Reload this Page >
Maj. Woody's Ultra Flash
Old 03-07-2017, 04:13 PM
  #201
MaJ. Woody
My Feedback: (28)
MaJ. Woody's Avatar
I spent some time looking at the fiberglass inserts for the wheel wells and soon determined these were not well suited for this jet. I decided on a different approach. First thing I did was trim the well.
ID:	2204387   Click image for larger version
ID:	2204388   Click image for larger version
ID:	2204389   Click image for larger version
Old 03-07-2017, 04:20 PM
  #202
MaJ. Woody
My Feedback: (28)
MaJ. Woody's Avatar
My idea was to box in the well with 1/16" aircraft grade balsa. I fit the sheets with the grain vertical which will provide the most strength. Be sure to locate and drill holes of your airlines. I saturated the landing gear blocks, bulkheads and my sheeting with thin CA then sanded it smooth with fine sand paper in preparation for paint.
ID:	2204391   Click image for larger version
ID:	2204392   Click image for larger version
ID:	2204393   Click image for larger version
ID:	2204394   Click image for larger version
ID:	2204395   Click image for larger version
ID:	2204396   Click image for larger version
ID:	2204397   Click image for larger version
ID:	2204399   Click image for larger version
Old 03-07-2017, 04:24 PM
  #203
MaJ. Woody
My Feedback: (28)
MaJ. Woody's Avatar
Next I worked on the retract cover. I measured and marked the location of the cutout. I made this cut very carefully ensuring tight clearance all the way around the trunion. This gives the best finished appearance.
ID:	2204402   Click image for larger version
ID:	2204403   Click image for larger version
ID:	2204404   Click image for larger version
ID:	2204405   Click image for larger version
ID:	2204406   Click image for larger version
ID:	2204407   Click image for larger version
Old 03-07-2017, 04:30 PM
  #204
MaJ. Woody
My Feedback: (28)
MaJ. Woody's Avatar
Now I had to figure out how to mount that landing gear door. That flat slab on the side of the Prolink strut was talking to me. What I did was cut a bass block to the size of the slab side. Next I spent a lot of time hand sanding the proper angle on the block so that my landing gear door would fit tight in the recessed molding of the wing. Clamping my T-Bar to the table allowed me to use two hand on the block and apply pressure to the right areas to get the proper angle. Lots of sanding and fitting. When done, I marked my centers on the block.
ID:	2204411   Click image for larger version
ID:	2204412   Click image for larger version
ID:	2204413   Click image for larger version
  #205
warbird_1
My Feedback: (61)
warbird_1's Avatar
Originally Posted by MaJ. Woody
Here is what the gear looks like temporarily mounted in the wing. I positioned my retracts so the tires were as far forward in the well as I could get without touching. My thought process was that when the springs settle in after a few landings, the gear will remain slightly pivoted bringing the wheel into the center of the well. If centered initially, the wheel may bind when the springs relax.
hey dom. why didn't you use Sullivan clevises on the elevator linkage?
Old 03-07-2017, 04:42 PM
  #206
MaJ. Woody
My Feedback: (28)
MaJ. Woody's Avatar
With the holes marked, I put the block in a vise and headed for the drill press. Once the holes were drilled in the block I had to disassemble my strut, attach the block to the strut with double sided tape then finally put the whole assembly back into the vise for drilling. I then tapped the holes for a 2-56 machine screws. Reassemble the strut and bolt everything back up in the wing. Now put the block onto the strut with double sided tape on both sides of the block. Now put the door in place. Remove the block from the strut but leave it on the door. Now transfer the holes from the block to the door. Sand the gear door and glue the block to the door. I needed to do some trimming on the wing recess for the door. Here you can see everything bolted up and the door is absolutely tight in the recess and the door very secure. By the way all those screws were painted the proper color. you will see that when I do the final assembly.
