Reload this Page >
All New KingTech EPO Jets, by HSD
Old 01-28-2017, 07:01 PM
  #176
LA jetguy
LA jetguy's Avatar
Wink
After getting a call from Dirk that the container had issues cleaning customs, he suggested a direct order (with a small shipping fee) and within two weeks a big box is delivered to my house. The same day I pickup a K60 G2 from Kingtech offices. A BIG THANKS to Dirk for organizing all of that.
After unpacking and starting assembly within 4.5 hours the jet was ready to fly. It would have taken much less time if this was my second time assembling this jet. The equipment board installation and the gluing of the rails to hold the board took the longest time. This jet has a Cortex Pro connected to a Jeti Receiver through a single wire in serial mode (EX Buss).. Thanks to Danny (DemonAero)
David
ID:	2198668   Click image for larger version
ID:	2198669   Click image for larger version
ID:	2198670   Click image for larger version
ID:	2198671   Click image for larger version
ID:	2198672   Click image for larger version
ID:	2198673   Click image for larger version
ID:	2198674   Click image for larger version
Old 01-29-2017, 07:23 PM
  #177
oukenfold
David
LA jet guy can you plz post more picture of your setup plz, you smoke pump and all the stuff plz, did the turbine came with the fod screen? what oil do you plan to use and how is the mix thanks.
Old 01-29-2017, 07:30 PM
  #178
Desertlakesflying
My Feedback: (28)
If you are going to run the Kingtech engine, or any turbine IMHO.
Oder the Kingtech oil from Pacific RC Jets it is $90 for the two gallons shipped, and the bottles are marked with the amount (5%) or 1 quart for 5 gallons of fuel. 2 gallons of oil should take care of 40 gallons of fuel The Kingtech oil has the additives to keep the slime from growing and causing blockages.
I have been running it in my old JetCat P-120 and it runs far better than the JetCat oil I had before.
https://www.pacificrcjet.com/collect...-oil-2-gallons
Old 01-29-2017, 07:45 PM
  #179
oukenfold
thanks Desertlakesflying... i will buy that oil and yes i buy allready the k60 with the navy viper jet, because the ferrari logo problem, the ferrari was my first choice.
Old 01-29-2017, 07:52 PM
  #180
Desertlakesflying
My Feedback: (28)
You won't be disappointed. Just make sure you use the proper mix. 5% oil over all
Or if you are doing 5 gallons..... 1 quart oil to 5 gallons fuel.
If my math is correct it is 947milliliters oil to 18.92 liters of fuel. I'm sure someone will correct me that that knows those numbers.
Old 01-29-2017, 07:59 PM
  #181
causeitflies
causeitflies's Avatar
There are no additives in the oil to control slime growth. You will have to add that separately.
Old 01-29-2017, 08:38 PM
  #182
Zeeb
My Feedback: (41)
Zeeb's Avatar
Oh man, everyone has been so nice on this thread. Why turn it into an "oil" thread?
Old 01-29-2017, 08:47 PM
  #183
causeitflies
OK. My Navy Viper is scheduled to arrive Friday
Old 01-29-2017, 09:54 PM
  #184
Digital Pilot
Digital Pilot's Avatar
Have A Look guys!!
The Kigtech EPO F-16 In the AK scheme. Here are a bunch of un-boxing and airframe assembly photos. Should have the K60 engine in a couple days and will document the install along with the remaining electronics.
This jet went together effortlessly and in about 30 mins. The packaging is amazing and you can flip the top of the foam box over and use it as an assembly cradle
ID:	2198886   Click image for larger version
ID:	2198887   Click image for larger version
ID:	2198888   Click image for larger version
ID:	2198889   Click image for larger version
ID:	2198890   Click image for larger version
ID:	2198891   Click image for larger version
ID:	2198892   Click image for larger version
ID:	2198894   Click image for larger version
ID:	2198895   Click image for larger version
ID:	2198896   Click image for larger version
ID:	2198897   Click image for larger version
ID:	2198898   Click image for larger version
ID:	2198899   Click image for larger version
ID:	2198900   Click image for larger version
ID:	2198902   Click image for larger version
ID:	2198903   Click image for larger version
ID:	2198904   Click image for larger version
ID:	2198905   Click image for larger version
ID:	2198906   Click image for larger version
ID:	2198907   Click image for larger version
ID:	2198908   Click image for larger version
ID:	2198910   Click image for larger version
ID:	2198911   Click image for larger version
ID:	2198912   Click image for larger version
ID:	2198913   Click image for larger version
ID:	2198914   Click image for larger version
ID:	2198915   Click image for larger version
ID:	2198916   Click image for larger version
ID:	2198918   Click image for larger version
ID:	2198919   Click image for larger version
ID:	2198920   Click image for larger version
ID:	2198921   Click image for larger version
ID:	2198922   Click image for larger version
ID:	2198923   Click image for larger version
ID:	2198924   Click image for larger version
ID:	2198926   Click image for larger version
ID:	2198927   Click image for larger version
ID:	2198928   Click image for larger version
ID:	2198929   Click image for larger version
ID:	2198930   Click image for larger version
ID:	2198931   Click image for larger version
ID:	2198932   Click image for larger version
ID:	2198934   Click image for larger version
Old 01-29-2017, 09:55 PM
  #185
Digital Pilot
ID:	2198936   Click image for larger version
ID:	2198937   Click image for larger version
ID:	2198938   Click image for larger version
ID:	2198939   Click image for larger version
ID:	2198940   Click image for larger version
ID:	2198941   Click image for larger version
Old 01-29-2017, 09:59 PM
  #186
LA jetguy
LA jetguy's Avatar
I fly a lot and I go through several gallons of Diesel per week. I buy Shell Turbo T32 in a 5 gallon pail and transfer into quarts. I have over ten Jets Munt turbines and two Kingtech all installed in airframes. JM requires 3% oil and KT 5%. I just use a quart of Oil for 5 gallons of Diesel its easier.
