Winter or Summer blend diesel fuel for turbine?
The following 2 users liked this post by sysiek:
Steve Collins (11-27-2023)
AEROSHELDON (11-29-2023)
My Feedback: (7)
HD kero is the cleanest Kero you can get ( we started with that fuel in the 2000s ) then we switched to pump Kero then pump Diesel, now we use both from the pump, I prefer Kero, it’s cleaner and not so smelly.
I get the farmers Kero from the pump ( cheeper and its red ) I filter it as it goes onto the can and have a paper fuel filter on the can before the pump, even though I filter the fuel going into the can, the paper filter manages to capture some stuff.
Jet A is Kero/Diesel, what it has that Kero and Diesel doesn’t is a bunch of additives and I believe that, makes it small so bad 😵💫😵💫
My Feedback: (41)
Buying Kerosene from Home Depot is a very expensive option. While Kerosend pumps at gas stations are relatively common in the midwest/south, just head to Joe Nall if you do not believe that, you will not find any of them in our neck of the woods, the Rocky Mountains. Nor will you find tinted Kerosene, there is tinted fuel for farmers but it's just tinted diesel not Kerosene.
You can find bulk plants in a lot of places but they are not common. The county I used to live in about 30 miles south of SLC and a population of about 300,000 only had one that I ever found. When I moved to southern Utah, the county only has a population of about 100,000 and it too has only one bulk plant and it took me awhile to find it. The price tag a these places for Kerosene, tends to run about $1.00 a gallon over diesel which is a WHOLE lot better that buying five gallon cans from Home Depot or the like.
In the summer, Kero was $2-3 more a gallon in my area. That does not sound like much, until you consider I was going through 5-7 gallons a weekend. It adds up. Yes Kero is cleaner and smells less but diesel is cheaper, more available, uses less turbine oil.
Tone
Tone
I've been using diesel for years with kt engines, but I agree that what you get at the pump varies greatly. Personally, I notice that winter diesel mix doesn't burn as well when starting up and I get a slight drip that I just can't avoid with my k210. Summer diesel doesn't do that. I've also used diesel that was apparently cut with unleaded gasoline, judging by the greenish color and gasoline-y smell. It also seemed a lot less oily than your average "yellow" diesel.
My Feedback: (53)
Winter diesel has nothing good and useful for turbines…it’s mainly so the diesel doesn’t gel in the tank…..at minus weather…..
When tanking Aircraft with Jet A-1 you can request the additive that does the same think….
My Feedback: (46)
We (myself and CARSII) have a local place that sells dyed Kero at the pump.
On my last two statements they charged me $6.00 a gallon which in CA is within $.40 of diesel prices.
It’s NOT dyed diesel which they have a separate pump for right next to the Kero pump. I ran diesel for the first few years and the Kero doesn’t smell anywhere near as much as the diesel.
Didn’t have to make any changes to either my KT or SW turbines to run it and they seem to run great on it.
Any kerosene advertised as K1 or 1K is the type that can safely be used in indoor heaters. It has less sulfur and aromatic content than regular kero. Diesel fuel has even less sulphur content. Sulphur is not good for our engines. This was especially true when combustion cans were stainless steel. When I used gas station pump kero it was 1K. It could be that different parts of the country sell regular kero at the pump.
