Elite Aerosport Shockwave is here!!!!
#51
I am about to start the build on the Shockwave. I've attached pics of the included hardware, which is top self. Here's myequipment list:
Servos:
Futaba BLS172 x 7
Futaba BLS175 x 1 (nose gear)
Robbe power unit
Gyro:
Cortex
Arms:
SWB aluminum arms
Receivers:
Futaba 6202SBW x 2
Batteries:
Duralite Sentinel 3000 Lithium Magenese x 2
Turbine:
Behotec 220
Servos:
Futaba BLS172 x 7
Robbe power unit
Gyro:
Cortex
Arms:
SWB aluminum arms
Receivers:
Futaba 6202SBW x 2
Batteries:
Turbine:
Behotec 220
#53
Dantley,
I'm really interested in how you are going to use the Cortex with your Sbus setup? When I enquired about this over on the Cortex/Bandit thread I was told there is no option for serial data in, serial data out on the Cortex.
I'm assuming that you will be using an Sbus setup given the equipment you are using.
Malcolm
Malcolm
#55
Malcolm, I will be using a traditional setup for the servo leads, which is how I'll get the gyro to work.servo set-up if the Robbe/Cortex unit do not work for me, I'll use a Power Box with iGyro.
Here are pics I took of the Shockwave during daylight.
#58
Thanks Dantley, I have the same servos/Robbe power unit wired Sbus in my Skymaster Hawk and would really like to be able to add a gyro.
Thought you had solved it for me!
Malcolm
Malcolm
#60
My Feedback: (57)
I've just started using sbus (two airplanes) and a Cortex in a non-sbus application (Shockwave), but have been thinking of a way to use the Cortex in an sbus equipped plane. Just thinking out loud.
#61
Good try George, but it doesn't help a lot in my install. I have two 3 channel Sbus receivers plugged into the Robbe power unit which outputs Sbus to all the flying services and pwm to ECU, brake and gear valves, etc. I really need to take the serial data from the power unit into a gyro and then output it back to the servos.
Malcolm
Malcolm
#62
My Feedback: (57)
Ah 3 Ch. RXs, you're right Malcolm, that won't work in your set-up!
Then how about adding two SBD-1s and a hub between the Cortex and RX? Again, this is just a "work around", and is definitely not ideal, but you'll have Sbus on both sides of the Cortex; and until it can handle serial data, I don't see any other way.
#63
Not too sure what happens when you try and mix two serial data streams. The Robbe box "decides" which stream to pass to the servos based on signal strength. I think this model is gonna fly gyroless until a suitable device appears.
Malcolm
Malcolm
#66
Ya guys, the cortex won't OUTPUT serial data.. only decodes it and passes it to channels A-E servo output, plus one aux pass thru output..
We mentioned this to the captron lead for future consideration
Yes, don't cross serial streams without a traffic controller.. You know what happens when you cross streams.. "ghost buster"..
#67
I am considering abandoning the Cortex/Robbe set-up and going with a PowerBox Royal SRS with iGyro built in. Seems to be the path of least resistance to get a 3 axis gyro integrated into the plane. In terms of progress, the Shockwave build slowed down while I wrap up some final details on my Skymaster F-104 (was waiting for a light kit). I'm planning to jump back on the Shockwave next week.
#73
Congrats with a great plane! I LOVE your scheme! :-D
I want one myself!
A rookie question: Why do you, great skilled jockeys, use gyro on these sport planes?
Looking forward to the rest of this tread! :-)
I want one myself!
#74
Primarily to smoothen out the flight. Gyro assistance really helps during bumpy wind conditions.
Pablo