As for the smoke pump it is already installed and plumbed ready to go and the smoke nozzle is in place. FOD screen does not come with engine and you have to get that as well as batteries.
I decided to go with two 2 cell Lipo for servos and lights and a 3 cell LiFe for the turbine. The onboard controller regulates all control surface power to 6.0 Volts (5.0 volts optional) so I think less heat will built up from 2 cell Lipo (7.4V) compare to a 3 cell LiFe (9.9V), but Kingtech turbines runs happier on a 3 cell LiFe.
David
Old 01-29-2017, 10:02 PM
  #187
DrV
DrV's Avatar
Very nice DP. Can't wait to see it fly.
Old 01-30-2017, 05:34 AM
  #188
garyhyde
How did you find that out? Where did you get it from?
Old 01-30-2017, 05:52 AM
  #189
garyhyde
How did you find out when your airplane arrives? Where did you order airplane?
Old 01-30-2017, 07:07 AM
  #190
Bob_B
Bob_B's Avatar
they will send you an email with tracking info
Old 01-30-2017, 08:31 AM
  #191
causeitflies
I think ordered right before Christmas. Received tracking number Saturday.
Old 01-30-2017, 08:32 AM
  #192
causeitflies
I was on the pre-order list for a long time.
Old 01-30-2017, 09:22 AM
  #193
oukenfold
thanks men i all ready have my tracking number, it maybe arrive to me 4 feb, buts its a navy, and i see it are the same, thats why i ask you for more picture of your setup, because this is my first turbine jet ever, and a bit worry because its all new setup, and i want to know were a will install all, i have an eagle tree guardian 3d gyro, in all my other planes i gues will heklp me with this viper jet.
Old 01-30-2017, 10:17 AM
  #194
Desertlakesflying
My Feedback: (28)
Actually Dirk said there was, so I'll take his word over yours, thanks.
Old 01-30-2017, 12:07 PM
  #195
SECRET AGENT
My Feedback: (18)
SECRET AGENT's Avatar
If there's anti-slime additives in KT oil then why is there slime in my fuel? All I use is KT oil and love it, but I had to shock my fuel with Biobor recently due to slime.
I think you might be mistaken on that.
Old 01-30-2017, 03:11 PM
  #196
LA jetguy
LA jetguy's Avatar
I add Biobor equivalent for 100 gallons to my 5 gallon pail of oil... Even though pump diesel has enough additives to prevent algae or slim since they are stored in under ground tanks.
To my knowledge only a JetCat ECU is susceptible to static electricity and the fuel used requires "Anti-Static" additive ... Xicoy ECU and Kingtech ECU are not susceptible to static issues.
Old 01-30-2017, 04:08 PM
  #197
Helijet
Hmmmm..negative on the JetCat ecu.
Don't use and have never used the antistatic coolaid in ANY of my turbines since '97
Dean W.
Old 01-30-2017, 04:44 PM
  #198
Desertlakesflying
My Feedback: (28)
Dean W.
No problems with mine either and it's an older one. Still run anti-static tubing from pump to turbine because it seems to fit he festo fittings better
Old 01-30-2017, 08:35 PM
  #199
Zeeb
My Feedback: (41)
Zeeb's Avatar
I hate to put a pin in your bubble but that's not true....
Being a retired Firefighter, I was around a bunch of diesel powered trucks. The reserve engines (pumper trucks) don't get used a whole lot even though they are pulled out of the bays at least once a week.
On one particular occasion, one of 'em would not start and we had to have the shops come get it on a trailer. The fuel system was plugged with algae, or as I like to refer to the stuff; bugs.
Jet-A used to have some anti-fungals included and it was most commonly called "Prist". Some A/C's required Prist at every fillup as it was an anti-icing, anti-static agent as well. Most notably the LearJets.
So now, if you want an anti "slime" agent, you have to add it to the fuel yourself. I add it to my diesel powered pickup since it's not used a whole lot. I simply ad the JetCat oil to my Kerosene for my models and that fuel is kept in the translucent jugs so you can see if any bad stuff starts growing. So far I've not had an issue but I've got the filters capable of cleaning it out of the fuel if I see any that's developed.
Old 01-31-2017, 08:06 AM
  #200
Digital Pilot
Anyone here building or flying the F-16?
