Kingtech presents the all new T1 sports jet
#2026
Still waiting for my thrust vectoring to arrive. In the meantime I got my plumbing completed, smoke installed, gps, 160n turbine, receiver and smoothflite installed. Can't go much further until I balance it and figure out were to put the batteries. I primarily went with the Smoothflite because it has a thrust vectoring feature that works with the gyro. Trying to wait for the new thrust vectoring set up so I wont have to balance twice but I may just go ahead and finish everything up
Tone.
Tone.
What receivers are you going with?
#2027
I have been flying Frsky for several years. If you look on the right side of the right side of the pic right below the fuel pump you can see the RX8R Pro receiver with a redundancy back up. I also use the R9 slim + long range receiver as a secondary receiver. That way I am flying on 2.4 gig and 900m and will always have a signal.
Tone
Tone
#2028
In the process of reading the entire thread but have a couple questions..
Is it still up to the user to install the nose gear door or does it come done at the factory with a servo installed like the Mini?
Whats the current wait time if I order today?
Really debating between the factory electric gear or electrons, how are the factory gear holding up? I’m probably going to go with Electrons.
#2029
Tone
Tone
#2031
Before I ordered mine, I was frustrated by the 16+ week wait time. Initially, they would not even take my order. So I ordered a different plane. Then once I flew the rather disappointing different plane, I decided to order the T1. Now, having flown them both, a lot, I wish I had just ordered the T1 in the first place. That being said, once I did order it, I was given a delivery period of ~12 weeks. They beat that period by a couple days. Dirk is honest and upfront with you about delivery dates. He won't give you an unrealistic promise and then let you wonder what is going on. I even got an occasional update from him.
The servo was installed on my T-1's nose gear door. The linkage was a little weird and put a lot of stress on the door's hinge. My hinge broke after a few operations. So I ended up replacing the hinge and then attaching the linkage to the door itself, versus the hinge arm. Now, I can pull that door tightly shut w/o pulling on that fragile hinge arm. BTW: The exact hinge replacements can be had at Ebay.
It is a great flying plane and is built well. It is well worth the wait. I can't tell you how many pilots have came up to me and said they wished they had waited for one.
#2033
My Feedback: (46)
Yeah, he’s far from me and local pickup only...
Plus I’m pretty picky, I want it to be perfect.
I have a T-1 Mini I ordered through Dirk.. it’s just the long wait that sucks but I already know it’s worth it and the quality is amazing.. it’s worth it for sure. March 2020 just seems like a really long ways away!!
I was also hoping for a Black Friday sale but if they are that backed up fat chance is that..
#2034
thanks
Tone
#2035
My Feedback: (9)
KY
I ordered mine in July. I emailed Dirk a couple weeks ago and he said it was supposed to be going into paint. That was at the 12 week point, I am in the dark as to how long it takes from that point to
my doorstep and I haven’t heard anything since, so I think it could be awhile. This is not so much a complaint as a heads up that 8 weeks is probably not a realistic estimate at the present time. It is what it is and as long as it’s done right that’s fine just a heads up for planning purposes
#2040
My T1 did have the nose door installed but did not come with a servo, however I received my T1 in June of 2017 so that may have changed in the past 2+ years since. All three of my T1 minis did come with a servo already installed on the nose gear door even though none of the three were the PNP version. -Tom
#2041
My Feedback: (53)
The T-1 I have seen (mine is 2017 as well) that were received this past summer have a lot of different things done to them...
As for the servo arm length....I have 1" except on the flaps I'm using ¾" ....but since the flaps are now internal versus external linkage unlike mine....they might need a different length.
#2044
My Feedback: (46)
Can anyone post a pic of the internal flap setup? Just curious to see how it’s setup. Good thing about the wait is I have plenty of time to get the rest of the equipment and plan out what I want.
I think I’m going to give the promodeler servos a try, my buddy just got three today and says they are really impressive. I’ve been wanting to try them for a long time.
I’ve never setup smoke before, how is the pump usually powered? Separate battery? I didn’t install smoke in my Mini.
#2045
My Feedback: (53)
For the smoke pump.....depend on the pump...I normally used the KingTech pump, and I add a small 2s 1100mAh battery just for it.....and shared the #2 RX with the retract, I’m on Jeti CB200 so when I land my battery are pretty much equal, the retract doesn’t actually take much....I have never actually look to see how much the smoke pump takes...but that 1100 is good for smoke with at least 5 flights (what I normally do in one day) I only fill the tank to half for most flights.
#2047
Thanks for posting the pics of the hidden push rod setup. Does the hidden push rod config have any mechanical leverage advantages/disadvantages over the exposed push rod config? - Tom
#2048
My Feedback: (53)
As long as they are well designed and put together....they are equally suitable for the task, a good friend of mine flew his newer T-1 and they are hidden....work still fine after many flights..
