Skymaster SU-27 CG >
Skymaster SU-27 CG
Skymaster SU-27 CG
Old 11-04-2024 | 02:35 PM
FenderBean's Avatar
Default Skymaster SU-27 CG
Hi everyone,
Im trying to find someone here with the 27 version that can verify the cg is good? The stock cg is a bit different than the 30 version which is all I have seen in person. Talked to one person that shared his measurements but are a bit different than my measurements I pulled.
thanks
Old 11-05-2024 | 07:51 AM
deleted.
Old 11-05-2024 | 01:00 PM
FenderBean's Avatar
I did glue in the holder because I figured I would need nose wait based on the spec cg but if you say it’s too nose heavy then I can mov them back to cockpit area.
I actually took so air pressure out of the nose because it is much easier to steer with it sitting about half stroke.
I appreciate the information with is had actual measurements to go on but I can work with that I think.
any idea where you are in relation to the manual?
Old 11-05-2024 | 05:28 PM
I must apologize, I thought this thread was in regard to the CARF SU-27. Please disregard all of the info I posted.
