Reload this Page >
skymaster pc-21
skymaster pc-21
Old 07-31-2016, 05:37 AM
  #276
argyris
argyris's Avatar
Here some photos from the smoke installation injectors.This is the most logical point for injectors but for the moment and after some test we haven't found the correct flow get.To much flow splash the aircraft with unburned smoke oil.We thought to reduse the flow and to push deeper the injector for more warm oil.
ID:	2175162   Click image for larger version
ID:	2175163   Click image for larger version
ID:	2175164   Click image for larger version
Old 07-31-2016, 08:30 PM
  #277
helifox
helifox's Avatar
Argyris, thank's a lot!
One more question:
Where you take your exhaust pipes? Our pipes what we received with Pilatus are looks different
Or it's a hand made production?
ID:	2175361   Click image for larger version
Old 08-01-2016, 12:12 PM
  #278
argyris
argyris's Avatar
Dear Sergey Mich supplied the exhaust pipes from Jetcat.
Old 08-03-2016, 08:21 AM
  #279
Fireflynightshift
Fireflynightshift's Avatar
Hi Argyris.
Thanks for the post with the smoke system. Can you maybe put some pics on of your pump installation and what size tank did you use for the smoke.
Also do you perhaps some videos to upload of the smoke system in the working please.
Have a great day
Regards
JB
Old 08-04-2016, 07:30 AM
  #280
Fireflynightshift
Hi All
What size hole did you chaps cut in the intake to vent onto the gearbox.
Have a great day
Regards
John
Old 08-04-2016, 11:39 AM
  #281
helifox
helifox's Avatar
Hi John,
We did't cat any extra holes in the intake, standart more then enough. More important to care of engine cowl heat protection. Few post up I showed how we done that (#232).
Kind regards,
Sergey
Old 08-04-2016, 01:33 PM
  #282
Fireflynightshift
hi Sergey
Yes I have the heat shielding on the top cowling, no problem there. Was just wondering if any of you chaps have cut opening in the intake like post #140. Thanks
Have a great Day.
PS anybody with a video of smoke system working Thanks
Old 08-04-2016, 02:12 PM
  #283
helifox
helifox's Avatar
That is modeling, many ways to find one best result.
There is no problem like overheating with stock size halls in our PC. Probably it can be if use higher power turbine (not sure), we use K-60tp.
About smoke system- Mich posted video with test, #252
Kind regards,
Sergey
Old 08-04-2016, 02:42 PM
  #284
argyris
argyris's Avatar
Here is the test video with smoke.
https://www.youtube.com/watch?v=An93toadmp8
Old 08-04-2016, 03:11 PM
  #285
argyris
argyris's Avatar
Mitch has made one permanent air flap 2--2.5 cm wide with fiberglass.With this flap drive more air on exhaust and gear.
Old 08-04-2016, 11:12 PM
  #286
In the Haze
In the Haze's Avatar
Originally Posted by Fireflynightshift
hi Sergey
Have a great Day.
John are you having a heat problem down there? I am going to do the small mods as seen here right from the outset I reckon.
Old 08-05-2016, 03:31 AM
  #287
Fireflynightshift
Hi Neville
No, no overheating at all. I have put a similar hole in the bottom like post #285 from the start with a little flap to divert the air. This aircraft flies so nice and true. Post some pic of your please.
Have a great day.
Regards
John
Old 08-05-2016, 04:29 AM
  #288
In the Haze
Kit yet to be delivered, One day when it's done.........
Old 08-08-2016, 01:07 AM
  #289
argyris
argyris's Avatar
One new onboard video from Michael's Pilatus pc-21
https://www.youtube.com/watch?v=pEd1kGZjiuc
Old 08-08-2016, 04:16 AM
  #290
argyris
argyris's Avatar
https://www.youtube.com/watch?v=upv_NkPsLvY&feature=youtu.be
Old 09-04-2016, 11:27 AM
  #291
mich-67
mich-67's Avatar
Default skymaster pc-21
i have go ahead replace the stp-5 with the new JETCAT STP-10 with 9KW power !!!
looking forward to fly my plane with this New power.
ID:	2179546   Click image for larger version
ID:	2179547   Click image for larger version
ID:	2179548   Click image for larger version
ID:	2179549   Click image for larger version
ID:	2179550   Click image for larger version
ID:	2179551   Click image for larger version
ID:	2179552   Click image for larger version
ID:	2179554   Click image for larger version
Old 09-22-2016, 05:32 AM
  #292
pilot tw
https://www.youtube.com/watch?time_continue=339&v=t1HcilAvge0
Old 09-28-2016, 12:19 PM
  #293
argyris
argyris's Avatar
Some new photos from 25-9-2016 at Dounis Airfield with the new setup in Pilatus PC-21 and JETCAT SPT-10 new engine!!
Amazing speed !!Amazing 7 new flights with Peter Dounis and Michael Leoutzakos !!
ID:	2183171   Click image for larger version
ID:	2183172   Click image for larger version
ID:	2183173   Click image for larger version
ID:	2183174   Click image for larger version
ID:	2183175   Click image for larger version
ID:	2183176   Click image for larger version
ID:	2183177   Click image for larger version
ID:	2183179   Click image for larger version
ID:	2183180   Click image for larger version
ID:	2183181   Click image for larger version
ID:	2183182   Click image for larger version
ID:	2183183   Click image for larger version
ID:	2183184   Click image for larger version
ID:	2183185   Click image for larger version
ID:	2183187   Click image for larger version
ID:	2183188   Click image for larger version
ID:	2183189   Click image for larger version
ID:	2183190   Click image for larger version
ID:	2183191   Click image for larger version
ID:	2183192   Click image for larger version
ID:	2183193   Click image for larger version
ID:	2183195   Click image for larger version
ID:	2183196   Click image for larger version
ID:	2183197   Click image for larger version
ID:	2183198   Click image for larger version
ID:	2183199   Click image for larger version
ID:	2183200   Click image for larger version
ID:	2183201   Click image for larger version
Old 09-28-2016, 12:22 PM
  #294
argyris
argyris's Avatar
And one onboard video .New spectacular flight video is on the way soon!!
https://www.youtube.com/watch?v=TUqd-o3xOfo
Old 10-01-2016, 04:26 AM
  #295
argyris
argyris's Avatar
And the video from 25-9-2016 !!!!
https://www.youtube.com/watch?v=ay9yk1s1dqk
Old 10-01-2016, 04:59 AM
  #296
Eddie P
Eddie P's Avatar
Amazing performance! Looks and sound so great.
Old 11-03-2016, 06:04 PM
  #297
pilot tw
maiden yeaterday
https://www.youtube.com/watch?v=OcEN_162lFk
Old 11-03-2016, 06:05 PM
  #298
pilot tw
https://www.youtube.com/watch?v=yPtQhBkhNDY
Old 11-04-2016, 02:02 AM
  #299
David Jackson
My Feedback: (15)
Are you using the Kingtech 100 turboprop unit in your PC-21?
Old 11-04-2016, 03:43 AM
  #300
pilot tw
my PC-21 powered by K-60TP
