Pluses/Minuses of Two Radio Choices
#103
OK, I successfully updated the TX software to the latest, 5.03 or 5.30. Having a rough time pairing the TX with a 7 ch RX. I got one module paired (only one check mark on upper left of screen) but can't get two checks. I tried default and dual path. No luck. Bedtime for this Luddite , I mean Jetiite.....
Good to see you updated the TX. Now, did you update the devices using that USB adapter you purchased? If not, go and get Jeti Studio software, install it, then watch HarryC's video on how to update your devices. I say that because sometimes a brand new device may have had a firmware update released between the time it was manufactured and the time you receive it.
One quick note, most devices only need to be plugged in to the USB adapter and will be powered by the adapter. The CB2xx is different. It will need a separate power supply while being updated.
Have fun!
...jim
#104
#107
Look at another usefull device, you can automate your retract by using this Micro Vario and Telemetry Fuctions
Elite Telemetry Sensor Micro Variometer for Jeti EX/Futaba S.Bus2/Graupner HoTT ($55.00)
New Baby Vario is on the way. No more clutter, no more extra weight for your Jet, Sailplane or DLG.
Know your Altitude, Air pressure, Temperature and Rate of Climb/Descent. Simply Plug & Play solution for your Jeti, Futaba or Graupner RC System.
Zb/Jeti USA
Zb/Jeti USA
#108
Here is another suggestion for you. There is a thread on the German Jeti forum about an automatic throttle to use when you hand launch an electric glider. I think that you probably can make a better solution to this problem or at least make an English spoken video about it.
https://www.jetiforum.de/index.php/2...dstart?start=0
And by the way. I have another problem. I just bought a DS-12. But when I tried to move the model files from my trusty DC-16 to the DS-12 by means of a PC it didn’t work. Do you have any ideas about that?
And congrats to your new DS-24, very well deserved!
Jannica
Sweden
#110
Via the PC I moved the file to the Model map on the DS-12. But when I tried to open the file in the DS-12 I got an error message. I don’t exactly remember the words in the message but the meaning was that it was incompatible whit the hardware in some way. I will see if I can replicate it and come back to you.
Jannica
Jannica
