Jetcat P120 thrust level help needed >
Old 02-02-2017 | 02:49 PM
ajp
Default Jetcat P120 thrust level help needed
I am getting a older model ready to fly again. It has a 14 year old Jetcat P120 in it. I have the rpm set to 115000, and cannot find the graph that compares thrust levels to rpm. Does anybody know what thrust level I am getting at 115000?
Paul Appelbaum
Old 02-02-2017 | 03:08 PM
Vincent's Avatar
My Feedback: (61)
Here is what I found on an old rcu thread.
Old 02-02-2017 | 03:32 PM
rhklenke's Avatar
My Feedback: (24)
Good find! I always thought it was interesting how the majority of the thrust is at the top-end. A 6.5% reduction in RPM reduces thrust by over 20%...
Bob
Old 02-02-2017 | 03:51 PM
ajp
Thanks, that is exactly what I was looking for
Paul
Old 02-02-2017 | 03:52 PM
Vincent's Avatar
My Feedback: (61)
Bob
After taking a quick glance at it I was surprised too.
Vin...
Old 02-02-2017 | 04:30 PM
Zeeb's Avatar
My Feedback: (41)
Typical of turbine engines. They say with full scale that 50% of the thrust is created in the last 10% of RPM. I don't imagine their tiny counterparts would be much different.
Old 02-03-2017 | 10:44 AM
My Feedback: (8)
Paul,
The thrust figures listed by Vinny are for the latest versions of the P120's, mainly the SX version. If your engine is indeed 14 years old and has a serial number of under 1400 I would guess it will push around 24 - 25 pounds at full tilt unless it has been fully upgraded with the new style compressor, EGV, Diffuser, Chamber. The P120's from the serial number I listed above and older were around 24 - 25 pounds of blow. At 115,000 I would guess it is pushing closer to 16 pounds.
Just what I recall from running thousands of these engines over the years on test stands, etc.
Old 02-03-2017 | 03:16 PM
Vincent's Avatar
My Feedback: (61)
[QUOTE=John Redman;12302529]Paul,
<<<<The thrust figures listed by Vinny are for the latest versions of the P120's, mainly the SX version. If your engine is indeed 14 years old and has a serial number of under 1400 I would guess it will push around 24 - 25 pounds at full tilt unless it has been fully upgraded with the new style compressor, EGV, Diffuser, Chamber. The P120's from the serial number I listed above and older were around 24 - 25 pounds of blow. At 115,000 I would guess it is pushing closer to 16 pounds.
Just what I recall from running thousands of these engines over the years on test stands, etc.>>>>
Hi John...are you sure about that the thread I got that info from is from 2006 and the P120sx had a max rpm of 125k and 30-31lbs thrust??
Vin...
Old 02-07-2017 | 01:20 PM
My Feedback: (8)
Yes Vin, at 125K the P120-SX would hit 30 - 31 pounds. I am sorry, I was thinking the traditional 123K.
Old 07-14-2018 | 06:28 PM
I have a P120sx, serial no. 3476. I noticed that the ecu is set
at 123K max rpm. Can this turbine be run safely at 125K, and if so
can that be programed through the GSU?
Old 07-15-2018 | 03:50 AM
My Feedback: (23)
Originally Posted by John Redman
Paul,
Your statement is neutral in context. Before 1400 24-25lbs. Above 1400 25-25lbs. Sounds like tax brakes. Just a little confused about the statement. I own a serial number 2455 and it’s definitely more than 25lbs. Non SX, those are simply a POS from what I read.
