 9151 Servo >
9151 Servo
9151 Servo
Old 04-04-2004 | 05:51 AM
Default 9151 Servo
I have, sort of, asked this question before but need some more advice.
I bought a couple of Futaba 9151 digital servos for a project but for some reason did not use them.
I couldn't return them so had two expensive servos sitting idle. I have now installed them in the rudders of my Kangaroo.
My questions are;
Does anyone have experience with these servos in a jet?
Do you think they will be OK in my rudders?
Will the normal servo horns be strong enough?
I am a little concerned as they were apparantly designed for 12lb F3A aircraft. The specs are very good but they have a plastic gear train.
Speed: 0.19 sec/60° @ 4.8V
Torque: 132 oz/in (9.5 kg/cm) @ 4.8V
Your thoughts would be greatly appreciated.
Old 04-04-2004 | 08:05 AM
Erik R's Avatar
My Feedback: (32)
Default RE: 9151 Servo
siclick,
I am using 9151's on the elevators of my turbine F-15(Simjet 2300 powered),and they work very well.Metal gear servos will develop drivetrain slop over time.I believe resin gears are fine,other than impact resistance,where metal gears are superior.
Erik
