Reload this Page >
T-3 Pics and Build
T-3 Pics and Build
Old 09-20-2017, 11:48 AM
  #76
rcflyguy_26
My Feedback: (8)
rcflyguy_26's Avatar
Very good.
Just talk to Dirk again little bit ago to confirm my order. I guess I didn't realize how much is done at the factory.
Scott
Old 09-25-2017, 01:38 PM
  #77
rcflyguy_26
My Feedback: (8)
How tall is the T-3?
On the gear and sitting on the keel.
Thanks, Scott
Old 09-25-2017, 06:29 PM
  #78
Desert Fox 1
Default T-One Models Manuals
Originally Posted by Digital Pilot
I'm starting to put together a basic assembly manual. I say basic as there is not a lot of work and guessing to assemble this model. The manual will have CG, Throws and some basic assembly photos. Estimated completion time will be a few weeks.
If anyone has any pertinent info that has built a T3 please feel free to send it to me.
The T-One Models Mini T-1 should have a basic assembly manual also. Some of the new owners are coming from ARF foamy and this is their first composite build.
Cheers!
Desert Fox 1
Old 09-25-2017, 07:32 PM
  #79
Digital Pilot
Digital Pilot's Avatar
Thanks, Scott
Scott, Keel to the top of the tail is about 33". Don't have it on the gear yet..
Old 09-25-2017, 07:34 PM
  #80
Digital Pilot
Desert, there are plans to do this for the Mini as well. Again this will be a very basic manual as well.
Old 09-25-2017, 07:41 PM
  #81
Digital Pilot
Couple More
ID:	2233703   Click image for larger version
ID:	2233704   Click image for larger version
ID:	2233705   Click image for larger version
Old 09-26-2017, 10:04 AM
  #82
gunradd
My Feedback: (9)
gunradd's Avatar
Clean work Jeff! Are you sure your going to have enough room?? lol
Old 09-29-2017, 06:05 PM
  #83
rcflyguy_26
My Feedback: (8)
Ok, I'm checking out my trailer on how I'm going to change my layout for the T3... 118 long... check.
33" from keep to rudder tip... Will have to lower shelf a tad... no problem.
How wide is the stab?
This thing is going to be huge! Can't wait!
Old 10-01-2017, 12:55 PM
  #84
jsnipes
I measure 50" wide on the horizontal stab.
I have mine on 4" thick foam padding. I cut a "v" groove in it for the keel to sit down in. It is 36" tall including the foam padding (this is total height of the foam plus vertical fin with the T-3 sitting down in the foam).
I keep the wing tube in it and pull a bungee around the wing tube on each side ... not too tight, just snug. I also put a bungee with padding over the tail section and nose section where the formers are located where the fuse sections go together....again, not too tight just snug. It's not going anywhere.
JS
Old 10-03-2017, 06:49 PM
  #85
Digital Pilot
What an AMAZING flying jet! Roll out and rotation was quick with the K210, couple clicks of elevator trim and was good to go. I did a pretty normal setup on the controls and the CG @ 335mm. She flew like a Cadillac and the flaps are very effective and do not compress at all with the internal linkage setup. It slows down fast, I also have about 1/2 inch crow at full flaps. 5 min flight and setup the flight modes and landed.
Some setup changes to the throws and flaps.. Now we are setup like a Cadillac CTS-V!!! Great response and performance. The Knife edge flight is spot on with zero coupling and very little rudder input (And I haven't even pulled the CG back yet) The power of the K210 is fantastic and pushes this jet very well through all the maneuvers. Landing with full flaps and crow, Spot on the mains and carried the nose all the way down the runway!
I will bring the CG back a bit more to my liking. Amazing jet especially for the price. You will be hard pressed to find another jet this size with this performance for the price! Once again T-One Models nailed it!
Photos....
ID:	2239915   Click image for larger version
ID:	2239916   Click image for larger version
ID:	2239917   Click image for larger version
ID:	2239918   Click image for larger version
ID:	2239919   Click image for larger version
ID:	2239920   Click image for larger version
ID:	2239921   Click image for larger version
Old 10-03-2017, 08:49 PM
  #86
flejter1
flejter1's Avatar
rcflyguy,
No need to adjust the trailer shelf... The T-3 wing bags are now in stock and it has a padded divider for the 2 wings, the horizontal and vertical stabs as well as the wing spar holder. The outer material is a heavy duty canvas that also has a thick padded layer to protect everything inside. It has a hard bottom piece with 4 feet nubs installed so you can stand it up like a suit case and it has the support needed so no wing edges get dented. The quality of these wing cases are probably the best I have seen and worth every dollar to protect your investment.
