Reload this Page >
Sebart Mini Avanti w/ K45 build thread
Old 05-27-2015, 06:29 PM
  #76
DrScoles
My Feedback: (18)
DrScoles's Avatar
Got the pipe in the mail today. It is very nice. T-shirt was a nice touch, and my son was pleased to see the gummy bears ;-) The bell mouth comes off, wouldn't go in otherwise. I might need to trim the bell mouth a bit, find out this weekend.
ID:	2099122   Click image for larger version
ID:	2099123   Click image for larger version
ID:	2099124   Click image for larger version
Old 05-27-2015, 06:40 PM
  #77
FenderBean
FenderBean's Avatar
Okay u had me at avanti but now u have my 7 year old with gummy bears.
Old 05-28-2015, 01:51 PM
  #78
c_makhija
Just got my pipe too, and picked up a new T35 for the Avanti, now just waiting for the Avanti. Pipe is very well built and service
from Grumania is outstanding.
Chatty.
Old 05-30-2015, 04:04 PM
  #79
DrScoles
My Feedback: (18)
DrScoles's Avatar
Had a chance to weigh everything. 8.4 pounds with tanks dry and a 2oz piece of lead in to account for the header tank. Kero weighs 80% of water by volume, (according to google)… ;-) So, the 32oz tank will be roughly 1.6 pounds of fuel, so take off weight will be right at 10 pounds. This is with a 2100 life turbine battery and a 2600 liion. My 8S habu 32 is gone, but this plane sure feels lighter than it.
I think Ilja and I had a communication error, the pipe might be too short. Need to see where CG is, then see if it will work. The pipe is fine if the turbine is back farther, but where I had it, its 4cm too short. ;-(
ID:	2099624   Click image for larger version
Old 05-31-2015, 01:50 PM
  #80
DrScoles
My Feedback: (18)
DrScoles's Avatar
Trial CG. I put the turbine as far forward as it would go on the mount. The pic shows where the batteries were, there is room to move them another 4" forward. So, I think you could easily get away with having the turbine in the stock mounting location and still not have to add weight. Henke's words were running through my head when setting this thing up, wanted the turbine as far forward as I could get it.
Only thing left is the ebrakes. I found some with 2" wheels. This isn't going to effect the CG much, and will add a small amount of weight over the stock wheels. Both of the fields I fly at follow AMA rules, so we gotta have brakes!
ID:	2099748   Click image for larger version
Name:	Screen Shot 2015-05-31 at 2.44.22 PM.png
ID:	2099749   Click image for larger version
Name:	Screen Shot 2015-05-31 at 2.50.09 PM.png
Old 05-31-2015, 04:59 PM
  #81
Len
Len's Avatar
Looking great Sir! I have my K45 and ran it on the test bench yesterday...awesome! Hoping to get my Avanti in the first shipment.... THanks again for this thread.
Len
Old 05-31-2015, 05:22 PM
  #82
Jason W M
Thanks for the updates DrScoles! And does that mean the pipe you have now will work?
BTW, for those interested we currently stock Grumania pipes for the larger Avanti S models, so once we know what pipe configuration works for the Mini we'll be stocking those pipes here as well (which will save you quite a bit on shipping!). This will be in addition to the pipe we already have for the P20 and up to 30N turbines.
Old 05-31-2015, 06:58 PM
  #83
Stevojet
All,
My friend maidened his at the basin today with a K45 and put two beautiful flights on it. Required some elevator trim and a click or two of aileron and away it went. Very fast and all the vertical you could ask for. He Set the timer for 5 minutes and landed with a third of a tank of kero. He uses a demon cortex gyro. We have a great photographer at the field so will try and post some photos soon.
Steve
Old 05-31-2015, 09:45 PM
  #84
LA jetguy
LA jetguy's Avatar
Congrats to Gary on his mini Avanti S maiden...
I know he is using a "Tam" pipe and I like his setup and I will be going with that setup. In my opinion the Grumania pipe bell mouth is slightly too big..
David
Old 06-01-2015, 01:05 AM
  #85
dappe69
Where do you find the 2" wheel with e-brake?
Old 06-01-2015, 05:07 AM
  #86
FenderBean
FenderBean's Avatar
Hey Dr is you ever get tired of this little fella let me know this would go great with my big Avanti
Old 06-01-2015, 09:06 AM
  #87
DrScoles
My Feedback: (18)
DrScoles's Avatar
Originally Posted by Stevojet
All,
Steve
Steve, do you know how big a tank he installed? Please share pics!
The bell mouth on the grumania pipe does need to be cut down. I've been talking to Ilja quite a bit the last few days. If you want the turbine farther forward, the rear former gets in the way of the bell mouth. I may move it back a bit to find a happy medium. I did need to get a slightly longer pipe made.
The wheels were from a guy on regroups out of singapore. I will post a link.
Old 06-08-2015, 07:51 AM
  #88
Didier
Default Maiden my mini Avanti
Hey guys,
Just wanted to tell you I made the first 3 flights with my mini Avanti powered by JetCat P-20SE today.
It was very very windy (crosswind as well) so fine tuning was not possible. It definitely feels very light on the stick and it's easy to fly. Power of the P-20 seems to be really good including decent verticals.
I flew before the Airworld Cougar and Habu32 with a P-20 but this is by far the better model.
My goal was to build it really light and made some small mods.
I removed the 2 geardoor servo's and sequencer and made a mechanical linkage (saw this idea on RC Network and works great), made a pull-pull system on the nose wheel steering (stronger on grass), replaced the carbon stab rod to a hollow one and use small batteries (2x 450 mAh RX, 1x 1300 mAH turbine)
Weight without fuel INCLUDING battery's: 3,075 kg (6,77 lb).
