Finally, I got to sort out the hot end! The fuel filter is tucked down to the right of the turbine cable tied to another plywood mount. The Merlin 100 needed both of the supplied packing pieces to centre it. I shaved away a little bit of the intake to get the turbine a bit further forward but the limiting factor is the very short nozzle on the Merlin, which needs to stay outside the fuselage for obvious reasons.
The engine has now been test run and everything looks OK. Just a couple of servo extensions, set up throws and balance and she will be good to go. The aim is to maiden on Wednesday...
ID:	2015894   Click image for larger version
ID:	2015895   Click image for larger version
ID:	2015896   Click image for larger version
ID:	2015897   Click image for larger version
ID:	2015898   Click image for larger version
ID:	2015899   Click image for larger version
ID:	2015900   Click image for larger version
ID:	2015902   Click image for larger version
ID:	2015903   Click image for larger version
Old 07-21-2014, 01:11 AM
  #804
mort78
Lovely install Mark. So darn neat!!!
Old 07-21-2014, 01:27 AM
  #805
Dave Wilshere
Mark
You need to take your tank out again...
You cut the overflow pipe at exactly the same angle as the tank top! Look at you installed shot its nicely sealing against the tank top, it will suck shut and you will get a flame out. I always cut the top as a ^ (roof top) so it can't do that
Dave
Old 07-21-2014, 01:53 AM
  #806
Beachy1968
Beachy1968's Avatar
Hi Dave
That did occur to me but I didn't think it could form a proper seal, but as ever I'm glad of your advice so I will change it. Everything is so easy to get at in the Xcalibur that it will only be a five minute job!
Edit: I exaggerated; including draining the fuel it took 8 minutes! So nice to have a jet with such a simple fuel system...
Old 07-21-2014, 01:16 PM
  #807
Beachy1968
Beachy1968's Avatar
Now that's what I call an easy to store jet! Very wife friendly!
Old 07-21-2014, 02:09 PM
  #808
lawndartz
Does anyone have a picture of their tail rudder servo installation ? Seams to be a pretty big gap side to side for the servo, wanted to see how people are mounting them or curing this issue.
Old 07-21-2014, 10:37 PM
  #809
Dave Wilshere
I mounted the servo forward, added a 1/8 ply spacer glued to the existing mount to fill the void
Dave
Old 07-22-2014, 06:45 AM
  #810
lawndartz
Dave
Thanks Dave, thats exactly what i wanted to know looks great..
Old 07-24-2014, 06:47 AM
  #811
bistodude
Hi all!
This is my first post on RCU, and I just wanted to share some pictures of my Excalibur. I've been following this forum since the beginning and have taken on board what different people have said. This has been invaluable and I've carried out the additional work people have suggested.
In putting the bubble trap upfront and full of fuel when setting up the centre of gravity at 165mm, I needed 96 grams of weight - which is equivalent to a 4.8 volt battery. So after the test flights I think I will use this battery for landing lights, meaning that in the nose I will have the ECU battery, 2 receiver batteries and also the spare 4.8 battery. This means I won't need any additional weight.
All that remains now is for Dave W to check out the model and test fly for me (as this is my first jet I feel it is worth letting an experienced jet pilot fly it first!)
Shane
ID:	2017093   Click image for larger version
ID:	2017094   Click image for larger version
ID:	2017095   Click image for larger version
ID:	2017096   Click image for larger version
ID:	2017097   Click image for larger version
ID:	2017098   Click image for larger version
ID:	2017099   Click image for larger version
ID:	2017101   Click image for larger version
ID:	2017102   Click image for larger version
ID:	2017103   Click image for larger version
ID:	2017104   Click image for larger version
Old 07-24-2014, 11:06 AM
  #812
Dave Wilshere
Shane
looks good, be a pleasure to check it out for you. Will confirm a free weekend soon.
Dave
Old 07-24-2014, 11:53 AM
  #813
r 3
r 3's Avatar
Dave
Got the engine I think thanks as I have not seen it yet as am stuck out here with fog. How’s my boom coming along?
I see some are using diesel would you recommend this for the P100 and p80se.
Old 07-24-2014, 12:37 PM
  #814
Dave Wilshere
Billy. Good! Get it fitted, hope to be at BD 2nd Sat in August
still waiting on booms
D
no, stick with kero...
Old 07-24-2014, 02:17 PM
  #815
Aussie1
Hi Shane, that's a very neat installation that you have done on your jet! I especially like the colour matching air tanks. You mention landing lights and was wondering what you were thinking of using, and where you may mount them? In my previous post, I have installed lights on my jet and am very happy with the brightness in full sun light, which we get a lot of over here! Good luck on your maiden and your very lucky to have someone like Dave W to do it for you! Just make sure you record the event, because studying the video later can sometimes be invaluable help.
Old 07-24-2014, 02:46 PM
  #816
Beachy1968
Beachy1968's Avatar
My Xcalibur had it's maiden flight yesterday. I'm still getting the feel for it but it I can already tell it's going to be a lot of fun. CG was bang on 170mm with no extra weight needed at all and the only trimming needed was to increase the down elevator with flap. Landing is very straightforward. I'm looking forward to putting many gallons of kero through the Xcalibur over the summer.
Anyway, here are some pictures of the finished model.