Cheers,
Dirk
Old 10-04-2017, 12:48 PM
  #87
rcflyguy_26
My Feedback: (8)
Originally Posted by flejter1
rcflyguy,
Cheers,
Dirk
I may not need the trailer at all... lol
Old 10-15-2017, 09:00 PM
  #88
Digital Pilot
Yeah!!!! We took home the (Best Sport Jet Runner Up Award!) at Best In The West 2017! This is a tough class with many other great sport jets and PRCJ is proud to take this award home with the first T-3 on the west coast! Again, This jet is amazing and many other pilots had a chance to fly it. They all said the same thing, WOW, Tracks like a pattern jet and the performance is excellent, it sure slows down to a crawl to land! Its how much??!! A few new orders went in that day as well!!!
Again, Thanks to T-One models for giving us such a great jet at a great price!.
More photos on the site:
https://www.pacificrcjet.com/pages/prcj-photo-gallery
ID:	2241323   Click image for larger version
ID:	2241324   Click image for larger version
ID:	2241325   Click image for larger version
Old 10-16-2017, 04:59 PM
  #89
rcflyguy_26
My Feedback: (8)
Excellent!!
I hope to take mine to the Toledo show this year.
Old 10-16-2017, 05:22 PM
  #90
Dansy
My Feedback: (53)
Dansy's Avatar
Excellent!!
That would be nice.....
Old 10-19-2017, 10:50 AM
  #91
rcflyguy_26
My Feedback: (8)
Default My T-3
Had to share! Shipping soon!
ID:	2241665   Click image for larger version
Old 10-19-2017, 04:09 PM
  #92
Digital Pilot
Very Cool!
Old 10-20-2017, 11:26 AM
  #93
pfact
My Feedback: (92)
Hey guys -
I ordered a P-3 for my son at BITW, I hope to have it before Thanksgiving and would like to accumulate the parts needed to complete it.
Can someone answer a few questions for me:
1. Roughly how much servo torque is needed?
2. Servo arms sizes for the flight surfaces?
3. Does anybody know the diameter of the roots of the struts (I am planning to use electric retracts)
4. How about the wheel and axel diameters?
Phil
Old 10-20-2017, 01:27 PM
  #94
jsnipes
T-3's at our jet meet today. Tiger Meet 2017 in SC.
ID:	2241744   Click image for larger version
Old 11-10-2017, 11:19 AM
  #95
rcflyguy_26
My Feedback: (8)
It's here! Well, half of it, wings due in Monday.
ID:	2244323   Click image for larger version
Old 11-10-2017, 02:09 PM
  #96
jsnipes
Very nice!! Keep us posted in your build! JS
Old 11-10-2017, 02:11 PM
  #97
rcflyguy_26
My Feedback: (8)
The sideway picture thing is upsetting me. Any ideas on how to fix it?
Old 11-10-2017, 05:08 PM
  #98
rcflyguy_26
My Feedback: (8)
Try this again
ID:	2244376   Click image for larger version
Old 11-10-2017, 06:05 PM
  #99
jsnipes
I gave up after a while. It's hard to understand how it's so hard for a site like this to handle pics in 2017. JS
Old 12-10-2017, 10:36 PM
  #100
PVS41960
Ordered the T-3 Pink Monster Scheme today before the Chinese New Year. Powered by the King Tech 210 with factory installed lighting system, cortex gyro, King Tech smoke pump, 36” smoke pipe, xicoy electronic gear/brake valves, xicoy failsafe/sequencer, 8 Savox SA1230SG servos, 1 Savox SC 0251 for the nose gear door. King Tech ECU & receiver batteries & DX 20 channel receiver.
Thanks to Dirk from PRCJ for all his help
Paul Sweeney
ID:	2247433Click image for larger version
ID:	2247434Click image for larger version
ID:	2247435Click image for larger version
