Savex
Old 09-11-2019 | 05:10 AM
David Gladwin's Avatar
Default Savex
Does anyone know if Savex is still in business.
I lost my L39 in a mid air on Sunday and ned a replacement, but no reply to my email to Savex.
Any help will be appreciated.
Old 09-11-2019 | 11:03 AM
Sorry for your loss David. Had bought a l39 from them around 3.5 years ago.
Chatty.
Old 09-11-2019 | 11:50 PM
Thank you, Chatty, sad loss, pure accident.
Ironically was the first airborne test of my Core, and just the 5th flight of my new X45 which was undamaged !
Need TCAS !
Do hope I can replace it.
D.
Old 09-12-2019 | 03:25 AM
JSF-TC's Avatar
David,
I have a like new RTF Savex L-39 with a Wren 44 that I haven't flown in a couple of years.
Is it of any interest to you?
Paul
Old 09-12-2019 | 09:59 PM
Originally Posted by JSF-TC
David,
Paul
Thank you but too far away.
Seems Savex no longer making model aircraft.
Old 09-14-2019 | 09:16 AM
Hi David,
I was always thiniking should I order one or not......while do that it seems that you are right and SAVEX doesn't do any models these days.....sad.
I know that people in Germany often say that these models were made/designed by Axel Schreiner - his models (and even the L-39) can be found here:
Ok- just learned that I need 10 posts to post a link....look for insider Modellbau in Switzerland -> Elektrojets -> GFK Jets -> Insider Modelle
Maybe that is of help for you !
BR from Germany
Markus
Old 09-14-2019 | 11:59 AM
Need TCAS !
D.
Although not full composite, but the sebart L39 should have similar specks. I am sure all your gear from the Savex could fit in there. Will be a much faster build than the savex too.
Chatty.
Old 09-15-2019 | 12:03 AM
Thank you Markus and Chatty, I am on the case. I really need a new home for the exquisite x 45!
Old 09-16-2019 | 01:39 AM
erbroens's Avatar
Sorry for the mid air David.
https://modellbau-peters.de/l-39-alb...h-starjet.html
Pretty sure this is the same plane,, ours from Savex is still going strong with a Kingtech K-45.
best regards, Enrique.
Old 09-17-2019 | 06:55 AM
Thank you, Enrique, looking into it!
kind regards,
David.
Old 06-06-2020 | 04:19 AM
David
Don't know if you have had any luck with the Schreiner L39 but I had one of these about 15 years ago. It seemed almost identical to the Savex version. Another route might be the Blackhorse L39 which is ply / balsa construction and several people have converted it to turbine using Wren 44's / K45 / P60 dry weight seems to be around 11 lbs. It is a bit bigger than the Savex, around the size of the small Airworld version I think. There is a good build thread on RC groups large EDF jets page 3.
Regards
John
Old 06-07-2020 | 11:00 PM
Originally Posted by john agnew
David
Regards
John
Thanks, John. Gave up on a L39 and the x45 is now mounted on my E Flite Blanik. Not a lot of thrust for a big glider but should be OK. At least the exquisite Little X 45 is now visible atop the Blanik. Paritech state the Wren 44 will fly well on their DG 303 which is bigger and heavier than the Blanik. I wilL soon find out as my DG has my Wren 44 Gold on it, ready to go !
Again many thanks for your suggestions.!
David.
