New Mini Xcalibur
#176
In this case,will Gens Ace 800mah 2S will be more suitable?
i may go with smaller battery packs to get the weight down and help on the balance a bit. i can juggle them with the ones i have to achieve the proper perfect cg as well as get the weight down to 7.6 pounds as dave thinks his was at.
dave
is the stock cg 115mm a good flying point for the plane over all.
dave
#178
Finally found time to finish this RA scheme version for best buddy Trevor. Weather was better than forecast, so I nipped out for a test flight...24 knot wind in the end, so did not get to fine tune the initial set up and start setting the iGyro, but no trim so far. Timer is set for 7.30 from gear up.
7.5lb dry
7.5lb dry
#183
hope to fly mine soon all is ready to go and im just working up me nerve to fly a small jet. not sure my eyes will keep up with it so its a group flight with spotter on hand for security... maybe one day this next week if the wind and rain let it happen. sure do like the red color there..
keep you posted
and thanks dave for all your setup help
keep you posted
#184
Had both Mini's out today, Trevor had his first two flights today, after more than 12 months without a turbine flight he was back into it after 2 circuits :-)
#185
Thanks for all your efforts Davey, Xcaliber flew really nice as to be expected with your setup. Looking forward to more flying and Jet Power not far off either.
Trevor.
Trevor.
#186
Hello,
I was hoping I could get some help with a couple of questions regarding this plane (which I think is my 'winter project' I have been looking for a smaller easy to transport and setup jet and I think this is the one (plus I couldn't get myself to go with a EPO foam jet ... it just seemed odd)
Turbine will be a P20SX, which from what I've read should be fine for flying from grass (I don't have access to paved runway). P20SX is much easier to purchase and get support here in the USA compared to a Kolibri Lambert T25 or T30.
Is there anyone in the USA who sells this plane? I checked GlobalJetClub and Dreamworks, but they only sell the 2 larger versions. Did I miss someone else?
Can someone tell me the size of the wheels on the mains? Since brakes are required by AMA, I am thinking of possibly installing a set of electric brakes on the mains, but don't know the size of the wheels nor axles.
Thank you very much,
#189
Thank you.
I assumed that installing inexpensive electric brakes on the mains, perhaps something like these https://www.turbines-rc.com/en/wheel...-4mm-axle.html would have been the easiest path forward (once I knew the diameter and axle size)
But perhaps I didn't think thru the dubro friction brake ... I haven't used one in almost 30 years ... nice to see they haven't changed anything!
#190
JSM Mini Xcalibur
Hello All,
Marcus getting in the maiden for him of horsefeetky old ride. Lightly use JSM Mini Xcalibur! Engine is actually a JetCat P20-SE.
Cheers!
Desert Fox 1
Cheers!
Desert Fox 1
Last edited by Desert Fox 1; 09-19-2017 at 09:31 PM. Reason: Added video link, correct error in video intro
#191
glad it got a great home on pavement.. it didnt like my grass here in ky.. maybe a bit more power and it would have done well but i went with larger plane for my needs.
this is a solid build with kst servos and should last many flights with crisp response. thanks marcus we miss you in ky...
#192
Last weekend saw a couple of our local club members, bring their Mini - X's to our club site. Grass runway, a little on the tight side for jets but had several flights without issue. The second model was bought to the field to set up and test the turbine as it had been bought second hand. It really is a nifty little package!
#196
looks sweet i miss that bird.. im sure on a k30 it will have much more fun than the original p20.. maybe even off grass now..
keep us posted on the all up weight and flight performance.. thanks for the updates marcus..
#198
our grass here in ky was not working out well for the mini on p20 power that is why it got passed on to marcus who fly's at ga jet site on pavement.. cant wait to see the next flight of it with new power i miss that plane and i dont say that about many i have let go of.
#199
One tip for all Mini Xcalibur grass flyers, increasing the angle of attach shortens the take off roll. A 1/8” ply packer under the nose unit is how I do it.
