Jeti-duplex-ds-16-2.4-ghz
#1028
Ok one more question before I order one. Models with power box royal srs and jeti receivers. Does the telemetry work on sensors like the airspeed? It's going in a mibo and there's too many servos to use the jeti central box 200. And which jeti components would I need for this setup?
Thanks!
Thanks!
Hi Chris,
We expect the new Central Box 400 to be released this fall. If you have time in your build schedule the CB-400 would work very well. If not the Power Box will work too but will not be as fully integrated as a Central Box.
#1029
until then, the Cbox 200 has 15 outputs.. 2 of the outputs can double as ext, but you can put an expander in the single Ext port and put as many sensors as you want, leaving 15 full outputs..
Is that enough to do an A10?
For telemetry, I would rig an Mui30 or flow sensor for each motor for sure, unless using a gaspar sensor with his ECU... either will give flameout warning..
#1030
You won't regret it.. its simply a great radio and system..
#1031
#1032
did some flying with single receiver in my phoenix 7 today.. took it up as far as I could see it, and rolled it..as it came down..
looked at the logs.. lowest Sig quality 85%
Lowest signal 7.
Very good.. I was just pushing the limits as far as I could with a single rx.. it was an r7
Lowest signal 7.
#1033
AB, CANADA
Is there a way to program the Telemetry to keep the Top Speed on the screen until the power is cycled or I want it cleared? I don't really have a need to examine the entire flight log and just want to see what my jet tops out at. But of course I'm not going to look at the screen when I'm doing a high speed pass.
#1034
Stand by....
#1035
I'm doing a three part review of this transmitter, you can find part one on my FB page (https://www.facebook.com/TheLittleJetCompany) or Youtube channel (TLJC1). I'm not a distributor or have any affiliation with Jeti and I purchased the transmitter myself.
Cheers, Alex
The Little Jet Company
#1036
Thank you Alex..... Always learning something new....and enjoy sharing the information..
Looking forward to watch your review...
#1037
AB, CANADA
Ok that works with the speed sensor but not with the GPS sensor correct?
Go to displayed telemetry then click 'double' on the airspeed line. You will now get the max airspeed displayed and retained in small font below the airspeed figure. You can clear this by pressing the 'CLR' button or cycling the power although I'll have to check the latter. This is with the Jeti EX speed sensor.
Cheers, Alex
Cheers, Alex
#1039
AB, CANADA
Yes I understand that but it doesn't change the fact it would be nice to see the GPS top speed kept in place until I decide to clear it. I do not like Pitot tubes as they always get damaged some way or the other. The other issue is that the pitot tube can only measure (according to the website) up to 350KPH or 212MPH. We don't have a speed limit in Canada and I am very sure my jet does more than that. So this just won't work.
#1040
I'll let you know once I receive the GPS module but that will be in a week or two. According to the manual which can be downloaded from the Jeti website it retains the min/max values until the next PowerCycle.
Cheers, Alex
Cheers, Alex
#1041
#1042
I can’t see my new R10 EX receiver in the Device Explorer of my DC-16 and I don’t understand why? Pushing the refresh button doesn’t make any difference. Still, the binding seems to have worked and I can control the connected servos. In the Jetibox emulation in the DC-16 the receiver shows up with correct name but not in the device explorer. Both tx and rx has the latest firmware. What shall I do?
#1043
In device explorer your transmitter is looking at the "device folder" on the "SD" card and in your case for "R10 Ex.bin" file . Connect your transmitter to the PC and see if you have that file.. also a small possibility that file is corrupt. From the unzipped 3.0 transmitter firmware upgrade, you can locate that file and replace it with the file on the SD card in your transmitter and try again...
David
David
#1044
My Feedback: (7)
I'm setting up a jet on my DS16 (v3.0) and I have a Xicoy ECU sensor and a Jeti BEC 2D EX setup as JB1 and JB2. They appear to work fine and both display correctly in the telemetry screen, however, each time I power cycle the transmitter and plane, both JB1 and JB2 display TX and a down arrow as if they are waiting to be setup for the first time. I thought I recalled that they were persistent before. Am I doing something wrong or this the way it's supposed to be. I hope it's not the way it's supposed to be because, well, it kind of sucks to have to select them each power cycle :^)
#1045
If you wait a bit the new speed sensor can go to 450 KPH
http://www.espritmodel.com/jeti-tele...ed-450-ex.aspx
#1046
Wayne,
The only time you want to see the Xicoy telemetry in JB1 is if you don't want to use the "System Analyzer" by Xicoy.. Im using the Xicoy telemetry and all sensor will show up and you can select which ones you want to be displayed on your main screen..
And yes each power cycle of the transmitter will reset the Jeti emulating screen...
#1047
My Feedback: (7)
Wayne,
Thanks again
#1048
AB, CANADA
Great Info. I still really don't like pitot tubes but it's worth a shot.
#1050
Thank you, LA Jetguy, for your advice. I checked the transmitter files as you proposed but everything seemed OK so far. I then went on to the receiver and reloaded the firmware and that cured the problem. I am very thankful to all you guys who spend your time trying to help your sisters and brothers in this forum. Happy summer to all of you!
