Reload this Page >
New big Ripmax Xcalibur (Xcalibur+)
Old 10-26-2015, 05:36 PM
  #326
roalddogge
Well, mine is almost finished and ready for maiden
I am quite happy with the outcome although I found some issues. I was looking for a large, reasonable goodlooking sportsjet which could accommodate both my 120N engine as my P160SX. I went for the Xcalibur because it breaks down in small pieces and makes owning and working on a large plane, while living in an apartment, doable.
First the good news:
  • The plane looks great. I am not really a big fan of boomies, but this one is really a nice looking plane
  • Overall design is very good. Lots of attention to details. Material where it needs to be but at the same time not too heavy.
  • Decent quality of accessories and hardware. More than adequate to fly out of the box.
  • Especially wood parts (wings, booms) are well built
  • No fitting issues of pipes as reported by some. It fits tight but ok
  • Weight is very good with 14.1 kg with full UAT and cg @ 195mm
Negatives:
  • Quality and finishing of fiber glass parts was not great. Needed quite some fixing and painting to make it look decent
  • Glueing of the formers in the fuse was a joke. The person handling the glue gun was either blind or drunk or both. Most of the glue applied was not doing anything
  • Radio plates were bent like a banana
  • Pushrod for aileron is not perpendicular to hinge line. When using the supplied hardware this requires the horn to deform a bit. The horn is too soft for using a ball link. Not a big issue but there are more elegant solutions
  • Manual is very good, but does not show which screws/bolts go where. As there were some other screws supplied then shown in manual this was a bit puzzling
  • Plane builds very tail heavy. I am using a Jetcat P160RX, which is actually lighter than P140RX (as valves and pump separated and placed forward of cg). Also the used servo’s are heavy, BLS157HV, but still having to add 380 grams of lead next to large batteries is a bit too much.
  • It is difficult to find other landing gear than the one offered for this plane. The mounting points are such that basically no other set will fit. I wanted to go for electrics and was at the end forced to make some carbon adapter plates.
Overall the impression is very good and I am looking forward to the maiden.
I attached some pics and will make a few more the coming days
Ro
ID:	2127811   Click image for larger version
ID:	2127812   Click image for larger version
ID:	2127813   Click image for larger version
ID:	2127814   Click image for larger version
ID:	2127815   Click image for larger version
ID:	2127816   Click image for larger version
Old 10-26-2015, 05:40 PM
  #327
RENO
My Feedback: (17)
Hey George,
Thanks for the heads up! I am powering mine with a JetCat 140 RXI. The canopy idea is brilliant as usual for you.
May God continue to bless you.
Skeet
Old 10-27-2015, 01:21 PM
  #328
Reever45
My Feedback: (16)
Did maiden and 5 more this weekend, mine is powered by a JetCat 180 RXI. I have a 3s 3800 LifePo for ECU and 2 2s 5000mah rx lipo's and i still needed 9 oz of lead in the nose, and according to my Xicoy cg machine it is 30.3lbs dry. Flys really good though
Old 10-27-2015, 02:58 PM
  #329
Dave Wilshere
You can add 2lb of lead to the nose and it would still be light for a 92" jet!
Trying to remember how much lead I had in the nose of my Torus-think it was 3lb and overall 37lb! Still flew well...
Old 10-27-2015, 05:27 PM
  #330
roalddogge
I do agree that the plane is very light for its size. Even with the 380 grams added the final weight is just a hair over 14kg, which is great.
Earlier I was a bit too optimistic about the fitting of the tubes. When I finally fully assembled the plane it turned out too tight in some areas and also one anti-rotation tube was not aligned. After quite some sanding it finally fitted. Obviously the planes are not test assembled before shipping.
For the rest it is ready for maiden, lets just hope that the weather improves over the weekend......
When I assembled it in my living room I realized how big it actually is.....
Old 10-29-2015, 04:35 AM
  #331
Dave Wilshere
We have had an instance in the UK where one of my customers tank plate came unglued during negative G. his flight pattern included quite a lot of flicks and outside loops.
Looking at the plate we think its peeled off from the rear end where the strap goes around. The factory are going to install a wooden block either side of the velcro strap to tie the plate to the fuselage base and also thicken the plate to be doubly sure.
I saw a couple of smaller versions have loose plates from the factory in the early days, but they seem to have sorted that. My Plus had plenty of resin bonding the plate, but I did add hysol before painting.
Anyway, its worth a check if you like negative stuff, its a big tank with lots of weight.
Dave
Old 10-29-2015, 08:53 PM
  #332
br1anj
Well, I've finished the build, tested all the systems on it to make sure everything is fully functioning. This is the first Jet I've ever built. I tried to keep all the installs nice and clean so it got a little crowded up front but I was able to get away with only adding about 3 oz. of lead in the nose to get a really good balance just back of the manuals recommended balance point. By just back I mean about 5mm back of the recommended spot. It should be just fine. Hopefully if the weather cooperates I'll get to put the maiden on it next weekend. Come on nicer weather!
ID:	2128366   Click image for larger version
ID:	2128367   Click image for larger version
Old 11-02-2015, 08:07 PM
  #333
RC-Ken
My Feedback: (29)
25 Flights now and she is doing great! Great flight characteristics, excellent performance fast and slow and easy smooth landings. Here is some video https://www.youtube.com/watch?v=Z-J2...ature=youtu.be
Old 11-05-2015, 09:38 PM
  #334
Global Jet Club Asia
More Features Of This Jet Can Be Found Here
Available Schemes
(In Stock, Act Soon before they are back ordered)
ThunderBird Scheme
Click Here! Order now for $1999. Use promotion code GJCXP1234. Promotion is valid until 12/31/2015.
