Carf rebel pro
#576
Even with full telemetry, sometime (like most of the times)it’s extremely hard to pin point the exact cause……since you can’t really duplicate with another planes….too many differences.
Sad, and yes only fly jets you can afford to loose in a seconds….it happen to all of us.
![Frown](https://www.rcuniverse.com/forum/images/smilies/frown.gif)
The following 2 users liked this post by essyou35:
Canadian Man (12-06-2022),
Skunkwrks (12-06-2022)
#578
Agree, sometimes STUFF happens..!
sewbusy (12-06-2022)
#579
![](/forum/images/badges/premium_member.png)
My Feedback: (21)
Unfortunately I never hooked up the telemetry. I did correct the first roll and it was fine for a second then did a bunch of rolls, so it was not a locked servo. It had to be radio interference it really the likely culprit. This radio I have is new to me and I have only have a few flights on it. My older futaba never had even a single hiccup.
Ill have to fly some edf and test it out good and see if it repeats. I had this issue with a spektrum radio years ago and lost several planes.
Robert
#580
![](/forum/images/badges/trading_plus_member.png)
Just quick update, and I know this is RARE and may seem like Im trying to save face, but I took a big HSD 105mm EDF out yesterday and set it up on my radio. Several club member present. On my first circuit, in the direction of the houses, the jet did the same thing. It started rolling, I would un roll it, then it would roll the other way and then it started rolling FAST and went in. It was nearly identical to what happened to the rebel. This was a completely different RX as well using FAST instead of FASTEST.
There is definitely an issue with this radio. Im able to fly my small heli ok with it but that stays pretty close.
Im no longer allowed to use my radio at the club until I get it check out, but I know how this goes that futaba will say it checks out OK.
Im not bashing futaba but there is an issue here with this specific radio in my hands. So a new radio it is.
Edit: Note the servo monitor does not show any wonky movements on the ground.
#584
![Talking](https://www.rcuniverse.com/forum/images/icons/icon10.gif)
Jeti are great radios!
#585
I just got the Core from Powerbox Americas, I ordered it 2 weeks ago and it came in this week and was shipped (should be in my hands in a few days). Aeropanda also as others have noted keep both Core and Atom in stock usually.
The following 2 users liked this post by Dansy:
Canadian Man (12-12-2022),
RickP (12-13-2022)
#588
I watched a ton of Harry C videos on Jeti programming and I was always thinking "I did this, now why do I have to do that, and then that (and sometimes, and that) to get something to work". Core programming just makes linear sense to me so I bought it.
Skunkwrks (12-12-2022)
#590
#592
#593
My Feedback: (21)
Robert
#594
This thread got me interested in the Rebel Pro…Thanks guys! I was flying a 3m Leonardo prior to this. There has been many mentions of F3S Jet flying and it is apparent that several of you guys have an aerobatics background that you are/have explored with your jets. F3S is a growing segment of precision aerobatics administered by the FAI.
My new Rebel Pro just arrived and I will be flying her strictly in F3S. Instead of adding any build here, as it has already been done by many, I’ll probably start a different thread, dedicated to F3S Jet aerobatics.
I have already started on the installation of the 6L Kevlar tank from CM jets and after shaving the former and also the sandwich former, I’m ready to glue it to the tank. My question is directed to “Dansy” ….. I noticed in one of your posts, you showed a very simple method of securing the rear of the tank with an L shaped bracket.
(1)Below the brace that is glued/anchored on the former just behind the wing tube sleeve, what do you have from the top of the tube to the bottom of the brace?
(2) Do you have any thoughts/issues of that former being under stress/broken with any “misadventures” of a pilot?
Here is a photo of my new wife! 🤣
Wayne
![](https://cimg2.ibsrv.net/gimg/www.rcuniverse.com-vbulletin/2000x1504/b4e1e09d_2eaf_426e_ab6b_61fd37475bed_455de2e72f027a355268110d5256777eef2e7c7a.jpeg)
Wayne
sewbusy (12-18-2022)
#596
My Feedback: (53)
Wayne
Wayne
I was a little force since I was working with a used Pirotti RP tank that was previously mounted in a Pirotti, the front former opening wasn’t big enough…so I enlarge that to just fit the tank, with a empty large spray can with sand paper glue to it….and when around and around until it just fit, so no fastener required up front….
![](https://cimg4.ibsrv.net/gimg/www.rcuniverse.com-vbulletin/2000x1504/img_2060_387921e7bcef42c9adaee1d9ae41dacb053724d1.jpeg)
![](https://cimg7.ibsrv.net/gimg/www.rcuniverse.com-vbulletin/2000x1504/img_2173_fbbabeca90050e03fca2606b0a881ceece168e52.jpeg)
![](https://cimg8.ibsrv.net/gimg/www.rcuniverse.com-vbulletin/2000x1504/img_2194_9caa530cbf625076152cd076288310bca28b229c.jpeg)
![](https://cimg9.ibsrv.net/gimg/www.rcuniverse.com-vbulletin/1080x1920/img_2202_1e24964258bec2388db538680171b06a9e406042.jpg)
![](https://cimg1.ibsrv.net/gimg/www.rcuniverse.com-vbulletin/2000x1504/img_2507_8eae0cc57ac8d6cf661f5deaa3acb968960d5de7.jpeg)
Made the little platform for the back, I was also integrating a smoke tank, support on both side, shape both side to the size of the sleeve….hysol all that in, I also Hysol the former behind the sleeve.
#600
Anyone have a Rebel Pro flying with the new fuel tank fittings that CARF is now providing? I'm in the middle of assembling my Pro and it seems the the main fuel fitting although plumbed for 4mm ID fuel line, the actual nipple inside the bung is only 3 mm ID, worse, the vent fitting only has 2.5 mm ID. Is that going to be adequate for a 210 turbine? I was planning on using 6mm ID for suction and vent lines.
![](https://cimg4.ibsrv.net/gimg/www.rcuniverse.com-vbulletin/2000x1504/f8ca4675_6329_4436_ae0a_6c9096d9dcf9_d32b1f991f2b1010559e0273834ca21e398d801d.jpeg)
![](https://cimg7.ibsrv.net/gimg/www.rcuniverse.com-vbulletin/2000x1504/7145110e_27c2_4101_b62f_29d43f09b761_a567a266feac481c9183d0d5597121b44de8e724.jpeg)
![](https://cimg9.ibsrv.net/gimg/www.rcuniverse.com-vbulletin/2000x1504/b4ad834e_0e60_4a04_b99e_2e036de21047_aff32aadfb33d141f87716c35f3eca76a7b37bfd.jpeg)
How did you solve this problem?
regards Hermann
