IGyro 3Xtra ca Cortex Pro >
Old 01-22-2020 | 08:05 AM
My Feedback: (64)
Default IGyro 3Xtra VS Cortex Pro
Trying to decide between Igyro 3Xtra and Cortex Pro for jet use. Any pros/cons and opinions appreciated
Old 01-22-2020 | 08:18 AM
BarracudaHockey's Avatar
Pros for the igyro is the hold mode is implemented better, it releases as soon as you move the stick. Allows GPS input for gain changes due to speed. Con outputs are hard coded, you have an extra elevator slot you can't remap it for nose wheel or whatever.
Cortex you plug in servos and it assigns outputs during the teach-in so its more flexible setup wise but hold mode is only good for torque rolling airplanes.
They both work really well.
Old 01-22-2020 | 12:31 PM
My Feedback: (64)
OK Thank you. I assume rates can be changed on both in flight via transmitter knob? I don't really use hold, can program for two seperate gain only setting via switch and have off/low/high gain switchable?
Old 01-22-2020 | 12:54 PM
You can adjust the gain on both from the transmitter.
What I do on the Cortex is find the highest gain that the plane will tolerate at high speed then back it off a few points, then set a mix to bump the gain with the flaps or gear down.
On the Igyro I just use the GPS to increase the gain with less speed.