Union Jack British Scheme
Click Here! Order now for $1999.Use promotion code GJCXP1234. Promotion is valid until 12/31/2015.
[HR][/HR]For any questions about your order or this special offer please email us at [email protected] or call 1-951-514-2988 extension 210 or 1-866-959-6888 (Toll Free, US Sales Only).
We accept Visa, Mastercard, Discover, American Express, and Paypal.
Payment can also be made by pre-paid check or wire transfer.
©2015, Global Jet Club, Inc.
No combination with other discount. All prices, pictures and descriptions are subject to change. Global Jet Club maintains no responsibility for inadvertent errors.
Old 11-07-2015, 06:16 AM
  #335
gmccluskey
For those that have had alignment issues, how did you fix the problem?
Old 11-09-2015, 04:11 PM
  #336
RENO
My Feedback: (17)
Hi Dave, on your receiver accessory board, (the black box with six attaching screws,) do the multiplex plugs receive power from the receiver batteries
then power the receiver through JR plugs?
Skeet
Old 11-09-2015, 07:37 PM
  #337
br1anj
I simply sanded/dremeled the wing root out until the tube fit. I actually went through part of the plastic alignment tube on the inside of one of my wings but unfortunately it was necessary to get the wing to fit properly. I opted to work on only the wing vs the fuselage and the tail boom. No problems as of yet.
Brian
Old 11-09-2015, 07:45 PM
  #338
br1anj
Flew the Plus yesterday for the Maiden and 4 additional flights. It was my first jet experience. Take off to landing was very smooth with no unusual events taking place. Used only a few clicks of elevator trim at first which I then pulled some out once the tank started to empty. Ailerons only took 2 clicks of trim. I'm 5% elevator with take off flaps and 10% elevator with landing flaps. CG is 5mm back of the recommended setting via the manual and that's with only 3oz of lead in the nose, I could easily add more lead but the jet flew great as it was. Being as this is my first jet, I couldn't be happier with it. This think is smooth as silk and that is without any gyros. Thank You all for the help.
Brian
Old 11-10-2015, 12:34 AM
  #339
Dave Wilshere
Brian
Excellent, just how it should be
Hope you have many more fun days out
Dave
Old 11-10-2015, 08:40 AM
  #340
Reever45
My Feedback: (16)
Unfortunately my + is no more , and sadly it's looking like the culprit may have been Futaba's new R7018SB rx
Old 11-17-2015, 04:07 PM
  #341
blainer48
My Feedback: (30)
Sorry to hear about your loss Reever. What makes you think it was the receiver? Not doubting, just wondering what you came up with because I fly Futaba. Were you running Sbus servos as well?
Jason
Old 12-08-2015, 01:26 PM
  #342
Dave Wilshere
Found this from JP this year, unfortunately its the Friday flight when the wind was strong and on our backs, but good video all the same.
JR 28x and JetCat P-140Rx power. Flights this year were kept short, so less than half a tank of fuel burnt!
https://www.youtube.com/watch?v=RQLLCUcAa0c
Old 12-09-2015, 12:04 AM
  #343
Dave Wilshere
Buses! Hadn't seen this one before either! Bits of a flight and stills from a CJ event.
https://www.youtube.com/watch?v=yjDOxoTB8co
Old 12-14-2015, 09:18 PM
  #344
GManning35
My Feedback: (66)
Hello all
I just thought I would follow up on the post I placed a little while back now that I have a number of flights on the plane. I have to say that this plane was better thought out than most of the model jets on the market and as I fly it more and more things like the tight wing tube are not a problem any more and although they still fit tight the wings go on and off easier. Also I have to admit the recommended CG is really good. I moved it around quite a bit and found that the trims and roll coupling are least noticeable when the CG is between the suggested one and about 5mm back. Overall the plane has really grown on me and after flying most of the twin boom model jets made I still say that this is the best. A couple of weeks ago I put a Mobius on the plane and had a friend take some ground video. The results are here at this link. By the way I'm flying this with a P-120SX and the flying site location used in the video is 2800 feet above sea level. For a plane this big It quite well.
https://www.youtube.com/watch?v=O74MrBLVcQI
Old 12-14-2015, 11:53 PM
  #345
Dave Wilshere
George
Great video with a nice 'mars' back drop! Big open spaces everywhere except UK ;-)
Good to see the Plus works so well even at 2800'
Dave
Old 12-15-2015, 02:59 PM
  #346
mikedenilin
My Feedback: (67)
Dave. That plane flew so well, even a Martian would jump out and steal it from George before I could.
Mike
Old 12-15-2015, 06:46 PM
  #347
patmo
Default information
wow this a beautiful jet.
Old 12-21-2015, 04:56 AM
  #348
kmrcjets
hi dave have you noticed the thunderbird scheme on the xcaliber plus does not come with decals for the underside of the model to match the bird
the standard xcalibur in the thunderbird scheme does have the underside decals. you thoughts
regards
ken
Old 12-21-2015, 05:08 AM
  #349
Dave Wilshere
Ken
Which decal are you referring too?
The TB scheme has not been that popular in the UK so I have not seen one in the flesh
Dave
Old 12-21-2015, 05:11 AM
  #350
aquaskiman
My Feedback: (46)
aquaskiman's Avatar
I talked to Global about this and they have contacted the factory and are working on it. They will have decals or covering to fix it.
