enclosed jet trailer
My Feedback: (54)
I bought a cut down Freedom Trailer and picked it up from the factory in 2009. It’s a 10’ Vnose, which is 12’ to the V. Best investment I’ve ever made for the hobby. It tows very well at a normal highway cruise for me at 77 mph, and have had it higher to get around someone. No fish tailing. You have to buy them through a dealer if ordering one from the factory.
I’ve had 2 jets and a CARF 3.1 Extra in there at the same time. I hung one jet upside down with foam between it and the ceiling.
Notice that I got it with barn doors. A ramp is a hassle for me, and dumps dirt into the trailer every time you lift the ramp door.
My Feedback: (54)
Mine are fine. I just don’t drive like an idiot over rough roads, RR#, etc. I actually don’t attach any of my jets to the floor. I’ve seen too many jets and planes damage simply by over strapping. If the jet or planes are on wheels, then I have tie downs where the wheels sit, and a small small bungee wrapped around the strut or wheels. Did this for my F-16, F-18, and all of the Extras’.
As you see those two of my current jets, I just let them ride in old dog foam beds. I’ve never had a issue. Even having a rear truck flat tire at 75mph and loosing control out through the median. Had it under control, until hitting a rough bridge. I didn’t jack knife or roll it. First thing I looked at was both jets and I had a CARF 44% Giles. Nothing damage inside or outside of the trailer. Totaled the truck, due to hitting all four corner panels. Most of the time that you see this happen to someone, they normally over steer and roll it is what the highway patrolman told me.
I also hang my wings.
My Feedback: (54)
I would buy another if I had to buy one today.
Bluebus, if you happen to visit flyinggiants site they have an extremely long and help thread just for trailers with more information than you will ever need on setting one up for RC
My Feedback: (54)
They are old dog beds. I have large dogs. The covering wears out. Yes, of course they add cushioning. As I said earlier, The jets just sit on top. I have another long piece from a bed mattress that goes in between the two jets. If I’m just going to the local field for the day, I only take one jet. My 5 gallon can sits in front strapped down. I place a foam piece in between the can and the nose of the jet. This way if I have to stop suddenly, the jet doesn’t move forward.
My Feedback: (8)
This is the trailer I pull for Elite Aerosports. There are three more planes up front. As I drive thousands of miles each year delivering customers and team planes not one plane has been damaged.
I do not recommend transporting planes WITH retracts with the gear down. The constant movement of the trailer from rough roads and whatever causes permature wear on the gear IMO. Fixed gear OK.
Get an accurate garage floor height to door when opened. Then check around with different manufacturers on what custom height they will do. When I bought my Haulmark and ordered it so it would fit in my garage, the dealer told me the factory could do it in six inch increments and then once I ordered they came back a few weeks later and told me one foot. May not sound like much but six extra inches in height on an already lowered trailer is huge. Oh and BTW, Haulmark is way overrated. I would not go that route again if was to get another trailer.
My Feedback: (54)
I added a cabinet in the back behind the wheels. In the cabinet I have a heavy duty and cycle 12v battery. I will also carry a 5 gallons of fuel under it. I have noticed that if you put more weight on the axle or behind the axle, the trailer rides better. I’ve heard of guys permanently adding dead weight of a hundred pounds or so. Even mounting the weight outside underneath the floor, attached to the frame to get a better ride. Just a thought.
My Feedback: (8)
You have to be careful when adding weight to the rear of the trailer. When you do that you take away tongue weight. Too little tongue weight may cause the trailer to fish tail and you don't want that. Tongue weight should be at least 10% of the weight of the trailer loaded. Trailer weighing 2500 pounds loaded, tongue weight should at least 250 pounds
My Feedback: (54)
