Jeti DS-24
#377
#382
I have removed some posts that were not contributing to the thread.
I will be investigating a possible sock puppet troll.
Please stay on topic this is a serious issue with significant sums of money involved plus reputations are on the line.
#383
This thread is providing useful info on the status of Jeti DS 24
At times I have been close to coming in and deleting a bunch of posts but it has not deteriorated down to that level until today.
Can I remind all potential posters about our rules on manufacturer "bashing". IE "XYZ is rubbish" is not acceptable. "my XYZ set has been returned 3 times and still has the following fault " is absolutely fine and is exactly the sort of thing RCU wants to disseminate.
If you are connected in some way to a competing manufacturer you should not be posting in this thread at all. I will turn a Nelsonian eye on posts that are positive informative and contribute to the thread. Remember you MUST make that connection clear in your signature. There is NO LEEWAY on this.
#384
#392
My Feedback: (7)
These days knowing how poorly the Central box makes use of Rx2 I've been thinking I'd prefer to use an REX7, etc as the primary with an R3 secondary (or clone) connected directly to the primary rx via a PPM link rather than connecting the secondary to RX2 of the central box. You should then be able to connect a 900Mhz receiver to the RX2 input so you would have 2, 2.4Ghz receivers in a configuration that I believe works better (as far as we know at this point) than the secondary directly connected to Rx2. Since Rx2 never gets used unless rx1 has almost completely failed it seems like a perfect match for the 900Mhz backup which also doesn't get used unless 2.4Ghz communications fail..
#393
I am about to replace a CB200/2xR3s in a T-1 with an R14/R3.
What are the pros and cons of dual path vs clone mode knowing what we do now? Will the switching to the R3 be the same as the CB?
I also may add a Cortex Pro so how will it best fit in the mix?
#394
My Feedback: (7)
One thing about Dual path is it prevents you from using the wireless trainer interface as that requires one of the transmit RF sections and dual path uses both.. If you aren't interested in the wireless trainer interface then dual path is great. As far as I can tell a clone or secondary receiver connected to a normal receiver via a PPM link seems to make better use of the secondary receiver (or clone) that the central box does. This is really just a firmware issue with the central box and I'm sure they can (will) improve this significantly but as it is now it's not that great.
Since I like to use the trainer interface to allow others to fly my jets I prefer a clone connected to a regular receiver via a PPM link.
#396
My Feedback: (7)
With the hardware available to the CB200 i see no reason why they can't make a huge improvement in the CB200s use of Rx2 without much effort. The question is, with all the other stuff they have going on, will they and if so, how long will it take for them to get around to it.
#397
I don't believe so when you are using a PPM link between them. I believe the PPM link may be fed directly into the primary receivers servo decoder so if fails to receive a valid signal but the secondary receiver has a good PPM stream then it should be able to use the PPM data very efficiently. How quickly the PPM stream from the secondary gets used once the primary fails to receive isn't clear. My GUESS is due to the nature of the PPM link being slower than the receive rate, the primary probably needs to drop several (2-3 ??) consecutive frames before using the PPM stream but it should to be way better than 14 consecutive receive failures which is the CB200 criteria for switching to Rx2
#399
My Feedback: (40)
Craig
I don’t have one yet, I only have one CB400 and my setup doesn’t need it....
