Carf - Models J-10 build thread
#251
Have a CARF J-10 with K210 motor. Keep getting a flame out when doing Flat spins. If spins are kept gentle all is OK. No air in UAT. Debating if there is a Turbine inlet air problem others may know about?? Seen some J10's online with large air holes cut out of tail cone.
Thanks in advance.
Thanks in advance.
#252
My Feedback: (21)
Flat Spins
I like to do flat spins . I don’t spin real fast and I have not had any engine issues. I don’t know how much time is on your engine but you might have worn bearings. The gyroscopic loads on turbine bearings are much higher in thrust vectoring aircraft. I have my bearings changed at 12-14 hours instead of the usual 25.
I can say that intake air flow is not the problem unless yours is somehow obstructed.
if you can hover with no issues then your intake air flow is fine.
#253
K210 is new less than an hour on it. Can hover the the J10 with no flame out issues. Positive and Negative flips No issues, Just moderate speed flat spins and she flames out. IF its not an air intake into turbine issue and there is no air in UAT, nor fuel leaks down stream of pump, maybe I need to start looking at wiring issue??
NOTE: 3 Flame outs in 6 flights and the K210 has auto restarted every time before I ever made it to the runway. I either kept flying or at least did full pattern approach before landing under power.
#254
My Feedback: (31)
J-10
Flew mine on a JC P-180 and did plenty of spins and never had an issue. I do have a couple of KingTechs in two other jets and one of the things I noticed that bothers me about the system connection is the cable leads into the ECU. They have a lot of side-to-side play after connection. I’ve not had any issues but maybe there could be A greater potential for intermittent connection when doing the spins?? Just a guess. Sounds like your fuel system is OK. What kind of UAT are you using? I had a BVM UAT in mine.
#258
FWIW, Like Ken I found the servo lead connections to my King Tech ECU to be very loose. One thing I have done (starting with my helis, which have high G, loads years ago) is run a bead or blob of hot melt glue along the ECU case top and servo type plugs. Don't get it into the case! It just holds everything together and is easily peeled off for service. It's nice that the KT ECU is metal cased because that trick can damage the stickers on some case tops.
#264
My Feedback: (53)
While I normally used MKS, this time around I choose to try the Jeti Ditex TD 2612S servo’s all around except for the Steering....I’m curious to see the result (torque amps ect) via telemetry...
if it doesn’t work out I can always replace them with MKS......the 599 should be great they are powerful and fast.
this is my scheme...
#265
WI
Thanks for the servo suggestions j10’ers. I have to say I am partial to MKS or Hitec. ( I’ll check out the MKS599 shortly).
As for scheme, I went conservative with the Display scheme. A few well placed decals should pretty her up sufficiently.
My initial plan of attack: Cortex Pro,Powersafe RX, Kingtech 210 and an Intairco UAT. Suggestions always welcome.
TIA
Robert in Milwaukee
jet fleet:
TopRC ODyssey KT160
Boomerang Elan KT80
TIA
Robert in Milwaukee
jet fleet:
TopRC ODyssey KT160
Boomerang Elan KT80
Canadian Man (08-20-2020)
#269
My Feedback: (53)
Speaking of painted nozzles; this realistic paint work was done by Ozzie, owner of Ozaero Custom Designs:
#270
WI
Ok, I just spoke to my local J-10 buddy. For the past 2 seasons he has been running MKS HBL380 servos all around ( except for the nose gear). Im leaning towards the same.
Rbt
Rbt
#271
My Feedback: (53)
When I select servo’s I always try to put thing in perspective.....this is what the original J-10 designer used back in the days...yes the 380 would work fine
J-10 from Elster
Aileron Futaba 452 mg 6v 194oz. 0.14
Rudder Futaba 3071 7.4v 146oz 0.17
Canard Futaba 451 mg ....6v 147 oz 0.10
Vector Futaba 451 mg
J-10 from Elster
#273
J10 JR TX Radio setup
Preparing the things for my new PilotRc J10B turbine aircraft equipment will be;
Pilot rc new J10B aircraft
KingtechK210 turbine
JR HV servos all around
powerbox igyro3e gyro
powerbox evolution power unit
I am experienced pilot both bulding and flying , been flying over 30 years but this will be my first jet and first delta wing vector thrust plane. I do not know how to setup my radio for this plane ,
I am a JR fun and has JR new 14X4 dmss 14Ch TX.
How should I go to setup this delta wing plane? I mean via TX software or via Gyro software?
If tx software where should I connect canard servo? thrust vector servos? which mix should I adjust etc etc.
or anyone using JR TX for this plane could send me his TX setup
thks
thks
#274
WI
Shipping via Old Dominion from California to Wisconsin was about 4 days and the boxes were in excellent shape.
Robert in Milwaukee
#275
My Feedback: (53)
I had all the rest of the parts in mine...except those rods......CARF didn’t want to send them....so they give me a credit instead, actually hard to source, I got some on the way will see how they fit...also Ray sent his from a damage J-10.....will see if that box survive the trip to Canada...
