Reload this Page >
Introducing the Top RC Model Odyssey - New sport jet - build thread
Old 09-17-2019, 02:14 AM
  #476
airborn900
My Feedback: (25)
Originally Posted by GULDUKAT
Here are some vids from my odyssey after 9 flights. The JP retracts and brakes from Mandy are working great.
https://youtu.be/cGUVrQ9Wgvs
https://youtu.be/ABClkETaHIE
what engine ate are you running?
Old 09-17-2019, 02:31 AM
  #477
GULDUKAT
Jc cheetah sp 150n.
Old 09-18-2019, 01:04 AM
  #478
GULDUKAT
Old 10-06-2019, 05:04 AM
  #479
synergy41
Good morning all,
Do you measure your landing speed,
Thank you
Old 10-06-2019, 05:10 AM
  #480
i3dm
My Feedback: (51)
Originally Posted by synergy41
Good morning all,
Thank you
nope
Old 10-06-2019, 05:17 AM
  #481
synergy41
What is this speed according to you?
Old 10-06-2019, 01:12 PM
  #482
i3dm
My Feedback: (51)
i dont know, why do you ask?
Old 10-07-2019, 02:45 AM
  #483
synergy41
I have to install a speed sensor.
I would like to be sure that my plane does not fall because of a speed that is too low
Old 10-07-2019, 07:31 AM
  #484
i3dm
My Feedback: (51)
i have never felt the need for that, the Odyssey is a very predictable bird to fly.
Old 10-09-2019, 04:57 PM
  #485
erh7771
My Feedback: (30)
At 4 tree height after flame out I floated nearly twice around the circuit no flaps no wind ... there's a lot of wing
Old 10-30-2019, 05:59 AM
  #486
Jim Cattanach
Jim Cattanach's Avatar
I have just received my Odyssey. The retract & brake controller seems to be an updated version from the one supplied a couple of years ago.
Does anyone have a link to the manual sheet for this new controller, as I can only find the sheet for the older version, or photos of the wiring connections?
This new version has no positive, or negative symbols on it, so I have no idea which way the wires are plugged in.
I am also wondering if the manual button works with just the battery & the retracts attached?
Old 10-30-2019, 06:25 AM
  #487
rvnrcer
Good luck getting an instruction sheet. I asked for one when I first received my Odyssey about 5 months ago.
I havent been able to get the retracts to work with just the controller but they are supposed to.
I will attach a sheet they sent me with mine.
the red/signal wires orient to the top of the controller. Black to the bottom.
Hope this helps
Keith
Also, check the wires that come from the brakes. I found that the connector is wired wrong. The red wire should be in the outside pin not the middle. I modified an extension so the red wire went to the signal or outside pin and the black stayed on the other outside pin.
Old 10-30-2019, 08:17 AM
  #488
Jim Cattanach
Many thanks for the info. I found this vid on You tube which shows a guy testing the retracts without the Tx or Rx. He is using a servo tester plugged into the Rx retract port of the controller. I tried this & it works.
With your info & his vid, all should be ok.
Twin-B0 (02-01-2021)
Old 10-30-2019, 09:05 AM
  #489
MargaretWoodard
Nice!
Old 11-03-2019, 08:41 AM
  #490
NICLAS
Well it arrived 26h after my order So now it is my turn to get "Odyssed"
Old 11-10-2019, 09:17 AM
  #491
NICLAS
Have anyone got the Geardoor function to work properly?
Have managed to get the door to function....but the opposite way. Gear down door close....gear up door open!
Old 11-10-2019, 10:27 AM
  #492
Ceeray
Reverse leads
Old 11-10-2019, 10:31 AM
  #493
i3dm
My Feedback: (51)
you can easily reverse your gears direction - will that help ?
Old 11-14-2019, 07:06 AM
  #494
airborn900
My Feedback: (25)
What size engines are you guys running. I have a SW-140b in mine. I have a buddy that is talking about a 160 or 170. I’m happy with the performance with the 140. Just wanted to see if anyone that is running a larger motor and can comment.
Old 11-14-2019, 07:47 AM
  #495
i3dm
My Feedback: (51)
i have flown the Odyssey on anything from 100N to 160N.
for me 120N felt like the perfect balance, but no issues with 160N.
this bird is very versatile.
Old 11-14-2019, 07:58 AM
  #496
RP-Stinger
I fly my Odyssey on a Kingtech 160 and love it. No issues here, great flying jet.
Old 11-15-2019, 07:06 AM
  #497
flying skunks
My Feedback: (7)
Originally Posted by tothemax
Where do you purchase this model. I emailed Top RC No love.....
DreamWorks Model Products also carries Top RC , and has the Odyssey in stock. I believe its the Orange/Black Navy scheme
Old 11-16-2019, 06:14 AM
  #498
Jmav7279
Default Odyssey
Mike at Gator Hobbies is the importer of Top Rc in the US. I fly mine with a SW 190 and love it!
Old 11-19-2019, 09:45 PM
  #499
Jim Cattanach
Just finished building my Odyssey. Weight came out at exactly 13 kilos. No added weight. Powered by Jetcat P130.
I am a bit concerned by the lack of give in the oleos. Even full of fuel, it takes a lot of downward pressure on the model to get the oleos to start to compress.
They are the Top RC oleos.
Anyone else had this problem & bad effects on landing?
Old 11-20-2019, 12:15 AM
  #500
Jmav7279
Default Odyssey
Mine are stiff as well but work just fine. Jason
