First Impression of new I gyro 3E ( Flying )
#201
My Feedback: (39)
I guess there is no concern with the SRS powering servos off a single power lead vs dedicated lines for the 3e? As I understand for Jeti purposes I can connect one of the bus outputs to one of the EXT ports in on say a REX10 receiver. I am still free to use that same receiver for throttle, gear, etc... One bonus of the SRS is since the flight surfaces are going through the EX bus I would be free to use all the channels of the RX for other stuff. So I could actually get 15 channels with only a 10 channel receiver. At least that is how I understand it.
Thomas
#202
I just ordered an SRS with the GPS, etc... Along with the iOS Bluetooth adapter. I am curious for any of you Jeti users - Does the telemetry for the GPS II unit show up displayed like the MGPS unit? And if so can you trigger events based on a given value same as the MGPS? In my test plane I already have an MGPS so if it is going to be redundant I can pull it and move to another airframe.
#203
My Feedback: (39)
Thomas
#204
Jeti EX BUS: alarms can be entered both at the GPS II and at the transmitter.
Jeti EX: Connect the sensor directly to the receiver’s EXT input. If you wish to connect multiple sensors, you will need an “Expander E4 EX”. The data to be displayed is selected at the transmitter.
From a stand alone perspective based on descriptions above it should work. The real question is will it carry through out the Bus of the SRS to the EXT of the Jeti Rx? I guess I will find out next week.
#205
My Feedback: (39)
Just checked http://forum.powerbox-systems.com/viewtopic.php?f=42&t=2345 , somebody asked the same question there. The answer was that it doesn't work with the iGyro, only the Powerbox Royal SRS can provide telemetry data.
#206
#207
My Feedback: (34)
Anyone have a 3G gyro in their Shockwave and what were you gains set at? Also did you use HH at all?? I have the bluetooth module but noticed that on a 3 position switch the middle would be off, Back would move the slider to the Blue side Rate mode and foward to Red Heading hold. Is there a way to re arrange this switch positions so back is OFF , middle flight gains and full forward landing?? No heading hold??
