Reload this Page >
Fuel transfer pump????
Old 02-23-2015, 09:54 AM
sam@ata
My Feedback: (16)
Default Fuel transfer pump????
OK, i have seen the Jersey pumps, Sig and a few others but asking if a Sullivan electric smoke pump will work for fuel transfer of kero/JetA???
Old 02-23-2015, 10:29 AM
raron455
My Feedback: (38)
raron455's Avatar
I have been using a walmart 5 gallon jug, with some dubro fuel fittings a lexan plate I made, and a Sullivan streamer pump ( about 18$) for my jet fuel. I am on my second one I run it on a 2 cell lipo and it works good but it is slow on the 2s. I know it can handle a three Cell but I don't want to pump that fast for fear of static or over pressurIng my tanks. I filter it before and after the pump.
Old 02-23-2015, 12:00 PM
FenderBean
FenderBean's Avatar
I just got a new jug from a guy who makes them and sales them on flying giants for 145.00 you can't beat it just add your battery. This is my first that I have not made myself and I have used the Sullivan pumps for years just get the gas version they make. I am curious how long you guys get running a two cell battery? My jets hold a lot of fuel and I wonder if I should just stick to running mine on a 12volt car starter box.
Old 02-23-2015, 01:53 PM
sam@ata
My Feedback: (16)
OK, Thats good Ronnie that the Streamer has lasted and works. I already bought a 5gl jug and now i have a pump(Streamer) and will get the rest to finish out a fueling station. I checked the Razorback fuelers on FG and i also found another supplier and will post the link later. The draw back i see is that this other supplier uses a turnigy 12v pump. Prices are good tho!!!!
Ronnie, a freind just suggested using a LiFe pack at 9.9v or A123 pack. Not as slow as a 7.4v and not as high as a 3s pack
Old 02-23-2015, 02:03 PM
raron455
My Feedback: (38)
raron455's Avatar
Yes sir, that may be a good choice,,, I will say this, I have a 4000mah 2s lipo, and I have flown my flash 6 times in 1 day, I have 3 tanks in it,, and that battery after 6 flights is still over 4 volts per cell, so not even 1/2 way discharged,,pretty good,, My new F16 has larger tanks all three, So I may need to up the voltage to the Sullivan, or it will take a while for it to fuel,,
Old 02-23-2015, 04:06 PM
sam@ata
My Feedback: (16)
rcfuelingsystems.com is the other vendor I mentioned above and the prices are good when compared to Jersey and such. As I said. it uses a Turnigy electric pump so not sure of the longevity.
Old 02-24-2015, 01:22 AM
madmodelman
madmodelman's Avatar
If it helps one of the best economic pumps I've found is the Kavan 12 volt one, very reliable and good German engineering.
Gary.
Old 02-24-2015, 01:32 AM
Malcolm H
Malcolm H's Avatar
Yes I use the black Kavan 12V pump on 3s lipo with great results.
I power it with an old brushed speed controller and a dirt cheap mini servo tester off Ebay to make a variable speed unit.
Malcolm
Old 02-27-2015, 04:14 AM
sam@ata
My Feedback: (16)
I appreciate the added responses and i will look for a Kavan pump so as to either use for a smaller fueler or as a backup to the 5gl. I am old fashion and like to built and tinker but just getting into turbines, i can use all the info i can find and get passed on.
Sam
Old 02-27-2015, 09:04 AM
madmodelman
For the Kavan pump search Conrad.com
Old 11-11-2015, 10:10 AM
Turbulence
My Feedback: (76)
Turbulence's Avatar
Default Bigger Case???
My two Jersey Modeler units are a bit old, about 10 years. Has anyone upgrade to a bigger battery case? if so which one? or what site carries them and what are they called/used for? I don't mind having to transfer all my electronics over. I know many people like the convenience of just strapping the battery to the side and it looks fine, but I would like to find a bigger case for my two JM cans. rcfuelingsystems.com has bigger batteries and cases than those in my JM jugs, but I don't know if he sells those out as spare parts.
Ralph
Old 11-11-2015, 10:33 AM
FalconWings
My Feedback: (57)
FalconWings's Avatar
I use a large external Lipo velcroed to the bottom of the case. I detach it for charging and storage,
Old 11-11-2015, 10:48 PM
DrV
DrV's Avatar
I do same as Falcon. 4000mAh 2s LiPo velcroed on the outside of the case. I use a cheap (I think it was $2 from eBay) Lopo low voltage alarm connected to the balance lead so I don't discharge less then 3.2v/cell.
Old 11-12-2015, 11:24 PM
Birdman6310
This works very well. Been using it for over 2 years on petrol (gas in the US)
http://hobbyking.com/hobbyking/store...Nitro_Gas.html
So cheap you buy 2 to have a spare
