Aluminum Servo arms for 8411 jr servos
My Feedback: (73)
RE: Aluminum Servo arms for 8411 jr servos
though all other products this guy sells suck !! the servo arms are top quality ...
[link=http://www.ewtech.com/cgi-bin/miva?/Merchant2/merchant.mv+Screen=CTGY&Store_Code=hhi&Category_Code=HHI+Servo+Accessories]HHI heli[/link]
also try http://www.centuryheli.com/ .... they have a good selection as well ...
i will say however that unless you are going to use a ball link on the end of a metal servo arm, you are better of with the nylon or other heavy duty carbon reinforced arms ... if you put a clevise pin in a metal servo arm, you will always have some play .... (thats on top of the play you already have inside your servo geartrain ! )
Wojtek
Wojtek
My Feedback: (60)
I second the SWS, they are far superior to the dubro.
WOJ is absolutely correct. In fact, on the Isobar, we're going with the aluminum control surface horns with the ball bearing 4-40 combo. There is zero slop in this setup and on the end of an 8611 you get as close to 100% positive control at any position as you can get.
Good Luck,
Sean
Good Luck,
Sean
My Feedback: (29)
ON, CANADA
Air Wild servo arms are good. I have used them in the past. They are at [link=http://www.airwildhobbies.com/MoreInfo.asp?title=product&level=2&id=21]AirWild[/link]