ID:	2204415   Click image for larger version
ID:	2204416   Click image for larger version
ID:	2204417   Click image for larger version
ID:	2204418   Click image for larger version
ID:	2204419   Click image for larger version
ID:	2204420   Click image for larger version
ID:	2204422   Click image for larger version
ID:	2204424   Click image for larger version
ID:	2204425   Click image for larger version
Old 03-07-2017, 04:45 PM
  #207
MaJ. Woody
My Feedback: (28)
MaJ. Woody's Avatar
By the way, that gap between the door and the retract cover is a must. Any smaller and the door will bind on the cover when the gear is deployed.
Old 03-07-2017, 04:50 PM
  #208
MaJ. Woody
My Feedback: (28)
MaJ. Woody's Avatar
Everything was then given a couple coats of flat white paint. As stated earlier, all screws were painted the appropriate color as well. Now its time for final assembly. I have to tell you this was a long process. I have over 45 hours on the wing alone! I estimate I will have closer to 50 on the wing when I am done. Hard to believe that it takes me as long to do the wing as some people take to build the entire jet.
ID:	2204429   Click image for larger version
ID:	2204430   Click image for larger version
ID:	2204431   Click image for larger version
ID:	2204432   Click image for larger version
ID:	2204433   Click image for larger version
ID:	2204434   Click image for larger version
Old 03-07-2017, 04:54 PM
  #209
MaJ. Woody
My Feedback: (28)
MaJ. Woody's Avatar
Hi Griz. Belive me I stressed over not being able to use the Sullivan clevises with the keeper. I had to decide between the beefy 3mm rod that was included or going down in size to 4-40 in order to use the Sullivan Clevises. I wound up using tygon on the stock clevises and painting it. you wont see it at 199.9 MPH !!
Old 03-07-2017, 04:55 PM
  #210
Instructor
My Feedback: (16)
Instructor's Avatar
Hi MaJ. Woody,
Good to see you back. Is it possible to find 2-56 screws with counter sunk heads? This way they would fit flush with the doors since the bass wood block is glued to the door. Also, if you beveled the gear cover and the door opposite, the door would fit closer. Just a thought.
larry/Instructor
Old 03-07-2017, 05:40 PM
  #211
MaJ. Woody
My Feedback: (28)
MaJ. Woody's Avatar
Hi Larry.
I did bevel the gear doors and they do fit really tight and perfectly flush with the wing. Great idea on the counter sunk screws. I do have these but did not use them as I originally did not plan to glue the block to the door. I guess I am off to paint some more screw heads!
Old 03-08-2017, 06:51 AM
  #212
smiller
Looking great Dom !!
Scott
Old 03-08-2017, 07:45 AM
  #213
MaJ. Woody
My Feedback: (28)
MaJ. Woody's Avatar
Thanks Scott. Looking forward to getting some more work done before I go on vacation next week. Taking my daughter Disney and we will also be headed to Florida Jets while we are there!
Old 03-08-2017, 05:21 PM
  #214
MaJ. Woody
My Feedback: (28)
MaJ. Woody's Avatar
I did the final installation of one of my landing gear today. I used lock washers and flat washers along with loctite to secure the retract to the mount. Note the minimal amount of air line in the wheel well. I used white for the forward position to disguise its appearance. It took me a few tries to figure out how to route my brake line. The tight clearance I have between the trunion and retract cover wont allow for even a zip tie to clear. The brake line is very secure being routed behind the retract bolts and under the cover. It has to stay put. The cover was screwed in place with thick CA on each screw. The gear door was secured with loctite on the screws. I tested the gear retraction / extension and it is very smooth, operates with minimal air pressure and has no binding.
