Reload this Page >
Kingtech presents the all new T1 sports jet
Old 10-08-2016, 04:10 PM
  #726
TonyBuilder
TonyBuilder's Avatar
Today I took the T-one to the field for final testing and engine run up. Filled the fuel system up then check that all is well. Engine primed itself and fired right up. Ran smooth with the auto restart on and shut down just fine. Taxi test to dial in the steering and check the breaks. Both air systems checked out and healed air all day. The bolt that was missing in the forward rotation clamp was nowhere to be found as we flipped the fuselage around to get all derbies, and any screws from construction out but no wing bolt so I'm guessing it fell out in shipping or never was there in the first place.
With the UAT full I weighed the plane, 27.6 lb dry. I then balanced at 225mm and had to add a little weight to the noes ( strip and a 1/3 of the GP lead) that I can shead if I feel it's to noes heavy. Got my waiver signed off on a buddies EPO viper
If conditions are good I may maiden tomorrow at ARCA, if not then next weekend in Waco.
TB
Old 10-08-2016, 04:59 PM
  #727
Helijet
Interesting weight. With a 120 it appears that the T1 is no different weight wise than other similar airframes ie Dolphin, UltraFlash, Bandit...
d.w.
Old 10-08-2016, 05:11 PM
  #728
TonyBuilder
I hestoricly build heavier then most! I'm guessing one could come in lighter then mine.
TB
Old 10-09-2016, 02:14 PM
  #729
rcpete347
My Feedback: (251)
rcpete347's Avatar
HI all, I maidened he T1 this past week at BITW in California,The first flight was very squirrelly with the new Jetti radio that was not set up properly, after Jim Brown completely set up the program properly the T1 flew great, a couple of recommendations.
1- set the trim steps to fine (2%)
2-CG- 250mm
3-this jet has powerful fin, so have 50% expo on fin and 70% expo on steering
4-This jet lands great, just keep the power on before tough down.
5-this jet needs aileron coupling on knife edge flight.
6- 8 to 9 minute flights are norm
7-Have 2 position gyro on flights, high on takeoff and land ( 20% and 10% on the Mercury)
8-Powered by a Jet Central Cheetah, 32lbs recommended
ID:	2185154   Click image for larger version
Old 10-09-2016, 02:21 PM
  #730
kelly vallee
What size turbine rcpete347?
Old 10-09-2016, 03:14 PM
  #731
rcpete347
My Feedback: (251)
rcpete347's Avatar
Any 32 pounder is good.
Rcpete
Old 10-09-2016, 03:56 PM
  #732
TonyBuilder
Thanks for the report. So you balanced at 250mm for the first flight? I'm set at 225mm with removable weight up front! Gunradd was sugesting 240mm for advanced flight! Is thus what you fly and what would you recommend for a first flight?
Today I did final setup with my buddy (rc test pilot). We set throws, expo, and we did some more run ups and testing of the breaks. We also tested the auto restart by pinching the line, letting the engine flame out then releasing only to have it start back up within 3-4 seconds.
We had a stiff direct cross wind all day so no maiden, hopefully next week will be good. A few minor tweaks left to do.
Rcpete, can you please list the throws you used on hi rates? Ailerons, elevator and what is your full flap setting with how much elevator mixed in? What was your ready to fly weight?
thanks.
TB
ID:	2185177   Click image for larger version
ID:	2185178   Click image for larger version
Old 10-09-2016, 04:25 PM
  #733
rcpete347
My Feedback: (251)
rcpete347's Avatar
HI, on low rates 1/2'' elev and elvater, the T-1 is really soft.
3,/4'' on aileron and 1'' on elevated ,with low expo, makes it more crisp.
Rcpete
Old 10-09-2016, 04:54 PM
  #734
JimBrown
JimBrown's Avatar
Picked up my T-One at Best In The West yesterday. Huge thanks to Dirk for going the extra mile to make sure it made it. She's in the back of my truck for the long trip home. Paint scheme is gorgeous. Will have more pics once I'm home (around Oct. 22nd.)
Looking forward to the build!
...jim
Old 10-09-2016, 07:07 PM
  #735
causeitflies
causeitflies's Avatar
Hope to get mine soon...
