Sebart Mini Avanti w/ K45 build thread
#826
A few Questions..
1) Does the JP Hobby Brake controller require an open channel in for operation?
2) Does the gear channel power the sequencer which then powers all three retracts and door sequencer servos plugged up to the sequencer? If so, does anyone what the amperage draw is on gear channel when loaded?
3) In the event a door sequencer servo jammed and/or a retract, could this spell disaster?
Raz
Raz
#828
A few Questions..
Raz
Raz
Yes
No, it shuts down on an over current
#829
I have fitted a JP 45mm wheel to replace the 40mm one that came with the upgrade retracts I bought to replace the originals.
#831
145mm measured at the root rib is the CG for this aircraft. It matters not what motor/engine combo that you use. Stick with that as your starting point and move to suit your style but I think you'll find 145 to be pretty much dead on.
#835
I am using a bag for the fuel made by Evernew with 900ml- it weighs nothing and you will never worry about air......no uat necessary.....just invest in a proper fuel station that measures pressure to avoid that the bag is stressed too much. VSpeak offers these fuel stations and they have a link to a website for custom made bags in almost any shape
The company Richter Tankverschluss sells caps for the bags with all necessary parts.....I find that war easier, safer and less Heavy than old school tanks
#837
#838
Aha, now I understand the reason why I never see one in any of the jets over here ...... what a shame.......bit similar to the fact that brakes are mandatory even when flying from grass......
thank you for the explanation
happy holidays
markus
#839
I never heard the reasoning why. You can make a fuel tank out of a discarded soda bottle but you can’t buy a purposely designed flexible fuel tank that is used successfully everywhere else in the world? Seems odd.
Have a happy and safe New Year!
#840
I can shed a little light on this. Turbine rules were first written in the mid '90s and while it is time to revisit some of these, national organizations are slow to change.
Having witnessed some spectacular, plasma bag / turbine powered aircraft burst and explode on impact, the AMA and MAAC ( Canada ) committees opted to ban flexible
bag use. While the material now used in IV medication bags has changed ( much stronger and puncture resistant ) in the past 20 years the rule still stands.
IMO it should be revisited.
Old turbine technology exhibited high residual thrust. In many cases, an aircraft could not remain stationary while at idle and due to slow spool up and down times, brakes were mandated.In the event of a runaway, the aircraft could be at least slowed down. Technology has moves on and this is another rule that could be looked reconsidered. Lower residual thrust, faster spool up and down times make the requirement of brakes less imperative. Rudder requirement was primarily for ground control ( crosswind / take off and landing ).
Dean W.
Dean W.
#841
Thank you for the background. My kids are both nurses, so I know how tough modern bags can be.
Personally, with all this drone nonsense os is probably not the right time for turbine rule changes ! I’m just hoping once the snow melts, I will be able to fly next season without a 10lb transponder strapped to my plane and a government employee assigned as my spotter!
Assuming of course I can pass the new upcoming airworthiness test. After all, fly8ng since 1974 means nothing anymore ...
#842
I‘m working in the chemical industry and even there US regulations are like „made in the 70/80s“ allowing old technology which is more dangerous rather than modern, less hazardous ingredients.....so a lot of similarities
I hope that one day you guys are permittied to catch up with 21st century tech ......
#844
That's one of my missions, to work on getting the turbine rules updated.
For example, to get a waiver you need a plane that weighs at least 12 pounds dry so you need a waiver to fly the Avanti as a turbine, but it doesn't qualify as a plane that you can get your waiver with.
For example, could you get a waiver using a 4m wingspan Fox glider with single 120 turbine on top, but perhaps then be unprepared to fly an Avanti with a significantly different wing loading/stall speed/handling?
#845
That's an interesting question and there's always situations where you say "you can get your waiver on this then fly that"
When I sign a waiver off (I'm a fixed and rotary turbine CD) i want to know if a person is conversant in proper installation and maintenance practices, fuel handling, fire suppression from ground or flight mishaps,and how to handle a complex model during flight.
I could always find some example of doing a waiver flight on a 12.1 pound plane means they can fly a twin 160 F-18. We (turbine sign offs) aren't to prove they can fly every conceivable model they could put a turbine on, we are there to make sure they can safely operate a model turbine and have the airmanship skills to handle a complex and potentially highly wing loaded model
#846
Hey guys,
I’m wanting to buy some carbon fiber plate and am wondering what thickness I should buy. If I’m making a plate to mount things on, what thickness do I need? Is 1 mm thick enough or do I need thicker?
Scott
Scott
#847
1mm carbon plate is plenty strong for mounting stuff on, just bear in mind real carbon plate shields 2.4 ghz so personally I would avoid mounting your receivers on it if that is the plan.
#848
Also, the new K45G3 is the same size as the K30 saving 300 grams. Because of this, I'll have to build some new mounts as the whole engine fits in the "gap". So, if I use the same 1mm plate to extend the mounts, do y'all think that'll be strong enough? I saw a picture on a previous page of someone doing something similar but it wasn't the carbon plate.
