Reload this Page >
What air compressor do you guys use?
Old 04-17-2015, 09:13 AM
  #76
Vincent
My Feedback: (61)
Vincent's Avatar
You need to cut the needle off with your dremel above the end where the two little side holes are and make a clean opening otherwise there is severe back pressure causing the gauge to be way off.
Vin...
Old 04-17-2015, 10:25 AM
  #77
FalconWings
My Feedback: (57)
FalconWings's Avatar
Originally Posted by FenderBean
hey for the guys that have the sears handheld one are you noticing any difference in PSI on the indicator and your air gauge in the jet? Mine seems to be off 20+ PSI even after I hit the calibaration. I had an error message on mine but it went away and I am thinking about returning mine and getting another. Has anyone noticed this?
Yes I do, Im using a BVM adapter. 20 lbs or so seems right. I believe what my EV5 says, The sears dial is a nice to have IMHO.
Old 04-17-2015, 06:52 PM
  #78
FenderBean
FenderBean's Avatar
Vin...
ahhhh okay thanks I'll give this a try
Old 04-17-2015, 06:59 PM
  #79
GSXR1000
My Feedback: (7)
GSXR1000's Avatar
I use this for my Robart Air tanks.
http://www.lowes.com/pd_146781-40883...Id=3522750#img
Not the cheapest or the most expensive, I say upper middle end. the price has gone down to.
Old 12-01-2015, 06:22 AM
  #80
afterburner
My Feedback: (18)
afterburner's Avatar
Well sears had the 19.2v compressor priced pretty high through Black Friday and Cyber Monday at around $60. Today however it's at a pretty good price at $38. Just a heads up.
http://m.sears.com/craftsman-c3-19.2...ls-activeusers
Old 12-01-2015, 09:58 AM
  #81
Eagle Driver
Eagle Driver's Avatar
IQ-Hammer Air & Fuel Multistation
ID:	2133412   Click image for larger version
Old 12-01-2015, 10:16 AM
  #82
Harley Condra
Originally Posted by Greg Wright
+++++1 on this one. I have recently taken out the the original battery and replaced it with 2 6000Mah 7.4V lipos run in series to make it a 14.8 volt system.
They last a couple of weekends of flying before needing recharged.
++++++++++++1 Too.
I have been using this pump since 1998, and now have two of them. I replaced my batteries with ones from BatteryMart.com. Only $14.95, which is about ten bucks cheaper than at the local hobby shop. http://www.batterymart.com/p-12v-7ah...ent=1130-cyber
One of the switches failed, but I replaced it with a much better switch from my junk box.
Old 12-01-2015, 10:22 AM
  #83
bluefin021
bluefin021's Avatar
Picked one up from Sears on sale today!
Old 12-01-2015, 10:31 AM
  #84
Harley Condra
Originally Posted by dingo9882
How are you guys connecting the tubing to go from the pump to the retracts. It seems the tubing is not really compatible to hook up to the pump.
I use a BVM Air Fill Valve on the end of the compressor hose. Air line connects a water trap, then continues for about a foot, and terminates with a small bevel on the end . The bevel allows the tubing end to be inserted into a BVM Air Filler Valve in the aircraft.
Old 12-01-2015, 04:24 PM
  #85
felker14
My Feedback: (50)
felker14's Avatar
Originally Posted by mikes68charger
Ok I have only been in this hobby going for 4.5 years now with the last 3 or so with big war birds and several jets.
I started with some cheap pump I had.
Then I noticed the guys at the feild were using the $29 Habbor Freight pump
Well I think my 2nd one is on its way out. I have been using a 2200 4s lipo and I tend to fill my jets to 110 psi most with 2 tank systems
So you guys tell not to buy cheap so what are my options?
This looks like a good product. http://www.bestrestproducts.com/p-29...ure-model.aspx
Old 12-01-2015, 05:54 PM
  #86
Viper1GJ
My Feedback: (20)
Viper1GJ's Avatar
$20 Slime portable from Walmart. Cut the lighter plug off and added a Deans plug to use 1000-1300mah LiPo battery that fits into the top compartment. Small, light, one battery lasts all day or all weekend, and much lighter that my old 12v gel cell brick.
Old 12-01-2015, 07:54 PM
  #87
LJE4357
Banned
My Feedback: (74)
I been using a cheap harbor freight $10 yellow pump for over 15 years. BUT........The first one I had lasted a three days. The connecting rod broke. I took it apart made a new piston and rod put it back together and been using ever since. Guess my $100,000 machine shop was worth the money. I still have an extra one that I haven't even opened the package yet. It easy, pumps up to 200 lbs.Takes about 30 seconds to fill the air tanks to 125 lbs, in my jets.
