Reload this Page >
CARF REBEL 2m
CARF REBEL 2m
Old 08-05-2020, 10:55 AM
  #176
Dave Wilshere
Video quality is superb
Dave
The following 2 users liked this post by Dave Wilshere:
bodywerks (08-05-2020), paulhat (08-16-2020)
Old 08-05-2020, 12:07 PM
  #177
bodywerks
bodywerks's Avatar
Originally Posted by skunkwurk
Nice flight! If you do not mind me asking, are you using any expo on the Ail or Ele? If so, what %?
you will want expo on both, no matter what. I haven't flown an aircraft without expo in over 30 years. The amount of expo is personal tastes and dependent on how much throw you have. I'd start at 35% and go from there.
Old 08-05-2020, 12:28 PM
  #178
skunkwurk
My Feedback: (18)
skunkwurk's Avatar
I understand, and I do so as well. I have been flying my rebel for about 3 seasons and have been decreasing the expo out incrementally. Mine feels rather sluggish on these two axis. I think it is due to the gain on my gyro. I'm planning on decreasing the gain for aerobatics or possibly the expo, perhaps maybe a little of both. I'm trying to gather data on what others are using on this jet. thanks for the feedback!
Old 08-05-2020, 02:55 PM
  #179
Desert Fox 1
Dave,
Thanks for the kind words on the video.
Cheers!
Desert Fox 1
Old 08-06-2020, 02:27 AM
  #180
Dave Wilshere
People who have not tried don’t understand how difficult it is! Camera is only part of it, you need to set it up properly and learn to follow a moving target without the pilot telling you which way he might next turn!
You have it aced
Old 08-06-2020, 07:03 PM
  #181
bodywerks
bodywerks's Avatar
You have it aced
and know how to edit!
Old 08-15-2020, 07:33 AM
  #182
Dave Wilshere
Test flew the first of three Rebel 2m models this morning for owner Steve. Perfect first flight, PB Mercury and Core radio
Old 08-15-2020, 09:00 AM
  #183
bodywerks
bodywerks's Avatar
Very nice. Hope to maiden my 3rd Rebel in a couple weeks.
Old 08-15-2020, 07:23 PM
  #184
Desertlakesflying
My Feedback: (28)
Hit 100 flights today on my Rebel since the end of February! Such a great plane to fly.
DenisFerrari (12-21-2021)
Old 08-18-2020, 01:10 AM
  #185
jamessymons
Hi Bodywerks
Does your nose gear have a extension part in it. If so please could I ask you to post a photo of it.
Many Thanks
James
Old 08-18-2020, 07:27 AM
  #186
bodywerks
bodywerks's Avatar
No sort of extension here.
Old 08-18-2020, 07:46 AM
  #187
jamessymons
Thank a million. Much appreciated.
Old 08-19-2020, 06:10 AM
  #188
skunkwurk
My Feedback: (18)
skunkwurk's Avatar
Dave, interesting to see the UAT cap pointed to the rear of the jet. I did the same thing on the Viper. I did it because I installed it directly in front of the main tank, it facilitated a nice straight shot between the two for fuel delivery. Typically you see them installed with the cap to the front, for ease of removing air bubbles by lifting the nose
Old 08-19-2020, 07:47 AM
  #189
Dansy
My Feedback: (53)
Dansy's Avatar
Most of my UAT’s are installed with the cap toward the rear......works just the same and a straight line into it...
Old 08-19-2020, 07:49 AM
  #190
skunkwurk
My Feedback: (18)
skunkwurk's Avatar
Great - I was worried about doing it. Glad to see others doing it.
Old 08-19-2020, 07:57 AM
  #191
Dansy
My Feedback: (53)
Dansy's Avatar
i also had one jet with it sideways.......so I could mount both the pump and the UAT way forward so no weight was required.....work as well...
the one thing I always try to do..is to install the UAT as close as possible from the tank and mount the pump really close to the UAT.....
Old 08-19-2020, 01:35 PM
  #192
Dave Wilshere
They are designed with a central pick up, this means they don’t mind which way you mount them, in the Rebel it shortens the lines. Since we use a felt hi-flow clunk there is no air in the trap on landing, so it was only the first fill we needed to tip it on its nose to get the nipples to the highest point. The test flight took off with a 1/4” dia air pocket bubble at the top of the MAP and landed 7 1/2 minutes later with exactly the same!
I would not mount a BVM bag type flat like this, only angled, the MAP trap is not as fussy.
Old 08-19-2020, 04:58 PM
  #193
bodywerks
bodywerks's Avatar
On my Rebel 2m I'll be using the factory uat and mounting it backwards, in front of my main tank, so I can have a similar clean install on the deck like on my Rebel pro. On the pro, I used a Cmjets tank with an integral uat.
skunkwurk (08-20-2020)
Old 08-30-2020, 04:13 PM
  #194
Agrav8ed
Finished the rebel. Had to add in a bit of nose weight but it turned well and is still lighter than my T1. Here is the final weight with a Swiwin 140n, electron retracts, uat full with main tank empty and 50 grams lead weight in the tip of the nose.
Tone
ID:	2268108   Click image for larger version
ID:	2268109   Click image for larger version
The following 2 users liked this post by Agrav8ed:
bodywerks (08-30-2020), CRX Turbines (08-30-2020)
Old 08-30-2020, 04:27 PM
  #195
bodywerks
bodywerks's Avatar
That is significantly lighter than a T1, by an easy 6lbs. But heavier than my friend's, who had a KT160 in his and no added nose weight. He was actually same weight with a full uat. I'm surprised you had to add any weight, then again your batteries could go WAY further forward.
You do know CG is the back of the wing tube, right? Measured with gear down. And even that is slightly nose heavy in the air.
Old 08-30-2020, 05:52 PM
  #196
Agrav8ed
The manual stated that the CG was the front of the wing tube. Thats where I measured mine. You are stating that the CG is actually the back of the wing tube?
Tone
Old 08-30-2020, 10:27 PM
  #197
Dave Wilshere
Back of the wing tube is nearer the mark...but it depends how much fuel are measuring the balance with. A full tank it probably is close to the front of the tube. I would balance a Rebel with 1/3 fuel in the main tank at the rear of the spar.
Dave
bodywerks (08-31-2020)
Old 08-31-2020, 03:36 AM
  #198
bodywerks
bodywerks's Avatar
^^^^ What he said.
Old 08-31-2020, 08:05 AM
  #199
Agrav8ed
Dave
I really wish manufacturers would put in a CG range or give us this information before we do things like gluing lead weights, buying different batteries, etc to try to get the manuals expectations for a very conservative cg. I looked in this forum and google searched online and this is the first I have seen on balancing at the rear of the wing tube.
Tone
Old 08-31-2020, 10:35 AM
  #200
Dave Wilshere
The problem is they don’t know the pilot ability and also personal feel. Safe is better than ‘neutral’
I would never permanently fix weight before flight. This one has no nose weight and we started with the batteries forwards and now as the 6 flights today we had moved the packs back and it’s near perfect.
This is landing fuel after 6 minutes with a P-130Rx JetCat, so we can add 1minute
