Reload this Page >
Elite Aerosport Rebel Pro Build
Old 12-18-2015, 08:20 PM
  #151
FenderBean
FenderBean's Avatar
Last bit of stuff, I made two battery mounts for my Ions, if I can get the jet down and out side tomorrow I will test everything.
ID:	2136475   Click image for larger version
ID:	2136476   Click image for larger version
ID:	2136477   Click image for larger version
Old 12-19-2015, 11:29 PM
  #152
Randy M.
My Feedback: (38)
The xicoy cg machine works great. As long as you put In the right info. Bring down new years day. Always a good time. .
Old 12-20-2015, 08:18 AM
  #153
FenderBean
FenderBean's Avatar
New Year's Day? You guys getting together at your club?
Old 12-20-2015, 10:56 AM
  #154
Randy M.
My Feedback: (38)
Yes Keith every year for the past 20. Rain or shine, or freezing cold.
Old 12-20-2015, 01:09 PM
  #155
FenderBean
FenderBean's Avatar
I will keep that in mind, have a road trip to south alabama around that time so well see. As for the Xicoy CG machine, I have given up on it. I did some testing with 5 and 10 pound weights today. The accuracy of the scales is not usable, up to a pound difference between scales even after calibration so I just cant trust it.
Old 12-30-2015, 03:03 PM
  #156
FenderBean
FenderBean's Avatar
Finishing up a few odds and ends today, I have a few pictures of the main gear doors installed. Pretty easy to drill the strusts and tap for 4mm. Only thing you have to watch out for is the strut side has an angle to it. Plus you have to make sure the wheel towing is straight before you drill the holes in the door.
I was wondering if anyone who has flown one of these can tell me how they measured the throws? The manual has mm throws, are you guys just measure from the center of the surface to the center of wing? The reason I ask is with not even what was listed the throws seem a bit much and with a 150mm of flap throw the flap is vertical? CG will be behind the wing tube about 1/4 inch aft per Pablos recommendation.
ID:	2138629   Click image for larger version
ID:	2138630   Click image for larger version
ID:	2138631   Click image for larger version
ID:	2138632   Click image for larger version
Old 12-30-2015, 05:07 PM
  #157
rc4flying
My Feedback: (21)
rc4flying's Avatar
The arrows are pointing to where your measurements should be taken at for control surface throw measurements.
I have my C/G at the back edge of wing tube and I am totally happy with the plane.
Old 12-30-2015, 06:00 PM
  #158
FenderBean
FenderBean's Avatar
Yeah I have that paper just seems like a lot of throw on the controls.
Old 12-30-2015, 06:20 PM
  #159
rc4flying
My Feedback: (21)
rc4flying's Avatar
I started with all the throws listed and they were a very good safe start for a maiden flight. I presently have the rudder set at 2-1/8" throw in both directions measure at location shown on above sheet. The elevator throw is set at 1-1/8" up and 1" down throws at present. At present, I can't remember my Ail throw but if I remember right, it is just slightly less then the throws suggested. These throws are of course what suit my style of flying and it gives me a smooth flying plane. Can't remember my flap throws right now, but I will be setting up my plane to do some airframe checks and can check my final setup tomorrow on all surfaces.
Old 12-30-2015, 07:26 PM
  #160
FenderBean
FenderBean's Avatar
Thanks, I just went a head and set everything to the recommended throws, I was mainly worried about the Flaps and ailerons. They seem to be the ones that will get you in trouble the most on the first few seconds
Well the radio is setup which leaves the igyro and a final QC check on everything!
Old 12-30-2015, 11:22 PM
  #161
lxfly
lxfly's Avatar
Thanks guys for all input in this thread, not worried for throws this year, got mine just 1 week ago
Old 12-31-2015, 09:35 AM
  #162
FenderBean
FenderBean's Avatar
Man really like the orange that's what my orig order was. Your welcome that's why I do builds
Old 12-31-2015, 09:45 AM
  #163
David Jackson
My Feedback: (15)
Finally making some progress on my Rebel Pro and hope to have it done by the time my engine is repaired and returned. Appreciate all the info provided in this thread.
Old 12-31-2015, 12:44 PM
  #164
number27
number27's Avatar
Appreciate your efforts here Keith. Nice build/assembly. My Rebel Pro due February. Normally don't like doors but may do your mod to the front.
Old 01-06-2016, 03:28 PM
  #165
rbxbear44
My Feedback: (86)
Ok, mine is here. Waiting for trucking co to deliver it.
Old 01-06-2016, 05:15 PM
  #166
FenderBean
FenderBean's Avatar
Welp its 100% ready to fly, weight with tanks empty and UAT full was 33.5lbs! super light. It would appear my original scales are not working as advertised. Went with stock throws +/-3 mm, the gear doors all function great, so now I just need to work up some motivation and make a road trip to a field to fly it. Minus any updates after the first few flights or problems I'm calling this one a done and moving on. I got a 2.5M FB viper on the table to start for a friend and soon a my own viper so I will be starting a another dual jet build!!!!!
I hope I can get the thing down stairs to the garage LOL
Old 01-07-2016, 06:35 AM
  #167
Mike Pascoe
My Feedback: (13)
Mike Pascoe's Avatar
Hi Fender, My Turbine Battery ended up being mounted behind the nose gear opening on the floor, the best C/G is about 1/2" behind the wing tube! I used the factory recommended throws. Hope this helps.
Mike
Old 01-07-2016, 07:24 AM
  #168
rbxbear44
My Feedback: (86)
Was just thinking, "I hope it can get through that little door in the background of the pic!"
Old 01-07-2016, 07:40 AM
  #169
FenderBean
FenderBean's Avatar
luckily that's not the way to the garage lol
Mike I am about the same spot, only battery change was sliding the turbine battery back about an inch. Pablo suggested the same cg, said it helped inverted flight which required less up elevator.
Old 01-07-2016, 08:04 PM
  #170
rbxbear44
My Feedback: (86)
Had to run get it from the trucking co. or wait till their schedule would bring to my side of town. But it is here, no shipping damage at all!!! Gear is somewhere over the rainbow but hope to get it here next week.
Very happy with this airframe! Will start on it this weekend.
Old 01-07-2016, 09:29 PM
  #171
FenderBean
FenderBean's Avatar
Man still love that orange, Scott or pablo should be sending you the gear since its the same as the shockwave.
Kenrico (05-02-2020)
Old 01-10-2016, 02:25 PM
  #172
rbxbear44
My Feedback: (86)
If anyone was wondering how much the "fuel keg" holds, it's 216oz. or 1.6 Gal!!! Let's see, with my P-200 at 21oz. per minute at full throttle the whole time...10.28 min of full throttle flight!!!
Build is going well. No gear yet so, doing everything else I can. Pretty straight forward build.
Rex
Old 01-10-2016, 03:14 PM
  #173
FenderBean
FenderBean's Avatar
Rex
Seriously? doesnt seem that big! man it will be nice to have a 10m flight time I havent had that since my kadet senior. Have fun Africa, I go back to work this week so my building will be slow again. I didnt manage to get the F-14 back together and done. Should have done it this way the first time, guess thats what happens when you rush for an event. I am hoping to the viper builds now, will have two to build soon. Going to be a great flying season this year!
Old 01-10-2016, 03:49 PM
  #174
David Jackson
My Feedback: (15)
Just curious, what would be the max size turbine for the standard pipe supplied with the Rebel Pro?
Old 01-10-2016, 04:43 PM
  #175
jetpilot
My Feedback: (48)
jetpilot's Avatar
We have ran up to 180 to 210 with stock pipe.
Scott
