Cortex Service provider USA? >
Old 09-04-2015 | 09:47 AM
My Feedback: (34)
Default Cortex Service provider USA?
Ok long story short my bought a Cortex for his Skymaster Viper, used it about a year with great results. One day at our feild his viper twichced really hard to the right 2 times and while trying to bring it in for a landing it did it again and caused it to crash as it was at low speed 10 feet up.
He figured it was a issue with his Spectrum set up and moved on, sold me the gyro.
As I was uncertain I put it in a cheap GP Biplane and put 10 flights with no issues so I moved it to my Carf Eurosport, I have had around 10 amazing flights.
But last weekend it started to twichce real hard to the right, I freaked out turned off the gyro and it still did it, buy the time of the first twichced to I got to the ground in the time it took me to fly my base leg and land it twichced around 10 times.
I was freaking out but figured it was jut low batteries. Today I got around to charging up the 2 2200 6.6 life packs and to my surprise I only put 620mah each to full charge. Which tells me they were not very low. Right now I'm dischargeing both backs to see there capacity.
I'm thinking I should send in this cortex for testing but to who?
Is there anything else you would check on your jet?
I'm useing 2 swiches with a life on each into the AR9010 spectrum reciver.
I'm not talking bad about Cortex as I have 1 other in my F16 with amazing results. I love this gyro but I can't afford to lose my Eurosport.
So who should I contact to send this to? Is there even a service I can send it to?
Old 09-04-2015 | 10:06 AM
FalconWings's Avatar
My Feedback: (57)
So is there a known compatibility problem between Spektrum and Cortex? I am installing one this weekend on a Spektrum receiver and would like to know.
Old 09-04-2015 | 10:08 AM
Bob_B's Avatar
No compatibility issues with the Cortex and any radio system.
www.demonaero.com
Old 09-04-2015 | 10:30 AM
mr_matt's Avatar
My Feedback: (10)
That's what scares me you can never really turn these things "off" as far as I can tell.
By "off" i mean the servo signals pass through the gyro like they are on a piece of wire.
Old 09-04-2015 | 10:33 AM
My Feedback: (34)
I'm not try to scare anyone I'm looking for a phone number of who to call and possibly some things I should duble check before my next flight
And I got 4 other buddies useing Cortex with spectrum with no issues
Old 09-04-2015 | 11:16 AM
My Feedback: (57)
ok thanks.
Old 09-04-2015 | 12:05 PM
take it out and fly it again only way to prove it is the gyro
Old 09-04-2015 | 01:07 PM
My Feedback: (12)
The Tech Rep for Demon is Danny. You can reach him at 407-687-3126. I am heading down the Cortex Gyro road myself and have spoke with him a couple of times. He answers his phone !!!
Curious to know what he says...
Bill
Old 09-04-2015 | 01:18 PM
rhklenke's Avatar
My Feedback: (24)
Yep, that's the one thing that nobody really thinks about with things like this - you are "asking" the software inside the gyro to please give you back direct control of your servos, and in case of a bug, or maybe a hardware failure, the answer maybe "no!"
You could use something like this to bypass the gyro as a last resort:
https://www.pololu.com/product/2806
http://www.robotshop.com/en/cytron-8...ltiplexer.html
https://acroname.com/products/RXMUX-...VO-MULTIPLEXER
Bob
Old 09-04-2015 | 05:03 PM
Gary Arthur's Avatar
My Feedback: (29)
If it is an early version Cortex you should have the foam shroud over it. If its newer, this is not required.
Old 09-04-2015 | 05:38 PM
Hi mikes68charger
Please contact me and we will take care of you.
Danny
407-687-3126
[email protected]