Old 10-23-2016, 06:36 AM
  #88
patrnflyr
My Feedback: (7)
patrnflyr's Avatar
Anybody come up with a high quality solution? I'm using a McMaster-Carr HP version that's good to 150psi. I needed that to move my CARF Tucano retracts but now that I'm flying BVM stuff, the high pressure is no longer needed. My pump is throwing a fuse every so often and after investigation, I've found its moisture in the cylinder. A solution is to place some Marvel Mystery oil or BVM oil into the cylinder every so often or just keep a bunch of blade fuses around. It's a great system but it's all tentative on the basketball needle/air tubing interface which seems fragile although I've never broken it. What would be nice is something that steps down from the initial tire interface to our tiny 2mm tubing that's strong.
Old 10-23-2016, 07:24 AM
  #89
LJE4357
Banned
My Feedback: (74)
Look on Ebay. I found some GAST pumps that were small, but worked great. I had 4, and sold 3 on another website you can't trust. It's a brushless DC motor. I use a cheap speed controller to power it. The pump itself is a vane pump, with teflon vanes. I think
it's used in military applications, in aircraft. It can go to 100 lb preassure, but that's the max. The person wanted $65, I offered him $25 ea. It works OK at 12 V, but at 24 works fantastic. It's been a while, but last time I looked he still had them. I think it said it had like 400 to sell.
Old 10-23-2016, 07:49 AM
  #90
AndyAndrews
AndyAndrews's Avatar
The Sears one is the best hands down.
Old 10-23-2016, 08:15 AM
  #91
patrnflyr
My Feedback: (7)
patrnflyr's Avatar
I think you're right Andy. Everything seems to point back to it. With battery and charger, it's upwards of $165! Maybe my charger is doing good after all. It's doing it's job well, just looking for convenience
Old 10-23-2016, 08:51 AM
  #92
AndyAndrews
I've had mine for over 8 years. $165/8 = $20 per year/12 = $1.67 per month. Do you buy Star Bucks? lol, I Think you know where I'm going.
Old 10-23-2016, 09:42 AM
  #93
patrnflyr
My Feedback: (7)
patrnflyr's Avatar
Well, I went ahead and pulled the trigger. Should've done it five years ago when my son advised me to do it. Will be here in a week. Under $125 with battery and charger with a coupon I found online.
Old 10-23-2016, 12:49 PM
  #94
Zeeb
My Feedback: (41)
Zeeb's Avatar
Don't get the NiMH battery, spring for the extra few dollars and get the red Lithium batteries. Trust me, they are worth the extra money...
Old 10-23-2016, 02:01 PM
  #95
patrnflyr
My Feedback: (7)
patrnflyr's Avatar
I did
Old 10-24-2016, 12:53 PM
  #96
jeteye
I use a Viair 350C. It's very high capacity, and works great. I use two 11.1 lipo batteries linked parallel, and get outstanding performance. Made the purchase through Amazon. I have dual large canisters on all my big planes, and this is the one for me! Mounted it in a tool box.
ID:	2187419   Click image for larger version
Old 10-25-2016, 06:09 AM
  #97
sysiek
My Feedback: (176)
sysiek's Avatar
When my Sears pump battery go bad and the price was like $100 I decide to go riobe the pump was only 19.95 and works much better than Sears faster and stronger the only catch you must have the batteries from other riobe 18v tools but for me that was no problem I have like 6 of them from my tools collection ,the best cordless pump I ever have .my buy the bigger brother to with mattress inflator & deflator .
ID:	2187482   Click image for larger version
ID:	2187483   Click image for larger version
Old 10-25-2016, 07:31 AM
  #98
Digital Pilot
Digital Pilot's Avatar
Amazon. Bought about 5 months ago and seems to work pretty well.. price is right!
Old 10-26-2016, 07:54 AM
  #99
lov2flyrc
My Feedback: (24)
lov2flyrc's Avatar
I spent months looking for a high quality, simple to use, compact, rechargeable field compressor. The result, our DMP "Perfect Field Compressor"
It comes with an internal battery for use on the go and it has a AC charger and DC aux power / charging cord for field charging. This small, lightweight pump includes a digital pressure display and has a programmable auto shut-off feature; set shutoff setting to desired tank pressure and pump will stop when programmed pressure setting is reached.
Old 10-26-2016, 09:51 AM
  #100
TJC333
Is the battery replaceable?
