Reload this Page >
Carf - Models J-10 build thread
Old 10-21-2014, 08:10 AM
dubd
dubd's Avatar
Thanks for posting this as a reference. Any idea when a manual will be available?
Old 10-21-2014, 08:38 AM
lavi rider
Not sure .
Old 10-21-2014, 10:53 AM
dbsonic
dbsonic's Avatar
saw this fly at BITW. I'd say it was the wildest flying jet there.
Old 10-21-2014, 11:56 AM
lavi rider
Yeah , the CARF J-10 is prety wild....
Old 10-21-2014, 02:27 PM
3dean
can anyone give set up details for the vector thrust, gyro,servos etc also are the flying surfaces gyro'd
thanks
Old 10-21-2014, 05:39 PM
  #31
husafreak
husafreak's Avatar
I believe they are using the JR DS8711 or 8911 servos on the CARF J10 that CARF flew at BITW.
Old 10-30-2014, 03:53 AM
  #32
snobird
My Feedback: (36)
snobird's Avatar
Just started my J-10 build. Installing the tumble tube . I received two long carbon rods, one short tube and one metal tube. not long enought to reach the tumble tube. ? I'm I missing something here ? Help
Old 10-30-2014, 05:57 AM
  #33
jetpilot
My Feedback: (48)
jetpilot's Avatar
https://www.youtube.com/watch?v=eu86...&feature=share
https://www.youtube.com/watch?v=eu86oZx3sUE&feature=share
Old 10-30-2014, 06:18 AM
  #34
afterburner
My Feedback: (18)
afterburner's Avatar
What's in there for power Scott?
Old 10-30-2014, 06:43 AM
  #35
Airforce7
My Feedback: (31)
Airforce7's Avatar
The J-10 was designed specifically for the JC P-180. When I looked over CARF's J-10 at BITW the two long carbon rods had the 3mm threaded rods glued to the ends in order to reach the servos and thrust vectoring tube. The threaded rods connecting to the thrust vectoring tube were bent following the profile of the turbine and connecting to the tube via ball links. They added shrink tubing around the glue joint overlapping the two rods and inch or two which was directly over the middle of the turbine to protect from heat. They have a picture of the turbine mounted to the rails and linkages in the latest CARF catalog. I can take a picture of it and post here if that helps. I have the kit and plan to start building it soon. I just received the gear yesterday. Main tires are 4.5 inches in diameter.
Old 10-30-2014, 08:12 AM
  #36
snobird
My Feedback: (36)
snobird's Avatar
Hi, Airforce7. Can you tell me if the kit contains 4 rods, I only have two and without extensions are not long enough.
Old 10-30-2014, 10:32 AM
  #37
Airforce7
My Feedback: (31)
Airforce7's Avatar
I will check tonight. Here is the photo from the catalog...
Old 10-30-2014, 10:55 AM
  #38
snobird
My Feedback: (36)
snobird's Avatar
Old 10-30-2014, 06:05 PM
  #39
rrembert
Should have two long and two shorter ones...also a piece of tubing that covers the joint of where the two are connected. PM me your email and I'll send you what I got instruction wise from Germany.
Bob
Old 10-30-2014, 06:47 PM
  #40
dubd
dubd's Avatar
Ken, let's compare build notes as we go. I just received my gear too.
Old 10-30-2014, 10:09 PM
  #41
Airforce7
My Feedback: (31)
Airforce7's Avatar
OK I checked my kit for the rods and this is what I found.
List of Rods:
2X ~39.5" Long
2X ~15.75" Long
1X ~12" Long (metal)
List of Packs:
Fin
Wing
Canard
Engine Mount
Fuselage
Landing Gear
Hatch
Canopy (empty bag, hardware installed already)
Thrust Vector Tube
Nose Gear Pack
See pictures attached.
Looks like the two long and two short need to be connected together and the metal rod is used as a sleeve like Bob mentioned. The thrust vector tube pack has six threaded rods in it, which I believe are used to connect all the rods together to make the two push rods from the servos to thrust tube.
ID:	2043578   Click image for larger version
  #42
Selcuk
Share your building process here, if possible with photos please. My kit is on the way.
Old 10-30-2014, 10:10 PM
  #43
Airforce7
My Feedback: (31)
Airforce7's Avatar
You bet!
Old 10-31-2014, 03:10 AM
  #44
snobird
My Feedback: (36)
snobird's Avatar
I see what's happened. , I'm missing the a small rod. I have a few pictures from a friend of mine. I'll send along
Old 10-31-2014, 10:58 AM
  #45
Meesh
My Feedback: (135)
Meesh's Avatar
Dave,
Can Jim help you out?
Bob
Old 10-31-2014, 12:05 PM
  #46
snobird
My Feedback: (36)
snobird's Avatar
Hi, Bob, yes talking to him, he built two but both put away for the winter. He has a memory like mine you know short
Old 11-02-2014, 02:22 PM
  #47
Tint
Hi Airforce7
You have to split the metal one in two parts and use them as connector (long carbon - metal - short carbon). Do you have the unofficial manual?
http://www.elsterjet.de/Downloads/Bauanleitung-J10.zip
Martin
Old 11-02-2014, 09:36 PM
  #48
Airforce7
My Feedback: (31)
Airforce7's Avatar
Hi Martin,
Thanks for the link to the manual and the detailed description of how to connect the push rods for the tumble tube. This will likely be my next step with the kit.
Old 11-02-2014, 09:54 PM
  #49
Airforce7
My Feedback: (31)
Airforce7's Avatar
Goals for the weekend were to get the canard, fin and gear completed. See photos. Word of caution, when working with the bottom cover off to get the gear installed be careful not to poke your self against the sharp edges. I put some foam on the tips to protect my skin and eyes while I did a trial fit of the main gear.
I need to make some small adjustments to the right main gear. Two or three washers to act as a shim should help get the gear to be in line with the left side when retracted. Also the opening for the nose wheels is a bit to small, I'll Dremel the opening a bit larger next chance I get.
Lastly, I fiddled with the linkage for the rudder quite a bit and ultimately needed to open the slot about a 1/2 inch towards the front to get the push rod to work right. I added a carbon fiber sleeve over the 3mm rod to give it a bit more strength. I also put the link on the top side of the rudder horn, which seemed to be the better option for me.
ID:	2044477   Click image for larger version
ID:	2044478   Click image for larger version
ID:	2044479   Click image for larger version
ID:	2044480   Click image for larger version
ID:	2044481   Click image for larger version
ID:	2044482   Click image for larger version
ID:	2044483   Click image for larger version
ID:	2044485   Click image for larger version
ID:	2044486   Click image for larger version
Old 11-03-2014, 05:11 AM
  #50
snobird
My Feedback: (36)
snobird's Avatar
Ken, could you e mail to me the elsterjet manual.can't open the one listed above, have you checked the pictures on their Facebook page ?
