Reload this Page >
Big Head Jet from Fly-Models Review and Build
Old 02-19-2016, 06:11 AM
vquick
My Feedback: (71)
vquick's Avatar
Next time i will post in oz or grams make simple for those who like to complicate there lives cause after they mention went and correct im talking in pounds and oz but like i say next time i will go with preschool math for those who get confused
Old 02-19-2016, 10:04 AM
luge_racer
I dunno, are you sure you can handle it? Because in preschool I learned how to present measurements in standardized format. For example, writing 2lbs 3oz instead of "2.3 pound" like you did earlier.
Ultimately though, I'm familiar with Fly Model construction. They use stingy amounts of substandard glue, and very weak plywood. On a sub $500 trainer, that can be overlooked. But on a $2700 sport jet that's trying to compete with Skymaster or CARF, that's just not going to cut it. If it were half the price I might consider it.
Since I can't trust your math, or measurements then I can't trust you to provide a proper, unbiased, review. Since you appear to be very rude and closed minded when multiple people show you an error you've made I don't really want to stick around in this thread any longer. Enjoy your jet; I'll pass.
Old 02-19-2016, 10:20 AM
vquick
My Feedback: (71)
vquick's Avatar
This thread is for showing the plane and build of the plane not for come and start picking on me with your smart coments correcting me this is not about who being right or wrong if you don't like the plane thats your opinion and if you don't want to folow the thread is your option there plany other thread and i know about quality i own other jets
Old 02-22-2016, 08:22 AM
vquick
My Feedback: (71)
vquick's Avatar
I got some more work done this weekend hope to have the plane ready for the coming weekend for test flight
I install the rear section and run servo extensions and air lines also figure out were everything will be located install wings and check the alignment against the fuse cover the servos and wires in the back section with aluminum tape install the trust tube and turbine
ID:	2148808   Click image for larger version
ID:	2148809   Click image for larger version
ID:	2148810   Click image for larger version
ID:	2148811   Click image for larger version
ID:	2148812   Click image for larger version
ID:	2148813   Click image for larger version
Old 02-25-2016, 09:22 AM
vquick
My Feedback: (71)
vquick's Avatar
More work been done plane is almost finish plan to test flight this Saturday just few thinks to be finish hope be done by today and balance the plane.I made some simple air tanks mount with some balsa triangle an lite ply install tanks and turbine components
ID:	2149375   Click image for larger version
ID:	2149376   Click image for larger version
ID:	2149377   Click image for larger version
ID:	2149378   Click image for larger version
ID:	2149379   Click image for larger version
ID:	2149380   Click image for larger version
ID:	2149381   Click image for larger version
Old 02-25-2016, 09:37 AM
  #31
vquick
My Feedback: (71)
vquick's Avatar
More pictures add electronic and valves
ID:	2149384   Click image for larger version
ID:	2149385   Click image for larger version
ID:	2149386   Click image for larger version
ID:	2149387   Click image for larger version
ID:	2149388   Click image for larger version
ID:	2149389   Click image for larger version
Old 02-27-2016, 04:18 PM
  #32
lfierro1
so its saturday, any flight report?
Old 02-27-2016, 06:30 PM
  #33
vquick
My Feedback: (71)
vquick's Avatar
No flight today still waiting for the GSU for Iq hammer so i can setup the turbine soon i test flight i will let know and post some video
Old 02-28-2016, 12:24 AM
  #34
Eagle Driver
Eagle Driver's Avatar
Hi,
please change the installation of your filter in the fuel line.
regards Steven
www.iqhammer.de
www.jetisfaction.de
Old 02-28-2016, 08:23 AM
  #35
vquick
My Feedback: (71)
vquick's Avatar
Originally Posted by Eagle Driver
Hi,
regards Steven
www.iqhammer.de
www.jetisfaction.de
what do you mean with that Steven
Old 02-28-2016, 09:30 AM
  #36
Eagle Driver
The Filter have to be installed vertical (thats important) .....
If you install it horizontal you may have air bubbles in the filter
which can cause a flame out.
hope this helps .... good luck on your maiden
Old 02-28-2016, 05:58 PM
  #37
vquick
My Feedback: (71)
vquick's Avatar
Cool Thanks i will work on
Hope can test fly this week GSU will be here tomorrow
Old 02-29-2016, 06:35 AM
  #38
why_fly_high
My Feedback: (19)
Did you get a completed weight yet? Are you pleased with the quality?
Dan
Old 02-29-2016, 07:51 AM
  #39
vquick
My Feedback: (71)
vquick's Avatar
Dan
Yes the plane ready to flight is 25 pounds Quality is ok is not perfect I did some reinforcement in the rudder mount for just to have some peace in my mind and I pass the notes to the Distributor so he can pass those to manufacture the retracts hardware and trust tube they are pretty good they are gone work with the price to be more competitive
Old 02-29-2016, 08:17 AM
  #40
why_fly_high
My Feedback: (19)
Thanks for the info. Obviously the most important thing is to being able to take the abuse in the air. This plane interests me and your comment of them working on the price is good to hear. At their price point quality needs to be really good. No perfect but really good. I look forward to the flying portion of your review.
Old 03-20-2016, 05:32 PM
  #41
vquick
My Feedback: (71)
vquick's Avatar
Well finally i got the chance to test flight the jet this past weekend we got a get together at GA Jets and Friday i put the first flight everything went well on the first flight i didn't put the retracts up so i flew with the gear down ant trim the plane for take off and landing on landing notice the plane nose heavy so from the 12 oz i was having in the nose for balance i remove half for the second flight during the second flight on Saturday i gear up and trim the plane for normal flight use less up trim from the previews flight and landing feels better when i got home today i remove the other half of the weight for the next flight i will be attending The jet event in Bomber Field Texas at the end of the month and i will have the plane there to do more testing and plan to take some video this time
Old 03-24-2016, 10:53 AM
  #42
vquick
My Feedback: (71)
vquick's Avatar
Some pictures of the finish product at this ariplane i used Jeti Radio with 18ch rx, all MKS HV servos, Optipower batteries i have 2 3500 mha for the radio system IQ hammer 90 Turbine with stock battery
ID:	2153994   Click image for larger version
ID:	2153995   Click image for larger version
Old 04-05-2016, 09:16 AM
  #43
vquick
My Feedback: (71)
vquick's Avatar
Video from one of the fights at Jets over Houston
http://www.youtube.com/watch?v=67Hdek4VvN0
Old 04-05-2016, 10:51 AM
  #44
Eagle Driver
Nice install and good to see the filter in correct position
The only thing you have to change now is "THE GUY ON THE CAMERA" ;-)))))))
Old 04-05-2016, 11:02 AM
  #45
vquick
My Feedback: (71)
vquick's Avatar
Thanks for your suggestions learn something new every day
Thanks again
Old 04-05-2016, 11:03 AM
  #46
vquick
My Feedback: (71)
vquick's Avatar
My wife sorry about that will try again at Mississippi jets
