Jeti DS-24
#1476
Thanks. I believe I am using the flight mode delay, but I’m not sure if I haven’t accidentally put an additional delay at the servo level, that’s what I need to still check and rule out. -Tom
#1477
Jeti USA Press Release!!!
We would like to announce that on December 13, 2019 at 15:00 EST the Federal Communication Commission and Industry Canada, Granted Equipment Authorization (FCC), and Certificate of Acceptance (IC) to Jeti USA (Esprit Model Inc.) for the Jeti Duplex DS-12 Radio System.
After spending hundreds of hours and thousands of dollars, we can say that this was our most complicated and most expensive project yet. We cannot express our gratitude enough to all of the people who believed in us and contributed to bringing one of the finest and most advanced radio systems to the American market.
We are expecting that we will start shipping all pre-ordered DS-12 radios next Monday.
Zb/Jeti USA
Esprit Tech/Model 1.321.729.4287
Zb/Jeti USA
#1479
My Feedback: (10)
="4"%Jeti USA Press Release!!!
Zb/Jeti USA
Attachment 2265907
Zb/Jeti USA
Attachment 2265907
Maybe a good idea to open a Jeti DS-12 thread.?
#1480
Hi guys, thank you for your helpfulness. As I said, the setup will apply to my first JET T1 Fortune.
In what discussion thread should I ask my questions? To the discussion thread / Jeti DS-24 / or in section / Kingtech presents all new T1 sports jet /. I think the thread / Kingtech presents ... / reads a lot of guys who build their first JET and use Tx Jeti Duplex. Maybe it would also help them and make setup easier. ***winter***
#1481
#1482
DS-24 with the T1, from my point of view this would be the ideal condition. This thread would serve not only the owners or builders of T1 controlled DS / DC-24. It would also serve those who control their JET models with the Jeti Duplex system. If a new fiber is not formed, I will try to respect the specific focus of the fiber. I would be in favor of a new discussion thread. ***winter***
#1483
My Feedback: (53)
I don’t think a tread specifically for the T-1 has not much value (but go ahead make one) has an owner of a few jets and the best radio a DC-24 , I can says that all of my jets are actually using the same template as a base.....then I just adjusted to include or remove, things like doors, smoke, ect....
What I’m actually saying is ask away questions, they will benefit everybody even if they have a scale jet with like the T-One F-22 which has tons of stuff, because frankly I would start still with my normal jet template...then add everything I need for that jets, so it doesn’t matter which jet they own......There’s nothing special in a T-1...it’s a very basic jet in term of systems......
#1485
There is a very long T-1 thread already so no need to start a new one. FWIW I have a T-1 and use a 12ch Assist and an R3 in dual mode with a Dual battery switch. No problems after about 75 flights.
#1487
I don’t think a tread specifically for the T-1 has not much value (but go ahead make one) has an owner of a few jets..........
........and the best radio a DC-24 ,.......
.........I can says that all of my jets are actually using the same template as a base....................
........ is designed and manufactured by us in the Czech Republic .....
........ I look forward to getting to the basic template for setting up JET. I know it initially looks complicated ...... ***winter***
#1488
- Added Support for Jeti DS-12 Radios, New Sensors, Receivers and Devices
- Added File Browser. See what Devices (.bin), Apps, Audio files you have right on your Transmitter
- Added Fully Embedded Help Manual (Press Menu when you see Question Box in Upper Right Corner)
- Added Support for Trainer Cable (PPM Jack)
- And Tons of Other Modifications, Improvements and Enhancements
#1489
Wasn't V5 coming some time ago??
Regards,
Regards,
#1490
I've only been using Jeti for a little over a year so I'm still a newb, but I also use a basic template for all of my jets that includes flight modes for flaps, retracts, gyro gain, separate nose steering etc. I keep all of my switches consistent from model to model so that I don't have to remember differences across models, for example my gyro control switch is always a three position (SC) where up is Gyro Off, middle is Dampening, down is Attitude Hold. Also, I love the Default switch position sensor functionality in the DS-24, I use it to make sure my gyro, retract, and smoke switches are in the correct positions when I turn on the radio
#1491
UPDATE: I got my DS-24 back from James at Esprit yesterday. Initial tests look good. I turned it on several times, switching to different models that previously resulted in the above error, and no sign of the error! James thinks that something got corrupted and that re-flashing the firmware fixed it. So, if anyone runs into this problem where the error message just keeps randomly popping up try re-flashing your firmware before you send it back for repair as this might save you several weeks and the cost of shipping -Tom
I made the update to v5 and also got the annoying message.
I changed a few switches some time ago, so I just went to System -> View Inputs -> "arrow for screen 2/2" and just cycled through all the switches.
Until now it hasn't popped up anymore.
Hope it helps!
Saludos,
Jean Paul
#1492
My Feedback: (7)
Hello
Hope it helps!
Saludos,
Jean Paul
Hope it helps!
Saludos,
Jean Paul
#1493
please take a picture of each Tx Jeti screen. Step by step. And some brief description. As Tom says: .....that includes flight modes for flaps, retracts, gyro gain, separate nose steering etc. I keep all of my switches consistent from model to model so that I don't have to remember differences across models, for example my gyro control switch is always a three position (SC) where up is Gyro Off, middle is Dampening, down is Attitude Hold., and more......
It's the easiest way to pass on your knowledge to other model builders. So that it is understandable to all and understand the basic settings for JETs. The template is then tuned by each newcomer according to their preferences. There's no rush. I'm sorry I won't be able to try everything right away. My CB 220 will only be after the New Year. I also did that when I wanted to share the construction of giant acrabatic models. I believe it made it easier for a lot of friends to work.
Thank you guys and wish you Merry Christmas to you and your loved ones. ***winter***
https://www.flyinggiants.com/forums/...=76101&page=83
https://www.flyinggiants.com/forums/...=76101&page=84
https://www.flyinggiants.com/forums/...=76101&page=85
https://www.flyinggiants.com/forums/...=76101&page=86
#1494
My Feedback: (53)
Hi Tom, Dansy .......
#1495
My Feedback: (7)
Also, in a separate thread on each part of the setup such as use of flight modes, how to control flaps, etc. Since there are a bunch of different ways to set things up with Jeti a separate thread with a number of posts on each part of setup would probably be more useful than a single large post in this thread.
#1496
Ideal and best understood is pictorial photo documentation and brief description. This is my experience in transferring my knowledge. It would be worthy to create such a thread. I would like to participate. First as a newcomer and after some time as an experienced.
As a newcomer, I dare not start a new thread. So far I have no experience that I could pass on. ***winter***
#1498
Hi.
I have a configuration on my CB 200 with 2 x R3 RSW + R3 900. Everything is working in Double Path.
The problem occur when I disconnect one of the 2.4 and, I lost both antenna telemetry (A1, A2, A3, A4) The servos keep responding, and the TX show me the message 'Switched to Backup'. If I also disconnect the 900 the TX show me the message 'Signal Loss', but the servos keep responding. Is it normal?
DS24 version 5.02
CB Version 1.31
R3 EX Version 3.25
RSAT 900 1.13
Output Period - Auto
CB Ext1: Receiver
RX : EX Bus L
tks
DS24 version 5.02
CB Version 1.31
R3 EX Version 3.25
RSAT 900 1.13
CB Ext1: Receiver
RX : EX Bus L
tks
