Reload this Page >
Sukhoi SU-37 "Terminator"
Old 01-10-2017, 12:58 PM
spaceman 01
My Feedback: (44)
spaceman 01's Avatar
I have both . The 27 and the 35 from AD also the Diamond , Eric makes a very good product.
Anton do we get a discount if we pre order on your SU 35?
Old 01-10-2017, 12:59 PM
DelGatoGrande
My Feedback: (23)
DelGatoGrande's Avatar
Trying to get the angles right... test fit , new spacers ,test fit ,new spacers....test fit.... for weeks .
I read somewhere in CARF manual that you can adjust the link to get the angles right..i assure you it is not the way to go...what a PITA
[IMG][/IMG] [IMG][/IMG][IMG][/IMG][IMG][/IMG]
Old 01-10-2017, 01:11 PM
FalconWings
My Feedback: (57)
FalconWings's Avatar
Originally Posted by DelGatoGrande
Who makes F-35?! Maybe you mean F-22?
No I actually fly a 35. Both the F-22 and the F-35 could take the Su-37 at distance. F-22 could survive at close encounter. F-35 can't maneuver like the Su-37 so it would rely on it's bag of tricks. In any case, they could all take each other, but with a Defense spending ratio of 12:1, I bet on my guys. :-)
Old 01-10-2017, 01:13 PM
DelGatoGrande
My Feedback: (23)
...but its now its absolutely perfect . Bear in mind the model is with out the weight of the components. Once everything is in ,the nose leg will be more compressed,
and it will look right.
FalconWings
My Feedback: (57)
good looking Terminator!
Old 01-10-2017, 01:19 PM
  #31
DelGatoGrande
My Feedback: (23)
Now the mains are big and heavy. I solved the problem by adding a second cylinder with only the "up" line connecting to it .
[IMG][/IMG]
Old 01-10-2017, 01:21 PM
  #32
DelGatoGrande
My Feedback: (23)
..i go the other way.... first ill make it fly right and after i will paint it
Old 01-10-2017, 01:24 PM
  #33
DelGatoGrande
My Feedback: (23)
And the problem wasnt only setting up the angles of the gear.The main dubro wheels are *****.
They cant handle the forces of a landing or take off !! and you can loose control at high speed and crash it big time like the guy in this video
https://www.youtube.com/watch?v=i5m4Za-Yfsk&feature=youtu.be
Old 01-10-2017, 01:51 PM
  #34
DelGatoGrande
My Feedback: (23)
The gear mounting woods are very strong . But i like to build things once. So G10 sides got glued as reinforcments with hysol.
Still light but now.. waaaaay stronger.
Old 01-10-2017, 01:53 PM
  #35
DelGatoGrande
My Feedback: (23)
Bear in mind that this are also engine mounts .And the engine it self contributes of the strength of the main gear
Old 01-10-2017, 02:05 PM
  #36
DelGatoGrande
My Feedback: (23)
Now back to the cr@p dubro tires. .. they went straight to the bin.
There is no other tire in this dimensions out there that can keep up with the load and the forces involved in this model.
So...i had to make mine
Photos of making tires here :>> http://www.petame.gr/forumv/showthread.php?t=9490
Old 01-10-2017, 07:51 PM
  #37
DrScoles
My Feedback: (18)
DrScoles's Avatar
Anton, you just made my night! I inquired to CARF if they would add canards and make a one seater of their Su-27, they said no. I can't stand the bubble top canoey of the two-seater. Sure would be nice to make it 1/7th. This plane is 71' long... transporting a 1/6 version is gonna be yuuuuuuge.
Originally Posted by pilot tw
George, nice Jet , the Su-35 1/6 under my development now, hope test fly it on end of 2017 soon !