ID:	2017169   Click image for larger version
ID:	2017170   Click image for larger version
ID:	2017171   Click image for larger version
ID:	2017172   Click image for larger version
ID:	2017173   Click image for larger version
ID:	2017174   Click image for larger version
ID:	2017175   Click image for larger version
Old 07-24-2014, 10:51 PM
  #817
Dave Wilshere
Mark
Congratulations, looks fabulous-certainly the "bling" install so far :-) (though I too like Shane's painted tanks!!)
The scheme looks great, just needs some of your stickers to busy it up.
Dave
Old 07-24-2014, 11:26 PM
  #818
Beachy1968
Beachy1968's Avatar
Cheers, Dave. Whilst I like to make an installation look clean and tidy I try to avoid unnecessary complication or weight so I was pleased that it balanced without any need for lead anywhere (I followed your example of going for a big ECU battery up front). I'm very pleased with how it flies; capable but very friendly. I just need to reduce the expo to sharpen it up a little to how I like it. Personally, I think I prefer it without the supplied roundel stickers as it's already quite a busy scheme. So yes, it looks great, flies great but the best bit.......it fits with 20l of kero and a folding chair (an essential airfield accessory) in a tiny Renault Twingo!
Old 07-25-2014, 01:30 AM
  #819
bistodude
Hi Aussie1,
Since I'm carrying a 4.8 battery at the front I thought I would put it to good use. Seeing your earlier post about your landing lights gave me the initial idea to use them. I have a kit here already from SM Services and I will be able to control the lights from the transmitter. As the booms are staying on I will be putting the lights in the same place you have them.
I'm very glad Dave is able to help me out with its maiden flight! Our flying site is surrounded on 3 sides by sea water and on the other side there is an oil quarry! It's like landing on an aircraft carrier, so both me and the model have to be 100%!
Mark, congrats on your maiden flight and your very tidy build! I was wondering what vinyl plotter/cutter you used to do your graphics? I've been waiting 6 weeks to have my graphics done at a local shop (maybe they don't want my business!) and I'm thinking it may be easier to do it myself in future.
Shane
Old 07-25-2014, 05:42 AM
  #820
Beachy1968
Beachy1968's Avatar
Bistodude, my plotter is a Graphtec Silhouette Cameo. I've never used it to do vinyl graphics (i.e. stickers) because I just use it to create paint masks, but I believe it can cut any vinyl. Thanks also for the complimentary words on my build/installation. Seeing as I am officially unemployed as of today, if anyone wants someone to build a jet for them then I have plenty of times on my hands!
Here is a quick video of my Xcalibur which was taken yesterday evening. I warn you, however, that it's not the most interesting RC jet video you will have ever seen! As a result of my wife putting her fingers in front of the lens a couple of times, the iPad running out of space half way through and the very difficult light which meant I couldn't see the model, its a bit rubbish!
https://www.youtube.com/watch?v=Wm10K6k1f-w
Old 07-25-2014, 09:07 AM
  #821
flejter1
flejter1's Avatar
Mark,
Be happy your wife was there to put a finger in front of the lens a few times and video'd for you. The alternative could have been her poking you in the chest asking where you have been for the last 5 hrs when you got home from a fun day at the field....
Very clean build and good flight!!
Regards,
Dirk
Old 07-25-2014, 09:30 AM
  #822
Dave Wilshere
A proper WW2 runway...worn out and full of stories!
Nice job though, relaxed on the sticks.
Dave
Old 07-25-2014, 10:46 PM
  #823
Beachy1968
Beachy1968's Avatar
LOL. I assure you I am very grateful that she was happy to video the flight. In fact it was she who was most disappointed about how it turned out but we both laughed about it. My 9 year old boy insisted on also trying to video a flight with my phone which turned out to be mostly clouds but with a nice jet turbine sound track!
Anyway, I'm on holiday now so no Xcalibur action for me for a while. I'll have to be content with pylon racing between the tents and caravans with my UMX Habu :-)
Old 07-26-2014, 12:26 AM
  #824
Jamie C
Jamie C's Avatar
Dave
Smeatharpe certainly does have a lot of history behind it. Much prefer this scheme to the other two, I think Dad should swap his for this one.
Old 07-27-2014, 09:57 AM
  #825
rslstft
My Feedback: (10)
rslstft's Avatar
I had my maiden flight yesterday with my Excalibur and was very happy. It took off very gentle, nice and level and literally flew straight and level, hands off the transmitter, without any trim changes! It has a JetCat P-70 in it and I had to add 4oz (about 113g) of nose weight to get it to balance at about 165mm. Plenty of power as I was at about 3000 ft of altitude and near 100F degrees in temperature. Flew exactly where I pointed it and showed no bad habits at all. I did add more down elevator with full flap that the manual called for (12%) and lowered some of the throws a bit, but other than that, it flew great out of the box. Kept the nose slightly down on landing approach and added a touch of up elevator a couple of inches off the ground for a very smooth landing. The other pilots at the field couldn't believe it was the maiden flight as it was so smooth
I would like to see more airflow around the turbine case, as it got pretty warm, even with some BVM heatproof paint inside the motor area. Also, the brakes are VERY good. I have a separate air tank and limit it's pressure to 50lbs, otherwise the brakes will lock up. I am looking forward to many more fights on the aircraft.
