Reload this Page >
BIG A-5 Vigilante build
Old 04-06-2014, 07:48 AM
jofunk
The Vigilante is bigger and older than the MiG 25. The MiG was/ is a bad ***** plane. There still may be a few flying.
Old 04-06-2014, 07:50 AM
jofunk
***** RCU wouldn't let me type an a with two dollar signs.
Old 04-06-2014, 10:53 AM
Ram-bro
My Feedback: (101)
I knew that. It was a wings episode that brought this info out. Actually imposed the outlines over each other to show tha likeness
Old 04-06-2014, 06:09 PM
jofunk
Here are the available cross sections blown up to the size they need to be. The missing cross sections will need to be interpolated.
ID:	1984818   Click image for larger version
ID:	1984819   Click image for larger version
Old 04-06-2014, 06:21 PM
BlazerB52
My Feedback: (7)
Subscribed. I have the Frankel plans and the fiberglass parts from Fiberglass Specialties. Bought the radome, canopy, intake ducts and exhaust tail and center tail dome as one piece. One day I will build it. Vigilante is my favorite. Tops on my list.
Blazer
Old 04-06-2014, 07:15 PM
  #31
jofunk
Hi Blazer,
If you have any obscure VIgilante info. throw it up here every little bit helps. The mother load of info would be something showing all the cross sections in the plane.
Joe
Old 04-07-2014, 01:51 AM
  #32
BlazerB52
My Feedback: (7)
Will post what I have when I get home this evening.
Blazer
Old 04-07-2014, 12:00 PM
  #33
Ram-bro
My Feedback: (101)
wrong thread
Old 04-07-2014, 02:02 PM
  #34
BlazerB52
My Feedback: (7)
Vigilante site:
http://clubhyper.com/reference/ra5creferencefr_1.htm
http://www.midwaysaircraft.org/Photo..._gallery_3.htm
Old 04-07-2014, 02:35 PM
  #35
BlazerB52
My Feedback: (7)
ID:	1985060   Click image for larger version
ID:	1985061   Click image for larger version
ID:	1985062   Click image for larger version
ID:	1985063   Click image for larger version
ID:	1985064   Click image for larger version
ID:	1985065   Click image for larger version
ID:	1985066   Click image for larger version
ID:	1985068   Click image for larger version
Name:	a3J1 vigilante cockpit.jpg
ID:	1985069   Click image for larger version
ID:	1985070   Click image for larger version
ID:	1985071   Click image for larger version
ID:	1985072   Click image for larger version
ID:	1985073   Click image for larger version
ID:	1985074   Click image for larger version
ID:	1985076   Click image for larger version
ID:	1985077   Click image for larger version
Old 04-07-2014, 02:38 PM
  #36
BlazerB52
My Feedback: (7)
ID:	1985079   Click image for larger version
ID:	1985080   Click image for larger version
ID:	1985081   Click image for larger version
ID:	1985082   Click image for larger version
ID:	1985083   Click image for larger version
ID:	1985084   Click image for larger version
ID:	1985085   Click image for larger version
ID:	1985088   Click image for larger version
Old 04-07-2014, 02:42 PM
  #37
BlazerB52
My Feedback: (7)
Magazine Vigilante build article for Mark Frankel plans.
ID:	1985090   Click image for larger version
ID:	1985091   Click image for larger version
ID:	1985092   Click image for larger version
ID:	1985093   Click image for larger version
ID:	1985094   Click image for larger version
ID:	1985095   Click image for larger version
ID:	1985096   Click image for larger version
ID:	1985098   Click image for larger version
ID:	1985099   Click image for larger version
ID:	1985100   Click image for larger version
Old 04-07-2014, 02:49 PM
  #38
BlazerB52
My Feedback: (7)
Cross sections came from here: http://tailspintopics.blogspot.com/2...vigilante.html
Old 04-07-2014, 03:40 PM
  #39
BlazerB52
My Feedback: (7)
Plans
File Type: pdf
File Type: pdf
Old 04-07-2014, 04:31 PM
  #40
jofunk
Hi Blazer,
Thanks for the contribution to the thread. That is some great info. It is nice to have it here for quick reference.
Joe
Old 04-07-2014, 04:44 PM
  #41
BlazerB52
My Feedback: (7)
Your welcome. I have looked for a long time for everything I can over the years. Not a lot out there compared to other aircraft.
Old 04-07-2014, 04:50 PM
  #42
BlazerB52
My Feedback: (7)
Vigilante parts from Fiberglass Specialties for the Mark Frankel plans. Canopy is around 22 inches long. Marble top is 51 inches long for reference. Parts are of good quality and would recommend them.