ID:	2204529   Click image for larger version
ID:	2204530   Click image for larger version
ID:	2204531   Click image for larger version
ID:	2204532   Click image for larger version
ID:	2204533   Click image for larger version
ID:	2204534   Click image for larger version
ID:	2204535   Click image for larger version
ID:	2204537   Click image for larger version
ID:	2204538   Click image for larger version
ID:	2204539   Click image for larger version
ID:	2204540   Click image for larger version
ID:	2204541   Click image for larger version
ID:	2204542   Click image for larger version
Old 03-08-2017, 05:27 PM
  #215
MaJ. Woody
My Feedback: (28)
MaJ. Woody's Avatar
Tomorrow I will install the other gear, secure the wing tank hatch then polish the wing. Using the brush attachment on my shop vac during construction has caused some minor scratches to the lower wing surface. I tested some polish on a section of the wing and the scratches come right out leaving a nice shine to boot. I'll take some photos of the process.
Old 03-08-2017, 06:09 PM
  #216
mr_matt
My Feedback: (10)
mr_matt's Avatar
To secure brake hose, I have used small lengths of brass tube, gooped to the gear leg on very tight installs. Nice modeling you are doing thanks for posting
Old 03-08-2017, 06:19 PM
  #217
MaJ. Woody
My Feedback: (28)
MaJ. Woody's Avatar
Wow that is a great idea Matt!! I love goop because it is very strong and stays put yet you can peel it off if needed. Aluminum tubes would match my gear also. If that zip tie of mine gives me trouble, I am going with your awesome tube idea. Thanks for the reply and the compliment.
Old 03-08-2017, 06:41 PM
  #218
causeitflies
causeitflies's Avatar
Dom, you're an animal!!
Old 03-08-2017, 06:58 PM
  #219
AEROSHELDON
My Feedback: (99)
AEROSHELDON's Avatar
Thank you for taking the time to do this build thread.
Old 03-09-2017, 03:07 AM
  #220
MaJ. Woody
My Feedback: (28)
MaJ. Woody's Avatar
Thanks Mark and Aerosheldon.
Old 03-11-2017, 09:19 AM
  #221
MaJ. Woody
My Feedback: (28)
MaJ. Woody's Avatar
I just installed the other retract and thought I would show you how I routed the airlines. Start in the wheel well then use the existing holes in the bulkheads back to the servo hatch and then up trough the spar.
ID:	2204891   Click image for larger version
ID:	2204892   Click image for larger version
ID:	2204893   Click image for larger version
Old 03-11-2017, 09:24 AM
  #222
MaJ. Woody
My Feedback: (28)
MaJ. Woody's Avatar
I left some extra length to my airlines so that if I needed to remove the retract I would have the required slack. I glued in a block to accept a sheet metal screw which secures the fuel tank hatch. After drilling a hole for the wires and lines, I installed a rubber grommet to protect the lines. All servo extension have been labeled.
ID:	2204895   Click image for larger version
ID:	2204896   Click image for larger version
ID:	2204897   Click image for larger version
ID:	2204898   Click image for larger version
ID:	2204899   Click image for larger version
Old 03-11-2017, 09:26 AM
  #223
MaJ. Woody
My Feedback: (28)
MaJ. Woody's Avatar
The wing is now complete and safely stored in the included wings bags.
ID:	2204901   Click image for larger version
ID:	2204902   Click image for larger version
Old 03-11-2017, 09:59 AM
  #224
Dblex
My Feedback: (81)
Dblex's Avatar
Question...
why did you choose air over electric retracts? " I'm trying to decide between the dreamworks options "
what airline connectors are those?
wing tank? Or no...?
thanks!
Old 03-11-2017, 10:12 AM
  #225
afterburner
My Feedback: (18)
afterburner's Avatar
Great build thread so far Dom. I would suggest you work on getting that brake line further out from the tire. I know you are meticulous in the build and maintenance but it really only takes one takeoff roll to chafe through the brake line and have nothing on the landing. Been there and done that on my UF as well as other jets. Even a strip or two of clear packing tape around the line will give you more time to catch a chafing issue and then go for a more permanent fix. I've used those Tidy Strips from Model Aviation Products. Cut a single clip off, cut up the bottom in a hatch pattern with an x-acto knife then used carbide bit in a dremel to roughen up the aluminum of the strut where I wanted to glue the Tidy strip. I've used Zap a dap a goo to secure it and it holds pretty good.
