Kingtech presents the all new T1 sports jet
#2602
My Feedback: (23)
Well I tried diesel on my 2005 P-120 with Kerostart and it shutoff showing hot temp. Was running then shutoff. Switched back to JET A nothing perfect. I guess my engine doesn’t like diesel! My manual does say if the pump voltage is to high flames may come out of the back. That I did see.
#2603
Winter,
Will you take a quick pic (top down) of your turbine install as well as a pic of how much of the pipe you have sticking out the back of the jet (if any)? I'm going to install the K140G2 and supplied pipe in mine.
Here's my maybe issue: If I mount the supplied pipe properly, I'm having to mount the K140G2 at the very back of the engine mount against the vertical bulkhead that separates the "engine mount area" from the "Thrust tube area" and I'm concerned that the K140G2 isn't mounted far enough into the Bellmouth. I've been told to mount it betwen 3/4" and 1" from the start of the pipe, itself. Right now, if I place everything as described, I don't think the engine sticks far enough into the bellmouth. I'm wondering if I need to cut into that bulkhead to get it close enough and this isn't really something I want to do if it doesn't need to be done.
Thank you,
Scott
Thank you,
Scott
#2611
cbk07 and Dansy It seems that the distance between the start of the pipe and the exhaust of the engine is more than 1". Is that just an optical delusion?
This is great though. I was trying to leave like a 1/4" of the pipe sticking out. I just like the look of it, I guess. Doesn't seem like that's gonna work though.
Also, one other question if I may. Are the socket heads to tighten down the empennage and the wings 3MM? It doesn't seem like mine line up very well.
#2612
My Feedback: (53)
smcharg (09-14-2020)
#2616
I think you have a pipe unnecessarily too far in front. I have the end of the pipe at the same time as the end of the fuselage. The distance between the end of the turbine and the beginning of the pipe is 30 mm. It works perfectly. ***winter***
#2620
Finally pulled the trigger on a T1. Hoping to get some info prior to the build regarding hardware. Looks like all the ball links are 4-40, is that correct? Also, regarding servo arm length, I like to go as small as possible for better resolution. Looks like some are using 1" arms, anyone using anything smaller? How about on the flaps for the internal linkage? TIA!
#2622
My Feedback: (46)
Its all metric hardware so 3mm not 4-40. The included ball links I would call acceptable, I replaced all mine with Dubro. Servo arm length, unless you want to cut the slots bigger so the ball link will fit through the slot, will all have to be 1”. The servo arm package that is on the PRCJ website is pretty nice and all the correct size. The flaps internal linkage I don’t really understand why they did that. It’s a PITA, it’s a sport jet I wish they would have just left it external. But it’s nice to have it internal I guess. What scheme did you get?
#2623
Congrats!
#2624
Is anyone flying their T1 with a 180 in it? I prefer to over power my planes so that I'm not flying around at full throttle making the engine cry uncle the whole time. Just curious about residual thrust on landing?