ID:	1985141   Click image for larger version
ID:	1985142   Click image for larger version
ID:	1985143   Click image for larger version
ID:	1985144   Click image for larger version
ID:	1985145   Click image for larger version
Old 04-07-2014, 07:42 PM
  #43
jofunk
It is interesting to see the fiber glass rear end. I think it confirms my suspicion that Mark Frankel and Phil Nuckles had to cheat a little on the rear end. The area between the exhaust is reduced to make the openings larger for the ducted fan exit. The shape on these plans look like a sub hunting antenna. The top view should be triangular in shape, with the exhaust openings being smaller………I have the plans hanging on the wall. I pinned some balsa on the plan outline of the vertical stab and glued the sticks together. I can then trace it on a block of foam to cut the stab.
ID:	1985211   Click image for larger version
ID:	1985212   Click image for larger version
Old 04-08-2014, 10:52 AM
  #44
mr_matt
My Feedback: (10)
mr_matt's Avatar
Cool project. be careful as I have found drawings online with cross sections that did not loft correctly. Bad to find that out too late in the process.
Another option is to cut up a model into cross sections and scan it them.
Old 04-08-2014, 01:56 PM
  #45
jofunk
Hi Matt,
I agree. Even holding these cross sections up to the plan view leaves a lot of questions. I talked to Bob at Bobs air documentations. He has 3 three views available with cross sections. If I buy all three he said I could come up with 16 cross sections. But like you said they may not jive. The trumpeter kit is an $80 plastic model, but I don't own it. Cutting it up is a B1 Bob trick. It probably isn't a bad idea……….I taped the plans together and See Temped the wing root airfoil. I have yet to find the wing tip airfoil on the print. Everyone feel free to look for it. Let me know when you find it…... I also glued some sticks together to come up with the wing plan view template. I also See Temped a side of the drop tank for future reference.
ID:	1985324   Click image for larger version
ID:	1985325   Click image for larger version
ID:	1985326   Click image for larger version
Old 04-08-2014, 03:49 PM
  #46
mr_matt
My Feedback: (10)
mr_matt's Avatar
Cool. What do you need the wing planform stick figure for?
You could always find an off the shelf airfloil that is close to that one and just use the same airfoil for the tip. Does it call for any washout? If not add 1-2 degrees of washout and input the wing on this website and get the cores done:
flyingfoam.com
Old 04-08-2014, 05:18 PM
  #47
Ron S
Ron S's Avatar
Along with Matt, I've also found sets of 3-views where the cross sections do not loft properly. Double check! I've also used flyingfoam in the past, and was very happy with their service. Here are some pics from Pax River, MD (Naval Flight Test Center) I took back in Nov 2013.
ID:	1985367   Click image for larger version
ID:	1985368   Click image for larger version
ID:	1985369   Click image for larger version
ID:	1985370   Click image for larger version
ID:	1985372   Click image for larger version
ID:	1985373   Click image for larger version
ID:	1985374   Click image for larger version
Old 04-08-2014, 06:10 PM
  #48
jofunk
Hi Matt,
The plan view stick outline is for tracing the plan view on a foam block. I don't know if it calls for any washout but I will put some in when I cut the cores. I was going to cut each panel in two sections because there is a step in the TE at the tip. As far as the wing tip airfoil,I will find one somewhere, but you would think it would be on the plans………..Ron, those are some nice pictures. It is amazing to see what documentation people have collected.
Old 04-08-2014, 09:40 PM
  #49
mr_matt
My Feedback: (10)
mr_matt's Avatar
give 'em hell jofunk....are you cutting old school with a bow? Feathercut? I tell you these new CNC cut cores are just amazing, and no polishing templates required!
I remember ogling that Frankel Vigilante when I was a teen. There were very few fully ducted DF plans ever published, much less a twin. Then years later I got to spot for Mark Frankel at Florida Jets. He had his new turbine Skyray.....what a treat.
BTW why not just blow up the Frankel plans...not scale enough? Does he have washout?
Old 04-09-2014, 03:30 PM
  #50
jofunk
Hi Matt,
I am going to cut the cores with a bow. I enjoy doing it…... I was at Top Gun in the early 90s and Mark Frankel had a string of DF powered Skyrays. He wasn't having a good day. Good thing he had more than one. Everyone that flies a Hotspot or a Kangaroo etc. should be flying a Skyray, and be scale. I don't go to many jet rallies but when I do I get bored fast watching sport jets. The landing gear need to be stuck retracted or something needs to be falling off of them to get me to watch them fly. The flat top Vigilante (the Frankel plan) Is the plane I wanted to do originally. It has an attractive 60s look to it. Frankels Vigilante is less scale but things can be changed to make it more scale. I ordered all the 3 views for the Vigilante from BoBs Scale documentation. We will see what shows up. Frankel's Vigilante plans show all the airfoils with 2 degrees of washout in the wing tip.
