Reload this Page >
need an idea for battery tray!!!
Old 04-29-2024, 03:18 AM
extra 300
Default need an idea for battery tray!!!
Hello,
i am searching for some idea for 2 RX, 1 ECU and smoke pump battery trays that will be located in my TJ F-16 nose. The idea is to be able to remove them without a hassle and still have them secured.
Of course the best thing would have been if the nose was removable but this is not what I am looking for.
Thanks in advance for your ideas.
Old 04-29-2024, 10:52 AM
DAN AVILLA
My Feedback: (12)
DAN AVILLA's Avatar
Originally Posted by extra 300
Hello,
If you could take a picture that would give people a better idea of the space you are dealing with. On many jets there is a platform that is glued flat in the nose. Then they have a platform that slips on top and keys in to the front of the glued one with a bolt on the back so you can remove. The other option is use ions for rx and life for ecu and you do not need to remove to charge.
The following 2 users liked this post by DAN AVILLA:
AEROSHELDON (04-30-2024), Dansy (05-02-2024)
Old 04-29-2024, 12:54 PM
mongo
My Feedback: (15)
mongo's Avatar
have used old style wood fixed lg mount blocks as "drawer slides" to mount equipment trays in the hard to get a places.
then just a large screw head/washer screwed in over the slot end will keep it secure.
Old 05-04-2024, 10:48 AM
ltc
Have you considered building/adapting a battery tray often used in F3A airplanes?
https://www.f3aunlimited.com/gator-r...ket-kit-grcrtb
https://www.f3aunlimited.com/gator-f...tray-kit-large
I have used these for many years and they are easy to remove and work very well
Old 05-05-2024, 09:55 PM
Boomerang1
Boomerang1's Avatar
Cut a piece of 3 mm ply & cut the front to a point to fit into the nose of the model.
Then glue some balsa block to the top & bottom of the ply & sand it to a cone shape to wedge into the nose of the model.
This will secure it up & down & side to side.
At the rear secure it with some screws to some hardwood glued to a former or some hardwood glued to each side of the fuselage.
Hold your batteries in place on the ply with some balsa strips & zip ties. This idea worked fine on a Savex F-16.
extra 300 (05-08-2024)
Old 05-06-2024, 04:05 PM
jetsflyin
My Feedback: (12)
This is what I use. Just search Lipo battery tray on amazon.
Old 05-08-2024, 02:21 AM
extra 300
Great Idea Thanks!!
Old 05-08-2024, 02:25 AM
extra 300
it would work on for a single accessible battery. Not sure it would work in my application where i need to place 3 batteries inside nose cone and still be able to remove them without a hassle.
Thank you anyway as this tray could be used in a different setup though.
Old 05-10-2024, 10:39 PM
Westwindpilot86
Been using these in my F-15. And I have a couple more on the way for my PC-21. Joe is awesome to work with too. If you have a custom size battery he will print to that dimension. Very easy to take in and out of your jet.
https://www.rccustom3dprinting.com/p...ry-tray-medium
