Help identifying and finding air valve for struts >
Old 01-18-2025 | 07:23 PM
Default Help identifying and finding air valve for struts
Can anyone identify this air valve and tell me the name of it? and also where I could find a replacement? A friend has an old set of struts that use this type of air valve. Even if you could post a schematic so that maybe he can refurbish the valve. They are leaking so the struts are bottoming out. any help will be greatly appreciated.
Old 01-18-2025 | 07:27 PM
One more picture.
One more picture.
Old 01-19-2025 | 12:24 PM
Auburn02's Avatar
Skymaster, I believe.
Old 01-19-2025 | 05:59 PM
Default Valve
Originally Posted by pcskyhi
One more picture.
One more picture.
Looks like Skymaster. Most of the time it is the gasket that fails. I sure John or Anton can get you a replacement. I normally send email and get a response with price and availability. Chinese New Year is fast approaching when everything shuts down
RCFlyerDan (01-20-2025)
Old 01-20-2025 | 09:21 AM
RCFlyerDan's Avatar
My Feedback: (54)
They also twist apart extremely fast when trying to install them. They are very thin brass.
I twisted two apart on one strut within minutes. Don’t use a flathead screwdriver unless it has a V notch in the center to accommodate the air nipple. Otherwise you’ll learn the hard way as I did one day.
Old 01-20-2025 | 10:28 AM
ECalderon's Avatar
Hi
Definitely valve of Skymaster struts.
In the past I have got replacement from Skymaster (takes a while). Also I have seen them in Aliexpress, but can´t seen to find them there any more.
Some models of air guns use the same type of valve, maybe you have some luck searching valves for air guns parts.
Regards
