Reload this Page >
Aviation Design Mini Diamond
Old 01-07-2017, 08:35 PM
  #51
F1 Rocket
Originally Posted by scoeroo
which style is that red ? it looks metallic ? how bright is it ? what does the whole plane look like ?
Its a dark metallic red. I'll post some photos of the assembled plane once I everything in one room.
Old 01-07-2017, 08:41 PM
  #52
F1 Rocket
Pitot tube and Jeti MSpeed sensor installed in the horizontal stab assembly. This is a nice position as it keeps the pitot protected. It was a bit tight/tricky to get everything in place but I'm happy with the results. Now to get the second one done.
ID:	2195951   Click image for larger version
Old 01-20-2017, 05:24 PM
  #53
leemkl06
Quick Update! My intairco gear came in so I plumbed my system and will run the turbine tomorrow to check the connections. Everything is good to go except for my gear!
ID:	2197562   Click image for larger version
ID:	2197563   Click image for larger version
ID:	2197564   Click image for larger version
ID:	2197565   Click image for larger version
Old 02-17-2017, 04:14 AM
  #54
leemkl06
Just FYI for everyone that was waiting for the E-Retracts, they're now available. Mine is on it's way across the pond! Can't wait to get some legs on this jet!
Old 02-17-2017, 04:08 PM
  #55
F1 Rocket
We received the electric gear this week. The mains are a fair bit larger than the original air gear and required the mounting area to be opened up. The nose gear bolts right in place.
ID:	2201616   Click image for larger version
ID:	2201617   Click image for larger version
ID:	2201618   Click image for larger version
Old 02-17-2017, 05:17 PM
  #56
DrV
DrV's Avatar
That Looks great Danny. thanks for sharing.
Old 02-17-2017, 07:37 PM
  #57
levendis
Any flight reports yet, gentlemen?
How underpowered do you think a JetMunts VT80 would be the Mini Diamond?
Old 02-17-2017, 10:58 PM
  #58
LA jetguy
LA jetguy's Avatar
Danny at Rocket Factory is assembling two carbon mini diamonds at the same time. They will be both powered with JM M140XBL. We had to upgrade the factory pipe to a stronger pipe to accommodate the bigger turbine.
All being well we should have flight results by Mid March...
DrV and I appreciate all the hard work of Danny and the team at Rocket Factory..
David
Old 02-18-2017, 04:16 AM
  #59
Bob_B
Bob_B's Avatar
Strong work as usual Danny!
Old 02-18-2017, 05:54 AM
  #60
leemkl06
AD specs a 70N to 120N Turbine so I'm sure it would fly. My preference with jets is to stay on the upper end of the spec (you never know when you'll need that extra umph).
Old 02-18-2017, 06:04 AM
  #61
leemkl06
One other detail I forgot to mention on the e-retracts, I really wanted a gyro brake assist controller like the Electron GS-200 but I found out that it wasn't compatible with the new retracts for the Mini. After a couple of emails with Gaspar, he informed me that the Xicoy LCG15 will work with the Mini retracts and pretty much has the exact same features. I have one coming for my build
Old 02-18-2017, 06:51 AM
  #62
scoeroo
My Feedback: (9)
scoeroo's Avatar
Very true - In thrust we trust .....
Old 02-18-2017, 09:24 AM
  #63
F1 Rocket
Yup. Merlin 140's in the two I'm building now
ID:	2201686   Click image for larger version
Old 02-18-2017, 10:51 AM
  #64
LA jetguy
LA jetguy's Avatar
"Mini" is relative.... Compare to the big diamond, this jet is a mini... My other "minis" have 45N and 60N size turbines and soon another one with M70.
Old 02-20-2017, 07:10 AM
  #65
scoeroo
My Feedback: (9)
scoeroo's Avatar
Looks like it was made for the merlin - neat install on the rails , was any relieving necessary (dremel work) ?
Old 02-20-2017, 07:57 AM
  #66
leemkl06
These were just delivered!
ID:	2201940   Click image for larger version
Old 02-20-2017, 08:15 AM
  #67
F1 Rocket
A bit of material needed to be removed from the rails to clear the rear of the motor and the ears on the motor mount. Also the inlet had to be trimmed forward to clear the starter.
Old 02-22-2017, 10:51 AM
  #68
leemkl06
Well the Diamond has the retracts installed! Still need to complete my wiring harness but it was nice seeing her standing on her own. I must say that I'm impressed with how accurate AD was with with the CG. With their recommended turbine (Merlin 100 XBL and 500g of lipos up front, it perfectly hit the recommended CG (done with my Xicoy CG machine). Again these are preliminary numbers but she comes in at 22.6 lbs with an empty main and full UAT.
ID:	2202317   Click image for larger version
ID:	2202318   Click image for larger version
ID:	2202319   Click image for larger version
Old 02-24-2017, 06:46 PM
  #69
leemkl06
Made some decent progress! I can see the light at the end of the tunnel for my winter build I completed my radio board, wired the rest of the jet and am at the point of programing equipment and checking throws. Once I figure out my Gyro assisted gear controller, I should be ready for taxi test in the next couple of weeks.
ID:	2202706   Click image for larger version
ID:	2202707   Click image for larger version
ID:	2202708   Click image for larger version
ID:	2202709   Click image for larger version
ID:	2202710   Click image for larger version
ID:	2202711   Click image for larger version
ID:	2202712   Click image for larger version
ID:	2202714   Click image for larger version
Old 03-15-2017, 07:26 PM
  #70
LA jetguy
LA jetguy's Avatar
Today we maiden both Carbon version Mini Diamonds assembled by Danny at the "Rocket Factory". I have the red metallic once and Mike (DrV) has the white version. The take-off roll was very smooth and the jet lifted gently and climbed nicely. It needed three clicks of down elevator and two clicks of left aileron and the jet was cruising at about 180 mph at 60% throttle.
It flew as if it was on rails and very solid. You just have to get used to the look of it in the air. The landing was uneventful and slowed down nicely with 95mm flaps.
As you can see from the pictures of the electronic and installation Danny and the team at the Rocket Factory did an "AWESOME" job. I would like to thank Danny and the team for 'another' successful jet... THANKS A LOT DANNY..
We had a professional photographer take inflight pictures. I will post those once i get them.
David
ID:	2205492   Click image for larger version
ID:	2205493   Click image for larger version
ID:	2205494   Click image for larger version
ID:	2205495   Click image for larger version
ID:	2205496   Click image for larger version
ID:	2205497   Click image for larger version
ID:	2205498   Click image for larger version
Old 03-15-2017, 07:53 PM
  #71
DrV
DrV's Avatar
Thanks for posting David. We had an awesome day. Thank you Danny for the excellent build.
Old 03-16-2017, 05:02 AM
  #72
scoeroo
My Feedback: (9)
scoeroo's Avatar
Nice -
What does she do full tilt with the 140 ?
Old 03-16-2017, 11:25 AM
  #73
LA jetguy
LA jetguy's Avatar
Nice -
I'm sure not more than 199.9999999 mph
Old 03-17-2017, 08:53 AM
  #74
scoeroo
My Feedback: (9)
scoeroo's Avatar
I see you did some thrust pipe mods - upgraded
For what reasons ? was the original too flimsy ?
Thx.
Old 03-17-2017, 08:57 AM
  #75
gooseF22
gooseF22's Avatar
Cool jets.. nice build.. nice job guys!!..