Including fuel (750cc): 3,7 kg (8,15 lb), so the plane is lighter then Seba's plane.
Small movie of today to give a little impression. Sorry, recored by phone.
https://youtu.be/OFODYSTeklk
Cheers Didier
Name:	2015-06-08 11.09.22.jpg
ID:	2101386   Click image for larger version
Name:	2015-06-08 14.01.49.jpg
ID:	2101387   Click image for larger version
Name:	2015-06-08 14.01.54.jpg
ID:	2101388   Click image for larger version
Name:	2015-06-08 14.02.57.jpg
ID:	2101389   Click image for larger version
Name:	2015-06-08 14.03.53.jpg
Old 06-08-2015, 10:18 AM
  #89
c_makhija
Great work Didier, which tail pipe are you using, would appreciate some pics of the tail pipe mounting from the rear.
I too may copy your idea of the pull pull system and mechanical door system, does the nose gear just push the doors open during gear extension.
Chatty.
Old 06-08-2015, 10:23 AM
  #90
c_makhija
Ahh, I think I got it, the bent wire must be under load when retracted.
Chatty.
Old 06-08-2015, 10:49 AM
  #91
Didier
Chatty.
Hey Chatty, you give already the answer yourself. ;-)
The nose wheel push the door open and the wire does the rest.
The pipe is a Grumania single wall pipe.
I had a left-over titanium pipe and cut it to 4cm/1,5 inch. This will function as the outer pipe. (only 4 cm)
I made a wooden ply ring, glued it to the aft wooden section of the fuselage and glued the outer pipe inside the ring.
The separation between the inner and outer pipe I made with a stroke of Titanium, Z-bended it as you can see.
Name:	2015-06-08 20.35.59.jpg
ID:	2101450   Click image for larger version
Name:	2015-06-08 20.36.43.jpg
Old 06-08-2015, 12:55 PM
  #92
c_makhija
Thanks Didier, My Avanti should be hopefully here next week, I got the stock pipe from Grumania and will be using a lambert T 35.
will try to keep weight down to a minimum.
Chatty.
Old 06-14-2015, 07:13 AM
  #93
DrScoles
My Feedback: (18)
DrScoles's Avatar
I got the ebrakes and the pipe installed. For those of you who need brakes due to flying at AMA fields, these are 2" replacements. The axle is 4mm, so you have to drill the strut out, pretty simple. They look very nice, but will obviously add some weight.
The grumania bell mouth is too wide to place the pipe and it at the same time. You have to bolt it together using three 3mm bolts while its in the plane. If you have large hands, might want to teach the wife how to turn wrenches. If your wife has big hands…. well… I put an angle bracket on the bulkhead for the bottom, and used one of the aluminum straps that grumania supplies and clamped it to the turbine. I had to cut down the bell mouth 2cm. Obviously, neither this pipe or the the kit were meant for each other, but you can make it work. I know Tam has made a pipe that might be easier to install???
I need to do some wire routing and it will be ready to go. Moving in the next two weeks, so doubt I will get a chance to maiden for a month or so… ;-(
ID:	2102510   Click image for larger version
ID:	2102511   Click image for larger version
ID:	2102512   Click image for larger version
Old 07-02-2015, 06:41 AM
  #94
1moparman1
My Feedback: (28)
1moparman1's Avatar
Originally Posted by LA jetguy
My KT45 serial # 005 is waiting patiently for the Mini Avanti S delivery.... A friend of mine who got his Mini Avanti with the first shipment and has serial #001 KT45 ordered the pipe through Tam (54mm wide and 450mm long) and he is very happy with it. He should be ready for maiden flight this week.
I'm curious how the struts / retracts will hold up with a slightly heavier KT45 compare to P20..
Thanks DrScoles for this built thread..
David
I have KT45 #006 lol I am waiting too
Old 07-02-2015, 07:41 AM
  #95
DrScoles
My Feedback: (18)
DrScoles's Avatar
I think the landing gear is going to be fine. It seems more robust than my Habu 32 with tams struts. I wish I would have weighed the habu, it felt a lot heavier than this plane.
My apologies for not seeing this through maiden. The e-brake controller I had was bad, and another one is coming from singapore. I'm knee deep in moving into a new house right now and planes can't be a priority. Hope to maiden in August. I know someone else above has already flown their K45 powered Avanti and sounds like it went well.
Old 07-02-2015, 08:06 AM
  #96
c_makhija
Finally finished building. lambert T35, grumania pipe. Total weight with UAT full and i gyro 3e is 3050 grams.
should have good performance. Can't wait to get her airborne.
Chatty.
ID:	2106893   Click image for larger version
ID:	2106894   Click image for larger version
ID:	2106895   Click image for larger version
Old 07-02-2015, 12:45 PM
  #97
RemoteJets
Following this thread with much interest there some of my customers also want to fit the Kingtech K45G in the mini Avanti S airframe when they arrive
See keep every info regarding the set ups and flight characteristics coming.
Grt,
Berto.
Old 07-05-2015, 08:08 AM
  #98
c_makhija
Test flew the Avanti yesterday, had 3 flights. Was actually surprised by the Verticals she had, almost out of sight.
All systems worked flawless so far, the igyro 3e made landings a breeze even in cross winds of around 15 gusting 20 knots.
With the 3.5 kg lambert, she is just a super sweet combo.
Chatty.
Old 07-06-2015, 12:03 AM
  #99
Midas D.
My finger is shivering above the "send order" button on this one.
Keep the info coming on the K45 set up, i'm really interested in how the combo works and if the airframe and gears can handle the load.....
Cheers,
Ed
Old 07-06-2015, 02:30 AM
  #100
RemoteJets
Not needed, I have 4 coming ;-)
