Reload this Page >
CARF Joker build thread
Old 01-30-2021, 04:39 AM
  #901
Bob_B
Bob_B's Avatar
Originally Posted by kevin View Post
I balanced mine at about 180 with about 20% of fuel in the tank. After a few flights like that I even moved my 2100 ecu battery from inside the nosecone to the tray under the canopy. That is how I fly it to this day. In my link you can see mine landing pretty slowly even with a k100. I was surprised at how slow it could fly during my initial testing but it is no Havoc or Tomahawk Sabre
https://www.youtube.com/watch?v=40ZpSGwSxa0
Nice landing!
Old 01-31-2021, 02:44 PM
  #902
jvaliensi
Well my Joker was test flown. The balance was spot on, the elevator did not feel too sensitive. However, my elevator compensation for flaps down was not enough. We had to add loads of down trim to get it set correctly. Ended up with 10mm down with full flaps and 4mm down with takeoff flaps.
Unfortunately, I had a really bad landing and damage the model. I'm too pissed off to fix it. I may pull it apart and use the parts for another model. I put it in the attic while I think about this.
Old 01-31-2021, 02:55 PM
  #903
Dave Wilshere
Your elevator figure measured at the root or tip of the elevator?
Old 01-31-2021, 03:32 PM
  #904
jvaliensi
At the root, near the fuselage.
Old 01-31-2021, 03:58 PM
  #905
kevin
Sorry to hear that. Did you have flight modes set in your transmitter?
Old 01-31-2021, 04:31 PM
  #906
jvaliensi
Hi,
I sure did have flight modes set up. I had expert help.
I came in too hot and should have done a run around for another pass. Just a case of bad judgement on my part.
The Joker was not hard to fly.
Old 01-31-2021, 06:35 PM
  #907
jcterrettaz
jcterrettaz's Avatar
Sorry for that ...suck!!! , you can order replacement parts from Carf ..I think so.
should be a very hard landing , Carfs model are solids!!
Old 02-03-2021, 10:46 AM
  #908
Christiaan22
Goodday fellow pilots
I ordered the green pnp joker.
What is the diameter of the wheels of the pnp version? I am planning to install the K85, is a 300ft grass field sufficient?
And last, the macgregor servo's doing the job well?
Thank you!
Old 02-03-2021, 11:17 AM
  #909
jvaliensi
65mm are what came with mine.
Old 02-03-2021, 11:25 AM
  #910
Dave Wilshere
Thank you!
Not sure what the idle thrust is on a KT 85, but ours with JetCat P-100RX (just over 2 N idle thrust) flies in a 100m grass strip no problem.
All of our are using the MacGregor servos with a Powerbox, so 5.9v They seem happy with that or 6.6 Li-fe
Dave
Christiaan22 (02-03-2021)
Old 02-03-2021, 11:33 AM
  #911
Christiaan22
Thank You!
Old 02-06-2021, 05:15 AM
  #912
Christiaan22
Does the pnp version uses the mac2607 or the newer mac2810 servo's? I have ordered the powerbox switch for 6volt operation.
With friendly regards!
Christiaan
Old 02-06-2021, 07:15 AM
  #913
Dave Wilshere
It will depend when the kit left the factory. Probably the 2607 like mine which I run on 5.9v
Dave
Old 02-06-2021, 08:04 AM
  #914
Christiaan22
Just ordered the last pnp in stock from the carf website. We will see, I run at 6volt anyway with the PB switch. Thank you for the reply Dave!
Old 04-05-2021, 04:30 AM
  #915
Desert Fox 1
Cheers!
Desert Fox 1
The following 2 users liked this post by Desert Fox 1:
DenisFerrari (04-05-2021), drfred58809 (04-05-2021)
Old 05-29-2021, 01:49 PM
  #916
Desert Fox 1
Cheers!
Desert Fox 1
apereira (05-29-2021)
Old 06-01-2021, 08:59 PM
  #917
pcskyhi
Hey guys, I just sent my turbine in for its 25hr service, all done in the Joker. while the engine is away I am doing some maintenance stuff. Please feel free to suggest things I should be checking/inspecting during this time. The one thing I do want to ask about is the pipe. My inner pipe is moving around inside the outer pipe. has anyone come across this issue? I forgot to mention this is the stock CARF pipe for the Joker. There is a spring that is surrounding the inner pipe that when new was keeping the inner pipe dead center with no movement. I don't know what changed but the spring no longer holds the inner pipe center and the inner pipe bounces around freely. any suggestions/comments/ideas are welcomed.
DenisFerrari (06-01-2021)
Old 06-01-2021, 11:41 PM
  #918
DenisFerrari
My one still has not many flights, not centered on the outer pipe but spring seems doing some job even if - as told - inner is more close to outer on one side. But this is from day 0 and still good.
Old 06-13-2021, 12:12 PM
  #919
Speedrick
Default Flap mixer
Hi, in the mean time, I did a dozen flights not and the K85 is the perfect match for my Joker.
Plane flies so good that I’m starting to feel comfortable on this jet.
The only thing I’m still having problems with is the elevator to flaps mixer…… there is so much down needed to prevent the pitch up.
What is the elevator movement that you are using to compensate for the flaps?
kind Regards,
Eric
Old 06-13-2021, 12:29 PM
  #920
jcterrettaz
1-2 mm down
Old 06-13-2021, 12:38 PM
  #921
Dansy
My Feedback: (53)
Dansy's Avatar
kind Regards,
Eric
Depending on the TX you have.....I always do those with the Flight Mode and I trim (one setting per flight mode) the plane for cruise, take off flaps and landing flaps.....never have to touch it again...
Old 06-14-2021, 05:40 AM
  #922
Speedrick
Originally Posted by jcterrettaz View Post
1-2 mm down
are you serious????
Old 06-14-2021, 05:43 AM
  #923
Speedrick
Okay, I’m flying since 40 years on Futaba😋
I’m interested to see how many down elevator is used at full flaps, and I heard that a lot is needed.
once spoke a Joker pilot, and he told me 8-10mm. 8mm is what I’m using, but it still seems not enough🤔
kind Regards,
Eric
Old 06-14-2021, 06:06 AM
  #924
jvaliensi
My joker needs 6 to 8mm down elevator with full flaps. But you have to watch your speed, too fast and it will still climb.
Old 06-14-2021, 07:19 AM
  #925
why_fly_high
My Feedback: (19)
kind Regards,
Eric
Do you use Conditions? Most powerful part of Futaba systems. Set 3 identical conditions where everything is the same except the elevator trim is independent and conditions change with flap switch. Take off, trim elevator, go to mid flap and trim elevator, go to landing flap and trim elevator. Don't have to guess on mix ever again.
