Messureing the airpressure >
Old 08-22-2015 | 12:24 AM
Jonas Bergström's Avatar
Default Messureing the airpressure
Hi
I will messure the airpressure to the landing gear in my aircraft when i fly. I know Jeti has this option to do this.
But i fly with Multiplex new Profi TX16 and I love that radio.
So is there any device on the market that can do that with my radio?
Is Jeti MBar compatible with MPX?
Best regards
Jonas
Old 08-22-2015 | 12:42 AM
Gaspar's Avatar
Hi Jonas,
We are working on a sequencer that includes a pressure sensor for failsafe, and have telemetry output for Multiplex, Jeti and Futaba, we expect to be ready for sale in a couple of month.
Gaspar
Xicoy Electronica SL
Old 08-22-2015 | 03:21 AM
nice!
Old 08-22-2015 | 10:24 AM
Hi Gaspar
That's was really good news, I am looking forward to see it.
This is just that type of device we MPX pilots missing.
Best regards
Jonas
Old 08-22-2015 | 01:10 PM
Originally Posted by Jonas Bergström
Hi
Best regards
Jonas
You can use JetiBox Profi with small Jeti R3 receiver and MBar air pressure sensor as standalone telemetry.
http://www.espritmodel.com/jeti-tele...-expander.aspx
http://www.espritmodel.com/jeti-tele...rogrammer.aspx
Old 08-22-2015 | 02:42 PM
Fantasic news Gaspar!!
ever since the factory that produced the airpower EU5 vales burnt down we have had a big hole in the market for retract sequencing valves.
dave
Old 08-23-2015 | 05:33 AM
dave
Just curios why not use sequencing with the radio?
Zb
Old 08-23-2015 | 01:40 PM
Zb
n
what sequencer with the radio?
Old 08-23-2015 | 03:23 PM
n
In my Jeti DC-16 I have 10 input electronic servo sequencer. Gear door and retract all can be executed by flipping single switch on the Tx.
No additional equipment sis needed.
Zb
Old 08-23-2015 | 04:54 PM
Umm, a presumption that I fly Jeti....
When I bought my powerbox I passed up on the cockpit SRS with a gear sequencer because the airpower unit was working correctly, now it looks like I might need to replace it.
And i I don't believe that Jeti has an air pressure failsafe feature?
thanks
dave
Old 08-23-2015 | 05:44 PM
Bob_B's Avatar
Mbar can provide a low air pressure failsafe
Old 08-24-2015 | 03:54 AM
thanks
dave
Not just that, you can execute functions according data inputs. I have set up my air pressure sensor that it gives me 3x (Drop Gear, Drop Gear....) warning at 50psi, at 40 it will drop gear no matter what and it also lowers the throttle to 50% automatically. No fun to drop the gear at full speed.
Zb
Old 08-27-2015 | 10:28 PM
JohnMac's Avatar
Hi Gaspar, if it had an external output it would be very useful. Model jets are getting to the size that we can afford to instal an onboard air pump. So I want a device that will simply run the pump if the pressure goes below set limit and switch it off again when it hits the high pressure mark. I also use Jeti and the Mbar sensor could do this via the radio, but it seems to be making it it more complex than it needs to be.
John