Old 10-10-2016, 12:08 AM
  #736
rcpete347
My Feedback: (251)
rcpete347's Avatar
Thunderbird T-1 at Best in the West
Rcpete
ID:	2185240   Click image for larger version
ID:	2185241   Click image for larger version
ID:	2185242   Click image for larger version
ID:	2185243   Click image for larger version
ID:	2185244   Click image for larger version
Old 10-10-2016, 05:52 AM
  #737
TonyBuilder
Any of you guys flying the T-one have a guess on what the stall speed is on this jet with CG set at 35%?
thanks
TB
Old 10-10-2016, 08:03 AM
  #738
gunradd
My Feedback: (9)
gunradd's Avatar
thanks
TB
Insane slow is what I would call it lol. Even with it at 220mm it was very slow.
If you watch the landing at the end of this video it gives you an idea of the speed on landing. Keep in mind this video does not show it but Franco climbed up to almost out of site then shut the engine off and dove straight down at the ground pulled up into a downwind 4 point roll and turned to final and land all dead stick.
https://www.youtube.com/watch?v=ARTCsTP4sas
Old 10-10-2016, 09:08 AM
  #739
fireblade5437
fireblade5437's Avatar
I will get one of these off Nexus Models but going to wait until the rush dies down a bit plus hopefully all mods if any will be done by the time I order one..
Looking a good alternative to the CARF Flash I was thinking of getting next..
Good seeing everyone's experience with this jet.
Alan
Old 10-10-2016, 08:12 PM
  #740
flejter1
flejter1's Avatar
Hi everyone,
I guess it is time to pump the brakes and give the T-1 factory time to catch up. Due to the huge demand of our T-1, and now shipping issues. We are going to stop taking orders at this time. The factory is getting too far behind and we don't want them to start rushing to get orders out and jeopardize the quality. It seems the pre season holidays are already causing major delays with shipping our planes and that is adding to the delivery times. The Major Holidays are right around the corner and I for see us having even bigger delays in days to come.
The current orders are still being processed as they came in, but we are going well beyond 12 weeks delivery times if I continue to take orders. We are having planes sitting in EMS warehouses upwards of 4-5 weeks now waiting for open cargo space on the planes. Keep in mind there are only so many planes leaving China everyday, and our big boxes are being bumped off to make room for a lot of little boxes.
If you want to place an order, Email me your name and contact # and I will put your name on a list as I get them. I will contact you when we get back to 4-6 weeks delivery times and see if you want to proceed, at that time, you can pay for it. No deposits will be taken, or are needed to hold your spot after you email me.
Again, for those of you that have current orders placed, they are still being processed but obviously at a much slower than anticipated pace. If at anytime you want to cancel your order for a full refund, contact me at [email protected] or call me at 626-808-6122
Thank you for understanding our position.
Regards,
Dirk & Barry
www.Pacificrcjets.com
Old 10-11-2016, 08:37 PM
  #741
Digital Pilot
Digital Pilot's Avatar
The unpack and start of another T-1
Once again, everything looks great!
Will get a JetMunts 140, Savox servos, Electronic valved and a DX18
ID:	2185446   Click image for larger version
ID:	2185447   Click image for larger version
ID:	2185448   Click image for larger version
ID:	2185449   Click image for larger version
Old 10-12-2016, 03:33 AM
  #742
TonyBuilder
Don't forget to check the rotation clamps on the fuse for missing screws and snug them up so you don't loos any
TB
Old 10-12-2016, 06:30 AM
  #743
Digital Pilot
Yeah. Already snug.. When will you fly yours?
Old 10-12-2016, 07:31 AM
  #744
TonyBuilder
This weekend if my wavier comes threw, I sent it in Saturday by email!
TB
Old 10-12-2016, 08:39 AM
  #745
Digital Pilot
Well hope you get it. Get video if you can of you flight..
Old 10-12-2016, 08:41 AM
  #746
TonyBuilder
I will have onboard cam at least, will try for static vid too.
TB
Old 10-12-2016, 08:46 AM
  #747
Digital Pilot
Ahh, on board is always cool to see. Good luck, They fly pretty effortlessly.
Old 10-12-2016, 08:54 AM
  #748
TonyBuilder
After my last nail bitter (37lb) GSTF P-47 this should be a piece of cake
This is what I had on my last inflight cam
TB
ID:	2185504   Click image for larger version
Old 10-13-2016, 04:25 PM
  #749
Desertlakesflying
My Feedback: (28)
Hope they offer an option that includes the xicoy electronic valves in the future. I'm pretty sure an extra $100 added to the price for the electronic retract and brake valves to be included wouldn't be a deal breaker. It wouldn't for me.
Old 10-13-2016, 05:49 PM
  #750
Digital Pilot
I'm pretty sure they offer them on the web site now.