Old 01-11-2017, 10:38 AM
  #38
DrScoles
My Feedback: (18)
DrScoles's Avatar
The AD kit is a lot of work.. they don't do an art do they? I like that size
Old 01-11-2017, 11:15 AM
  #39
Mikey5547
I love the large planes skymaster are bringing out but I agree with you on size. Hopefully skymaster will do some 2m-2.5m size planes as well cause I cant transport 3m size models sadly
Old 01-11-2017, 11:18 AM
  #40
spaceman 01
My Feedback: (44)
DrScoles, I have an AD -27 for sale in here check the classifieds. George, I was the pilot in the video that you posted earlier and it didn't crash, it was a safe landing.
thank you,
Nick
Old 01-11-2017, 11:29 AM
  #41
DrScoles
My Feedback: (18)
DrScoles's Avatar
I bought this just to transport planes. My 1/4 yak fits, but man is it hard to put in and take out. It surprises me that the market is dictating larger and larger planes. Not everyone has trailers and vans. Anton, please make a 1/7th single seat/canard Sukhoi!
ID:	2196340   Click image for larger version
Old 01-11-2017, 12:35 PM
  #42
Kevin_W
Now back to the cr@p dubro tires. .. they went straight to the bin. There is no other tire in this dimensions out there that can keep up with the load and the forces involved in this model. So...i had to make mine Photos of making tires here :>> http://www.petame.gr/forumv/showthread.php?t=9490
That aluminum tire plug looks very familiar! Looks like you modified my procedures here and there, but it's nice to see that my tire making thread helped someone out.
I noticed (google translated just enough for me to read about 1/4 of the words) that you mixed micro balloons into the urethane for the tires. I assume you did that to try to make the tires lighter. My ME262 tires were very heavy, and I never really found a good solution (although I didn't think of micro balloons).
How did that solution work out?
Do you think the addition of the micro balloons will affect how the tire tread wears during use?
Great job! Looks like it will be a nice jet when finished.
Old 01-11-2017, 08:51 PM
  #43
wojtek
My Feedback: (73)
wojtek's Avatar
Looks like you may have some old/bad hysol .. its clumped up pretty bad there!
Old 01-12-2017, 05:36 AM
  #44
DelGatoGrande
My Feedback: (23)
I do not use the mixing nozzles.I always mix on paper first well and then i put the premixed hysol in a siringe to work as you can see in the photos. Try it.
My hysols from Dreamworks are not even close to expiration date.
Plus its easy to check by trying scraching them with the tip of blade.Mine are hard like a glass!
Bear in mind that this work was six years ago and my work has already been proved to be reliable!
Build to last!
Old 01-12-2017, 05:56 AM
  #45
DelGatoGrande
My Feedback: (23)
Hi there Kevin, thank you!
I put photos of your aluminium plug to show an example of excelent craftmachip!
I used the original dubro tire as plug!
I spent more than a month tests and yes final is strong and light!
Yes use microbaloons! Thead i guess will survive depenting on the braking usage..
I still havent worn out my first set !
Boy you reminded me one very funny story with them microbaloons!!!!
At the time i had run out of microbaloons.So a friend was placing an order for resins and offered to include a 1liter bucket of microbaloons for me.Later when order arrived we met in the center of Athens for coffie so i pay him and get the microbaloons...
And that was veery funny!!! Why? Just imaging!
Two guys in the center of Athens ! One is giving money to the other ,
and the other giving buck a bucket with white dust LMAO
Not wise at all doing this in the midle of Athens hahaha
Specialy when most cops dont even know English to read the backet description lol
...away on a buisness trip..more to follow soon !
Old 01-12-2017, 10:52 AM
  #46
Kevin_W
What ratio of urethane to microballoons did you end up using?
Old 01-12-2017, 12:51 PM
  #47
DelGatoGrande
My Feedback: (23)
Estimate 15% of the urethane weight is microballons Where you get your urethane from? I mean what brand it is ? Thanx
Old 01-12-2017, 01:42 PM
  #48
Kevin_W
Do you mean 15% of the volume is microballoons? I used this product for my tires: https://www.smooth-on.com/products/pmc-780-dry/
Old 01-13-2017, 02:43 AM
  #49
DelGatoGrande
My Feedback: (23)
Hello Kevin ,
NO! As i said ,15% in weight!
My tests shown good resaults up to 21%.
But best combination of strenth and weight saving is 15% to maximum 18% .
I would not recoment more...use presicion weigth scale and add the microbaloons not all at once but in smaller doses.. this way mixing is easyer
Old 01-13-2017, 01:11 PM
  #50
DelGatoGrande
My Feedback: (23)
Kevin , the product on the link says shore hardness 80! It is not very hard for tyre?
